Master Cylinder Plastic Reservoir Wobbly
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PzTank, Aug 6, 2019.
  1. Aug 6, 2019 at 11:47 AM
    PzTank
    PzTank [OP] Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Hey folks,
    I searched and found a gazillion hits for “Master Cylinder”. I searched further and did see this mentioned....
    The plastic top reservoir of my MC is a bit wobbly, side to side, from the metal base.
    I would say it moves about 1/16th or less if that. Definitely loose.
    I do not have any leaks.
    Is this normal?
    Is there a way to tighten it up?
    Is anyone else’s loose?
    Thanks :cheers:
  2. Aug 6, 2019 at 12:08 PM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Normal
    PzTank[OP] likes this.
  3. Aug 6, 2019 at 12:13 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    nope, wobbly
  4. Aug 6, 2019 at 12:15 PM
    PzTank
    Above the Notches
    Huh??
  5. Aug 6, 2019 at 12:15 PM
    BillsSR5
    bill
    2014 SR5
    wobbly
    PzTank[QUOTED][OP] likes this.
  6. Aug 6, 2019 at 12:48 PM
    PzTank
    Above the Notches
    So you’re saying yours is wobbly too and that it’s normal?
    Thanks
  7. Aug 6, 2019 at 6:23 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    If it's not leaking, it's fine. I believe they're mounted on rubber bushings.
  8. Aug 7, 2019 at 6:52 AM
    Taco'09
    Taco'09 Well-Known Member
    OP, there are two rubber O-ring like seals on the bottom of the reservoir that seal the reservoir from leaking at the aluminum M/C. I had them leak one time on another truck and had to replace them. For vacuum assisted brake control trucks (non ATRAC) they are available as spares.
