Master Cylinder going out?? Pedal gets softer while stopped.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nolazach, Sep 23, 2011.
  1. Sep 23, 2011 at 9:54 PM
    Nolazach
    Nolazach [OP] Well-Known Member
    New Orleans
    An ARE camper shell, a 1000w power inverter.
    Okay, I've had a similar problem before in a VW. But in that one the brakes just almost failed, and were really soft and slow to engage.
    What I have on the Tacoma, is the pedal gets softer while I'm sitting at a light or just stopped. At first I thought maybe it was normal, but It seems more frequent. No leaks at any wheel, so I can rule that out. With brakes if the system is closed then the problem is usually the cylinder.
    Also I noticed when the pedal does this, it seems like the torque converter engages or disengages giving the truck a small surge.
    Wondering if any one else had master cylinder issues or a pedal that gets soft when stopped, but is not spongy under normal use.
  2. Sep 23, 2011 at 9:59 PM
    youradhere
    youradhere Well-Known Member
    SoCal
    08 Prerunner TRD Off-Road
    Similar issue for me in my 08 DCSB Prerunner... the sponginess is very gradual, nothing like when my old integra's master cylinder blew out and I lost my brakes. This happens infrequently and I also get that lurch in the truck.
    Don't have any answers for you, but at least you know you aren't alone!
  3. Sep 23, 2011 at 10:00 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    The lurch at a stop is your ac compressor kicking on.
  4. Sep 24, 2011 at 8:08 AM
    Nolazach
    New Orleans
    damn its crazy, every weekend I think I have some major problem, then I come on here and find everything is normal.
    I'm going to price master cylinders, probably not a bad idea to change them. I was going to rotate my tires anyway, so I'll do a brake inspection while I'm at it. Damn that is a big surge to be "normal"
