Matching spare on 3rd gen?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ngejie, Mar 11, 2025.
  1. Mar 11, 2025 at 9:00 PM
    ngejie
    ngejie [OP] Active Member
    North Texas
    2023 TRD Pro Ice Cap
    I DID search, admittedly a little half assed and didnt find much info about 3rd gen’s. I’m about to upsize to 265/75/16 on the stock pro wheels and was wondering if a trd pro wheel 16” could be mounted as the spare under the bed and not get scratched up? I know the larger tire will be a little closer to the exhaust but not much. Mostly worried about buying a matching pro wheel and scratching it up… I will be keeping that wheel and tire in rotation. So it will be a 5 tire rotation going. Thanks in advance guys!
    Finn-2187 likes this.
  2. Mar 11, 2025 at 9:22 PM
    Finn-2187
    Finn-2187 Well-Known Member
    2021 White Tacoma SR 4x4 DCSB
    Fog lights, Vision Turbine 16x8 wheels, Goodyear Wrangler Ultraterrain 265/75/r16 AT's, janky LEDs that probably won't catch on fire
    I have 265/75/16s and aftermarket rims all the way around including a matching spare wheel and tire and haven't noticed any scratches FWIW. Just be sure you're aware of the tpms issues with a 5 tire rotation. Apparently our trucks can't remember more than 4 sensors at a time.
    musicisevil likes this.
  3. Mar 11, 2025 at 9:25 PM
    ngejie
    North Texas
    So you’re saying that adding a tpms sensor in the spare will mess with the system? Geez…
    Finn-2187[QUOTED] likes this.
  4. Mar 11, 2025 at 9:31 PM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    I stow my matched spare face up so the hoist doesn’t mar the show side. It’s always filthy when I rotate it in, but have yet to notice any significant damage after cleaning them. I have a magnet on the chain to keep it from knocking around, but that’s probably unnecessary overkill.
    +1 for the tpms issue. It’s an added expense to consider. You’ll need a tpms tool (pay once), obdii > usb dongle/computer/pirated version of techstream (pay once), or Carista ($10 pay and cancel subscription every rotation). Alternatively you could pay someone else to program the sensors every time or you could also just do nothing if you don’t care about only having 3 sensors on the ground 4/5’s of the time for the life of your tires.
    It’s not that adding a TPMS sensor messes up the system, it’s that the ECU can only monitor 4 sensors. There’s no place to input a fifth sensor ID and the computer has no provision for monitoring one
    SoonToBeOn39s, wood714 and Finn-2187 like this.
  5. Mar 12, 2025 at 12:07 AM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Abandon the fifth wheel tire rotation and keep an old used spare as a spare; does not have to match tire size being a temporary spare. Easy-peasy.
    Veet-88 likes this.
  6. Mar 12, 2025 at 1:28 AM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    This i hopped around shops for a decent shape tire in the right size put it on the steely then just picked up a spacer so my 285 would clear full sized spare for the low cost of free
