MatosTaco's Build Thread
Discussion in '1st Gen. Builds (1995-2004)' started by MatosTaco, Mar 12, 2021.
  1. Jun 18, 2021 at 1:16 PM
    #281
    MatosTaco
    MatosTaco [OP] Well-Known Member
    96 Toyota Tacoma
    Coilovers, sway bars, wheels, tires, extended studs, intake, head and taillights, seats, short shifter,
    Well, the black plastic came in and my two Lexus wheels are officially getting rebranded. The print looks really good. Now I just need to sand down the silver trim on the bottom and spray it black.
    [​IMG]20210618_160550 by Jose, on Flickr
    ireymon likes this.
  2. Jun 18, 2021 at 2:30 PM
    #282
    MatosTaco
    96 Toyota Tacoma
    Here is what the steering wheel looks like once assembled. I really like the look. It's going to be even better once that silver is gone!
    [​IMG]20210618_165957 by Jose, on Flickr
  3. Jun 19, 2021 at 1:41 PM
    #283
    MatosTaco
    96 Toyota Tacoma
  4. Jun 22, 2021 at 3:30 PM
    #284
    MatosTaco
    96 Toyota Tacoma
    In order to get the hood ready for restoration, I cut the excess material hanging from the bottom where the vent is. Now that this is cleaned, I can fit a mesh in from the bottom. However, before I do that, I am going to wet sand and then clear coat the entire hood. Before even doing that, I have a couple of defects and holes in it the hood that need to be filled with epoxy.
    [​IMG]20210622_164554 by Jose, on Flickr
  5. Jun 22, 2021 at 10:26 PM
    #285
    MatosTaco
    96 Toyota Tacoma
    Here it is after it dried in the sun (I rinsed it to get off the dust from cutting the excess material). I have to say, it looks way better just by not having that bit of material exposed at the vent. Now you just see pure engine bay. I can't wait to have it all polished, clear coated, and meshed.
    [​IMG]20210622_183233 by Jose, on Flickr
  6. Jun 23, 2021 at 2:53 PM
    #286
    MatosTaco
    96 Toyota Tacoma
    As part of the process of restoring the hood, I decided that the windshield washer holes had to go. The hole I mistakenly made years ago (when cutting the openings for the hood hooks) also had to go. In order to do this, I cut small squares of aluminum foil and taped them down over the holes atop the hood. Then, I flipped the hood over and poured some clear epoxy into each of the three covered holes.
    [​IMG]20210622_212229 by Jose, on Flickr
    Once that dried just enough to get tacky, I put a small piece of carbon fiber in each. Then, I added more epoxy in order to soak the carbon. Once that was dry, I flipped the hood over and removed the tape/foil. From there, I added more epoxy from the top side. Once that dries, I will sand it down flush with the top of the hood.
    [​IMG]20210623_171518 by Jose, on Flickr
  7. Jun 23, 2021 at 2:55 PM
    #287
    MatosTaco
    96 Toyota Tacoma
    Up close, you will always see the difference at these points- especially since the carbon I used is a different weave. However, I don't care too much about that. I was more concerned with filling it. I may also paint the center of the hood, so it may very well go unnoticed.
  8. Jun 25, 2021 at 9:17 AM
    #288
    MatosTaco
    96 Toyota Tacoma
  9. Jun 25, 2021 at 10:52 AM
    #289
    MatosTaco
    96 Toyota Tacoma
    Working on this has me wanting to make random carbon fiber parts. Stay tuned for random carbon craziness lol!
  10. Jun 25, 2021 at 2:30 PM
    #290
    MatosTaco
    96 Toyota Tacoma
    Here's the sanded hood once dry
    [​IMG]20210624_215104 by Jose, on Flickr
    Can't wait for the epoxy to be hard enough to sand so I can even this out and clear coat it all.
  11. Jun 26, 2021 at 9:14 AM
    #291
    MatosTaco
    96 Toyota Tacoma
    My local junkyard got a Tacoma in, so I woke up early to go take parts off of it lol. Snagged a hub, valve cover, tailgate latches, interior door handle, visor clips, etc. May go back tomorrow and get the tailgate too, we shall see. My visor clips broke years ago, as did one of my visors, so I had gotten one from the junkyard.
    [​IMG]20210626_111825 by Jose, on Flickr
    [​IMG]20210626_111827 by Jose, on Flickr
    Turns out, the visor I got is the wrong length. I realized it because I put the clips in and it did not reach. I may have taken it from a 4Runner now that I think about it. Oh well,
    the plastic on it is the wrong color anyway. I will have to hunt for a new one.
    [​IMG]20210626_112349 by Jose, on Flickr
    I did wrap both of these in microsuede way back when, so I will have to redo this once I find a new visor
    [​IMG]20210626_112405 by Jose, on Flickr
  12. Jun 26, 2021 at 6:02 PM
    #292
    MatosTaco
    96 Toyota Tacoma
    Here are the other spare Taco parts I got from the junker
    [​IMG]20210626_205219 by Jose, on Flickr
    [​IMG]20210626_205213 by Jose, on Flickr
    They look like junk right now, but I will restore them to look fresh really soon
  13. Jun 26, 2021 at 6:06 PM
    #293
    MatosTaco
    96 Toyota Tacoma
    The other thing I got at the junkyard is this SC300 brake booster. I am going to be swapping my master cylinder out for an SC300 one, but doing so requires you use the SC booster as well. I ordered the master cylinder from Rockauto, since I wouldn't be confident running a master cylinder from the junkyard (that and I hate yellowed out brake reservoirs).
    [​IMG]20210626_205222 by Jose, on Flickr
  14. Jun 27, 2021 at 2:04 PM
    #294
    MatosTaco
    96 Toyota Tacoma
    Well, I finally felt confident enough in the curing of the epoxy on the hood. So, I took the hood outside and sanded it down. Starting from 180, then moving on to 220, 400, 600, 800,1000, 1200, and 1500 on the epoxy itself got the thick epoxied surfaces down flat and even. Then, I did a final finish sanding on the entire hood. I wanted to go with 1500, but had run out, so the final finish sand is at 2000 grit.
    [​IMG]20210627_145127 by Jose, on Flickr
    You can see how flat the epoxied areas are now
    [​IMG]20210627_145803 by Jose, on Flickr
    [​IMG]20210627_163156 by Jose, on Flickr
  15. Jun 27, 2021 at 2:04 PM
    #295
    MatosTaco
    96 Toyota Tacoma
    Here's the wet hood when I put it out in the sun to dry
    [​IMG]20210627_163203 by Jose, on Flickr
  16. Jun 27, 2021 at 6:30 PM
    #296
    MatosTaco
    96 Toyota Tacoma
    Flare side Taco Lover likes this.
  17. Jun 29, 2021 at 7:32 PM
    #297
    MatosTaco
    96 Toyota Tacoma
    Well, I got the mesh glued on with some plastic bonder epoxy. Same stuff I used to glue the mesh on my Miata's hood.
    I had the hood upside down and supported with 2x4s so it would sit off the surface of the work table.
    [​IMG]20210629_184948 by Jose, on Flickr
    The epoxy was mixed and spread all over the inner edge, followed by placing the mesh down and adding weights to keep it in place. I used some cuts of wood to distribute the load from the weights.
    [​IMG]20210629_184954 by Jose, on Flickr
    Some epoxy came through the other side and will need to be cleaned up, but overall, I am happy with the outcome
    [​IMG]20210629_213015 by Jose, on Flickr
    Almost time to clear coat this hood!
    [​IMG]20210629_213111 by Jose, on Flickr
  18. Jul 1, 2021 at 2:36 PM
    #298
    MatosTaco
    96 Toyota Tacoma
    My SC master is finally here! Time to paint and refresh the booster, and then this sucker is going on the truck! The most complex part is going to be bending the lines, since the SC master has the lines on the opposite side.
    It's a cool looking, dual cylinder arrangement. I expect this will handle all my 4 wheel disc braking needs lol.
    [​IMG]20210630_130709 by Jose, on Flickr
    [​IMG]20210630_130705 by Jose, on Flickr
    Dalandser likes this.
  19. Jul 4, 2021 at 3:12 PM
    #299
    MatosTaco
    96 Toyota Tacoma
    I started freshening up a couple of things before putting them on the truck. As per usual, there is no way anything with rust is going on my truck. So, I sanded down the SC300 brake booster and then painted it with self-etching primer. I followed that up with a coat of Rust Reformer and am planning to finish it off with a urethane Black Sand Pearl and clear coat.
    [​IMG]20210704_174431 by Jose, on Flickr
    I also removed the silver trims from the IS300 steering wheels that I have. I wet sanded those down to about 600 grit and then did self etching primer, more sanding, and about three coats of VHT roll bar and chassis black. They look much better in the semi-gloss black than they did in the faded, factory silver. I also generally detest silver plastic. If you want something to look like metal, just use metal lol.
    [​IMG]20210703_173419 by Jose, on Flickr
  20. Jul 4, 2021 at 3:15 PM
    #300
    MatosTaco
    96 Toyota Tacoma
    Here's a quick comparison on the difference in appearance:
    Before:
    After:
    [​IMG]20210703_173412 by Jose, on Flickr
    Now I just need to redo the leather on all of them. I have like 7 of these steering wheels in total, three Supra ones and four IS300 ones(steering wheel buttons). Re-wrapping steering wheels has apparently become another one of my weirdo hobbies lol. I just love the transformation once they are all freshly leathered out!
    Phessor likes this.
