Math deficiency: Talk to me about calculating mileage with non-stock tires
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Slverfox, Apr 7, 2021.
  1. Apr 7, 2021 at 12:25 PM
    Slverfox
    Slverfox [OP] Member
    Hi all,
    I recently replaced my tires on my 2019 Tacoma with 265/75-16's. The tire calculator chart says that the tire diameter is 3.4% bigger than my previous tires.
    Given that my mpg readout is likely calibrated for the smaller stock tires and subsequently more revolutions per mile, would it be accurate to assume that my mileage is 3.4% greater than what my display tells me? If not, how would I go about accurately calculating my mpg other than using a third party gps device to determine mileage and begin from a full tank with subsequent refill?
  2. Apr 7, 2021 at 12:36 PM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    no. you would add 3.4% to the miles driven per tank and then calculate the mpg. Miles driven/Gallon's used = MPG
    Fargo Taco likes this.
  3. Apr 7, 2021 at 12:38 PM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    use the vehicles trip meter... :notsure:
    fill it up, set it to zero, drive until gas light goes on, then fill it back up, take note of how many gallons you take on, and then divide :gossip:
  4. Apr 7, 2021 at 12:40 PM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    but if the tire size is different, will the speedo record the correct miles driven?
  5. Apr 7, 2021 at 12:41 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    NONE of Ur electronic devices will match up.....................even if All components stock
    the dash mpg info is close yet not as accurate as miles driven / gallons used
    to get the very best / accurate info
    have a loop U can drive under consistent conditions
    cruise control is better than under foot
    fill up.....zero the miles .........drive conservatively ( hi-way .....NOT commuter environs )
    3 to 5 gallons used would be the min
    divide miles driven by gallons at fill up
    new tyres vs worn tyres WILL CHANGE ANY CALCULATIONS
    Any TRUCK !!! even tho U are not using stock size
    so being totally obsessive analytical retentive will drive U crazy
    a good run will provide U reasonble info
  6. Apr 7, 2021 at 12:42 PM
    Clearwater Bill
    Billy
    Largo Florida
    1st thing to do is check your speedo against a good GPS and see how far off it is, or isn't.
    Because of a typical 'read high' error in most OE speedos, *sometimes* a bit more tire actually corrects the speedo.
    Lt. Dangle and uurx like this.
  7. Apr 7, 2021 at 12:43 PM
    a2lowvw
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    no. you take the trip meter and have to calculate the supposed vs actual numbers. If you know the speedo and odometer are off by a 3.4% variance it should be pretty easy to calculate.
  8. Apr 7, 2021 at 12:43 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    This is correct. ([miles driven] x 1.034) / gallons
    EDIT: Actually, you can switch that formula around like you originally thought and get the same answer. Whatever it tells you your MPG is, multiply by 1.034 to get actual MPG.
    y=mx+b, Spunky and Fargo Taco like this.
  9. Apr 7, 2021 at 12:45 PM
    Spare Parts
    Southern Maine
    Understand this, but the commetn I quoted, the person said just use the trip meter. And I was asking if you have changed stock size tires, won't the trip meter be off.
    uurx likes this.
  10. Apr 7, 2021 at 12:47 PM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    Yes it will be off because the distance it's expecting to travel over one revolution of the wheel is less than what it actually is with the larger tires.
  11. Apr 7, 2021 at 12:47 PM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    Hold up, so if I'm on larger tires am I getting better or worse MPGs than my truck computer is telling me?
  12. Apr 7, 2021 at 12:48 PM
    Fargo Taco
    Fargo
    2019 TRD Pro
    Should be better because you're physically traveling further than it thinks.
  13. Apr 7, 2021 at 12:49 PM
    ishootaround
    ishootaround Well-Known Member
    2020 SW Tacoma TRD Pro M/T
    Your assumption is, more or less, correct. The new tire has a larger circumference, so it takes longer to make a complete revolution, relative to the smaller tire. This is why the speedometer is off by that 3.4%. So for every 100 miles driven according to the dash, you've actually have gone 103.4. What is not accounted for is the extra weight of the new tire, adding to the unsprung weight. So it's not as easy as adding 3.4% to your number. Your mpg is better than what is shown, but just slightly.
  14. Apr 7, 2021 at 12:50 PM
    DWD484
    DWD484 Could Be Joking
    Dave
    Louisiana
    '19 DCSB TRD Sport
    Super White
    Wouldn't it be easier to just fill up when needed and not worry about all that mpg stuff?
    PilotMM, dleriche and Spare Parts like this.
  15. Apr 7, 2021 at 12:50 PM
    ROAD DOG
    FEW
    speedometre ......trp metre will be off from Normal tyre wear
    so nit pickin tyre size is going down the rabbit hole
    to the point if an accurate mpg with staock tyres................thats out the window now sizes have changed
    driving & filling up is NOT goin to be determined by 3%
    Ur gointo go & do no matter what
    U only need a rule o thumb when trip planning.....................matters will rarely be as close as 3% !!
    as i mentioned before new tyre vs same tyre wear are real world factors
    Spare Parts[QUOTED] likes this.
  16. Apr 7, 2021 at 12:52 PM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    This, but you need to know the difference in circumference, not diameter. You get that by multiplying stock and new diameters by pi and noting the percentage difference. You have metric sized tires on standard sized rims, and sidewall is a percentage of width, so there's even more math involved.
  17. Apr 7, 2021 at 12:53 PM
    a2lowvw
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    While this is all true. If you are trying to calculate your mileage off of an inaccurate number then your result's aren't accurate either.
  18. Apr 7, 2021 at 12:53 PM
    ROAD DOG
    FEW
    if U had 3% more ‘ winky ‘ ........................Ur girlfriend would not notice !!
    regardless of tyre size Ur going to drive to get to where UR going .............. destination achieved
    no one in their right mind would stop 3% shorter
  19. Apr 7, 2021 at 12:54 PM
    Fargo Taco
    Fargo
    2019 TRD Pro
    Agreed.
    Using 100 and 103.4 miles and assuming 5 gallons to fill up, that equates to 20 and 20.68MPG.
    That's not really enough to worry about, IMO.
    ishootaround[QUOTED] likes this.
  20. Apr 7, 2021 at 12:54 PM
    Fish.Taco.Ma
    Fish.Taco.Ma IG: @fish.taco.ma
    Dean
    2017 Silver Sky Tacoma TRD Offroad
    This is the best method. Luckily changing tire size doesn't effect the fuel gauge.
