Massive screw up, transmission advice
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Torrey95, May 1, 2025.
  1. May 1, 2025 at 2:58 PM
    Torrey95
    Torrey95 [OP] Member
    2023 Tacoma OR
    Hey all, i messed up bad and am looking for any mechanics insight.
    Was attempting to do my first diy oil change. Instead of draining the oil i pulled the transmission fluid plug. To add onto my problems I proceeded to fill the oil, doubling the amount in the engine. I thought the dipstick looked high but have always thought it tough to read from residue oil getting high on the stick.
    Anyways i did a quick drive around the block to make sure everything was operating ok and there were no issues.
    The next day i drove 100 miles total going to work and back. That’s when the transmission started knocking and i reevaluated what i did. Once i got home i filled the transmission fluid and drained the oil to the proper level. Everything is operating normally now. No more knocking or anything concerning.
    I am wondering if i’ve done permanent damage to the transmission worth taking into a mechanic. Or if i can expect future problems. As of now it seems to be running fine.
    Thanks for any input!
    Irons and mtip like this.
  2. May 1, 2025 at 3:03 PM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    I would do another drain and fill on the transmission . Check for any metal debris .
  3. May 1, 2025 at 3:08 PM
    mike s
    mike s Well-Known Member
    South Carolina
    2019 TRD OR
  4. May 1, 2025 at 3:29 PM
    BabyBilly
    BabyBilly Well-Known Member
    Billy
    2020 TRD
    This happens more frequently than you would imagine. You'll probably be ok but it couldn't hurt to do a couple of drain and fills for the trans. The engine is fine.
    Don't sweat it too much. Mistakes happen. Don't let this deter you from future DIY.
    Chew, StayinStock, Irons and 3 others like this.
  5. May 1, 2025 at 3:37 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    I bought full steel skid plates to keep me from doing that! :bananadance:
    OP, if your tranny is running well you probably got by with just a small scratch. It’s good you caught that. Good suggestion to refill again- and double check your engine oil level as well.
    And you’re right about the dipstick, it helps to take Emery paper and scrape it by sanding across the stick up past the oil level indicators, that helps the oil stick to it better.
    CygnusX191, joeyv141 and BabyBilly like this.
  6. May 1, 2025 at 3:53 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Well, it will either live or die at this point so you might as well drive the damn thing!
    Chew, TnShooter, StayinStock and 8 others like this.
  7. May 1, 2025 at 4:47 PM
    pdxTacoSR5
    pdxTacoSR5 Well-Known Member
    PDX area
    2018 Tacoma SR5, V6 Auto, Access Cab, 4x4, Silver Sky Metallic
    there is a procedure for filling the trans. it involves warming up, shorting obd2 pins, click this, click that, magical incantations. you can read up on it in this forum for DIY. just dumping in some fluid is not correct and you could wind up damaging it. you'll probably survive your mistake if you fill it properly. i am only going on what i read here as far as trans fluid level check. never had the pleasure.
    edit: i did a quick search for 3rd gen trans fluid level check and came across this video in one of the threads. hope it helps. READ THE UPDATE AT YOUTUBE REGARDING GETTING INTO TEMP CHECK MODE.
    https://www.youtube.com/watch?v=rNqYpEpmUng
    Chew and Schlappesepple like this.
  8. May 1, 2025 at 5:00 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    OP, you need to change your oil since you really never changed it. You only have new and old oil mixed together. I really don’t know how you will avoid transmission failure since you drove it dry for a 100 miles. Sorry to be negative just don’t want to give you false hope.
    Chew and CygnusX191 like this.
  9. May 1, 2025 at 5:16 PM
    CrashZone
    CrashZone Well-Known Member
    Curious how you filled the trans when there is no dipstick and a whole procedure behind getting the fluid at the right level. I mean I hope you found the procedure online and did it right, but confusing the drain pans leads me to believe otherwise.
    Chew, t0p_d0g, swimmer and 1 other person like this.
  10. May 1, 2025 at 8:11 PM
    CB350G
    CB350G Trust you inner Hobbes
    Western PA
    2023 SR Access Cab 3.5V6 A/T 4x4 MGM
    WTT: hood for skewp WTT: seats for util pkg
    Damage to engine: Unlikely - maybe gave the PCV valve a workout and sucked a bit of oil through the intake, but shouldn’t cause physical damage to the engine. But, I had this happen on a Honda Civic (dealer oil change / overfill) and it ended up killing the O2 sensor. Took about 500 miles till the sensor died. (Just something to be aware of / don’t be surprised if...)
    Damage to transmission: Don’t know - defer to others. All depends on how far you drove before it started “knocking”. Possibly you were getting aeration of the fluid, getting chattering of the valves. :notsure: But agree - change fluid / drive it a bit / change fluid again - sounds like good advice.
    Then just slowly back away from the Taco…
    Torrey95[QUOTED][OP] likes this.
  11. May 1, 2025 at 8:26 PM
    HelloFelix
    HelloFelix Well-Known Member
    Felix
    Las Vegas
    2017 MGM 4x4 OR Tacoma
    You have way more fluid left in the transmission than you drained .
  12. May 1, 2025 at 8:38 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    You probably shortened your transmission's life. By how much? Unknown, but you still have the balance of your powertrain warranty to find out.
    Torrey95[QUOTED][OP] and jmneill like this.
  13. May 3, 2025 at 12:22 PM
    Torrey95
    2023 Tacoma OR
    Thank you, definitely makes me feel a bit better. I did a trans fluid change with temp check and all. Will do another drain and fill soon.
  14. May 3, 2025 at 12:23 PM
    Torrey95
    2023 Tacoma OR
    That's a hot tip! Thank you!
  15. May 3, 2025 at 12:24 PM
    Torrey95
    2023 Tacoma OR
    Thanks. I did a full drain and fill on the trans(with temp check) and everything seems ok!
    pdxTacoSR5[QUOTED] likes this.
  16. May 3, 2025 at 12:26 PM
    Torrey95
    2023 Tacoma OR
    I should have clarified, I did a full oil change after I realized. Trans seems to be operating fine after a drain and fill. Are you suggesting trans failure is in the truck's future?
  17. May 3, 2025 at 12:29 PM
    Torrey95
    2023 Tacoma OR
    Why even mention a dipstick if you know there isn't one? I used a youtube video for trans drain and fill with temp check.
    Your comment is neither constructive nor helpful.
  18. May 3, 2025 at 12:32 PM
    Dbarffish
    Dbarffish Well-Known Member
    Doug
    Montana
    2024 dcsb TRDOR blue crush
    Stock
    The remaining fluid in the tranny saved you big time. I would expect there to be some reduction in the life of the tranny but no idea how much.
    t0p_d0g likes this.
  19. May 3, 2025 at 12:42 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    Not necessarily if it’s shifting fine now you will probably be okay. You are very lucky!
    kahanabob and BabyBilly like this.
  20. May 3, 2025 at 12:57 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
