Match front lift to rear & new shocks.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mctechhweng, Aug 22, 2022.
  1. Aug 22, 2022 at 10:49 AM
    mctechhweng
    mctechhweng [OP] Well-Known Member
    Matthew
    2015 TRD Sport V6.
    Audio: Focal PC165, Focal KX2, JL VX800/8i, Pioneer AVIC-8200.
    I just put an Icon leaf pack on the back of my 2015 double cab TRD Sport. I measured the hub center to wheel-well distance before and after the leaf pack install & I came out with about 2.75" of lift as a result of the new leaf pack (Option two swap extra leaf with leaf 3 in pack). I'm waiting for a custom aluminum drawer system that is supposed to be ~150 lbs so I guess I'll re-measure after installing that.
    First, how do I figure out what measurements to give for new shocks? I wanted to get 5100's but 4wheel parts said they only make them for my truck in a 1" lift? (I'm assuming this is probably BS but idk).
    Second, how do I figure out how much lift I would need on the front to match the rear? Assume I want it level, do I just measure hub to wheel-well again? (idk if the wheel wells are actually at an even height).
    Thanks.
  2. Aug 22, 2022 at 10:58 AM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Measure the current hub to fender
    Put a jack under the front cross member, start jacking it up until your happy with how it looks.
    Put a level on the door seal if you want it 100% level (these trucks look silly without any rake).
    Remeasure hub to fender.
    This is how much lift you need.
    Purchase accordingly
    Marc70 likes this.
