Massive screw up, transmission advice
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Torrey95, May 1, 2025.
  1. May 3, 2025 at 2:07 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    Unless Tacoma Corp monitors this site.
    pdxTacoSR5 likes this.
  2. May 3, 2025 at 2:13 PM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    When you drained the tranny fluid did you not notice the color of the fluid?
    Motor oil drain it is always black. I assume tranny fluid would be much different.
  3. May 3, 2025 at 5:45 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Just passing it on from someone else here :)
    -Take care!
    CygnusX191 likes this.
  4. May 3, 2025 at 6:04 PM
    CrashZone
    CrashZone Well-Known Member
    Don't care.
  5. May 3, 2025 at 6:06 PM
    BabyBilly
    BabyBilly Well-Known Member
    Billy
    2020 TRD
    Dumbass
  6. May 3, 2025 at 6:09 PM
    Akguy
    Akguy Well-Known Member
    way up north
    23' Silver OR DCSB
    Just curious how much fluid is left in the trans if you drain from the plug only
  7. May 3, 2025 at 6:13 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    The approximate capacity is 10.5 qts. a drain and fill takes about 3.1 qts. so he still had 7.4 qts.
    CygnusX191 and Akguy[QUOTED] like this.
  8. May 3, 2025 at 6:16 PM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Pull fill plug.
    Pull drain plug.
    Pull fill check tube.
    Drain.
    Reinstall tube.
    Fill until it's running out the check tube. Once it slows to a trickle, close drain plug.
    Close fill plug.
    Easy breezy.
  9. May 3, 2025 at 6:43 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Lol. Warranty will be fine.
    Not always. Penzoil can had a reddish sheen if it's not gunked up. So can Mobile One. (Not sure about others lol)
    But it's definitely not the same as tranny red lol
    bkhlrTaco's likes this.
  10. May 3, 2025 at 6:48 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    Absolutely, the first oil change I did on my 2gr-fks the Mobil 1 had the reddish look and I had to take a second look and make sure I didn’t drain the auto trans lol. :D
    CygnusX191[QUOTED] likes this.
  11. May 3, 2025 at 6:55 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I was driving my C6 Corvette down the highway years back and did not see a small object in the road. Unknown to me at the time, but whatever it was kicked up and punched a hole in the bottom of the transmission pan. I got off the exit and pulled into the store I was going to and peaked underneath. To my horror, I saw transmission fluid gushing out the hole that got punched in the pan.
    I had no idea how much I had lost before I parked it and shut it off, but obviously I was concerned. I had it towed to my Chevy dealer and they put a new pan on it, filled it up with new fluid and said it was just fine! I drove that thing hard for years after that incident with no issues. The moral of this story is that you are fine OP. And don't listen to these naysayers telling you that you have taken life off of your transmission. How the hell would they know that?
    vme and CygnusX191 like this.
  12. May 3, 2025 at 7:03 PM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Transmission fluid is intentionally dyed red to avoid any confusions.
    Maybe red motoroil guy had antifreeze in his? :notsure:
  13. May 3, 2025 at 7:10 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    No antifreeze oil turns a milky color when antifreeze is mixed with it. I had never used Mobil 1 and for some reason it does have a reddish look if changed at 5K intervals.
  14. May 3, 2025 at 7:18 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I did the same thing like 15 years ago and all was fine lol
    CygnusX191 and t0p_d0g like this.
  15. May 3, 2025 at 7:45 PM
    #35
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    It is, but nope I've never had coolant in my oil
    Been doing 5k on my 2017 for 120k miles. All changes were mobile except for one super tech change (never again)
    All of them have had a slight red sheen to the dark oil. :notsure:
    t0p_d0g[QUOTED] likes this.
  16. May 4, 2025 at 9:16 AM
    #36
    OnHartung'sRoad
    There was a putt putt racer with a loud fart pipe tailgating me once on a mountain road section with no turnouts, and he couldn’t see the boulder in time that was on the road that I had to straddle with my Taco. He sort of rolled over it but the rock was a can opener and took out both of the oil pans, his steering linkages and opened part of his floor. I hope it cured his tailgating problem!
  17. May 4, 2025 at 10:43 AM
    #37
    black3rdgen
    black3rdgen Well-Known Member
    STL
    3G on 35s, 5.29s
    YW tune, 5.29s, equal length dual exhaust, 2000w audio system
    Most of the fluid is held in the converter, right? I’d say the trans is probably fine. Overfilling oil is usually pretty bad but if it’s still running then whatever lol
