Master lock box in bed auxiliary box
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fluffytaco11, Nov 7, 2023.
  1. Nov 7, 2023 at 12:53 PM
    Fluffytaco11
    Fluffytaco11 [OP] New Member
    2011 Tacoma black access cab
    Black headlight and light housing, badge over lays, wheels
    This is my first Tacoma as I was looking around in the bed and I found a master lock box in the side box but dealership didn’t give me a code to unlock it with. I’m trying to see if anyone knows any trick to help me be able to unlock it without destroying it.
  2. Nov 7, 2023 at 12:56 PM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Look under the box and see if it is bolted or screwed in. It's a spare key box , only the PO would know the combo.
  3. Nov 7, 2023 at 12:57 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Hopefully that 10mm is in there.
    Captain4x4, essjay, YF_Ryan and 3 others like this.
  4. Nov 7, 2023 at 1:01 PM
    Fluffytaco11
    It looking to be screwed in
    Tiedie[QUOTED] likes this.
  5. Nov 7, 2023 at 1:03 PM
    Murd3rd
    Murd3rd I believe I Toyota harder than most
    Your Mom's House, USA
    00.5 Reg Cab Slammed, Turbo'd/19 TRD OR 6MT S/C
    1st gen - it's got a built engine, a turbo, and waaaaaaay too much to list. 3rd gen - basic-bitch lift, S/C, Pro Wheels
    Lockpickinglawyer on YouTube will show you how to get into that box quicker than if you even had the code.
  6. Nov 7, 2023 at 1:08 PM
    Stuck in VT
    Stuck in VT Well-Known Member
    Utah
    2019 SR SX MGM
    Try a paper clip pushing through one of the two inner numbers and pushing down the locking mechanism.
    SH10151 and Fluffytaco11[OP] like this.
  7. Nov 7, 2023 at 1:12 PM
    Tiedie
    David
    WFOY
    :worthless:from underneath, maybe you can un screw?
  8. Nov 7, 2023 at 1:15 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    hahaha. Not quite as fast, but dang, that's nuts how easy that is!!!
  9. Nov 7, 2023 at 1:22 PM
    Fluffytaco11
  10. Nov 7, 2023 at 2:00 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    That's a pretty clever way to keep a spare key!
    Tiedie likes this.
  11. Nov 7, 2023 at 2:04 PM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    McNallyOfficial shows you how to break into master combination locks.
    Tiedie likes this.
  12. Nov 7, 2023 at 2:04 PM
    RockfordTaco2006
    RockfordTaco2006 Well-Known Member
    Alexander
    2006 Toyota Tacoma TRD Off Road 4x4
    2 Inch Lift
