MatosTaco's Build Thread
Discussion in '1st Gen. Builds (1995-2004)' started by MatosTaco, Mar 12, 2021.
  1. Mar 12, 2021 at 12:31 PM
    #161
    MatosTaco
    MatosTaco [OP] Well-Known Member
    96 Toyota Tacoma
    Coilovers, sway bars, wheels, tires, extended studs, intake, head and taillights, seats, short shifter,
    1-07-2019
    Decided I was tired of pushing my ridiculously heavy clutch pedal and holding it down every single time I start the truck. So, I took the truck out of gear, crawled into the floor space and pushed down the button under the clutch pedal. Once I saw that I could turn the truck on whilst pushing this in, I knew what to bypass. In the Miata world, we have the bypass clip from Flying Miata that installs here and holds the button down. I considered designing one for the Tacoma, but I realized a simple zip tie would do the trick. Here is the completed bypass, it works like a charm.
    DISCLAIMER: This modification makes it possible for you or someone else to inadvertently start the vehicle in gear. This could result in the vehicle crashing into people, buildings, pets, other vehicles, etc and result in serious injury or death. If you perform this mod, you do so at your own risk. I take ZERO responsibility for any harm or damage done by your vehicle and/or to your vehicle as a result of this mod.
    [​IMG]CM0 by Jose Matos, on Flickr
    On another note, how annoying is it that car manufacturers don't paint the metal that goes under the dash just because it isn't visible? I don't care if I can't see it, I DON'T want RUST in my car smh!
  2. Mar 12, 2021 at 12:33 PM
    #162
    MatosTaco
    96 Toyota Tacoma
    1-26-2019
    My starter ended up sticking the other day. When I tried to turn the truck on, it was slow to crank and for whatever reason I turned it back to off and then on again. Well, the truck came on but my starter kept spinning. Turned it off and it kept spinning... so I disconnected the negative from the battery. At this point, I thought I had ruined the ignition cylinder, so I pulled it out and connected the negative again- starter kept spinning.
    At this point, I realized it had to be the starter solenoid, so I fully disconnected the battery and pulled the starter. Sure enough, the shaft that holds the little sprocket and turns the flywheel was stuck out. I spun it and it popped back in. Put the starter back in and reassembled my dash. Truck started right up with no drama.
    So, if this happens to you, just disconnect the battery and then pull the starter. Don't end up doing this lol, (even if it's easy for me at this point)
    [​IMG]M11 by Jose Matos, on Flickr
  3. Mar 12, 2021 at 12:35 PM
    #163
    MatosTaco
    96 Toyota Tacoma
    April 2020
    With the coronavirus keeping everyone at home, I have finally found time to edit video and post on Youtube again! Here's the latest on the truck, I finally got around to installing the backup camera a few months back and I edited the video recently.
  4. Mar 12, 2021 at 12:36 PM
    #164
    MatosTaco
    96 Toyota Tacoma
    I also had to change my alternator since my previous battery decided to spew acid on it and cook it. A true shame, since that alternator had been running faithfully since 1996 (it was the original alternator). I made sure to replace it with an identical unit from Denso (OEM Toyota).
    https://youtu.be/61IgjcKr0R4
  5. Mar 12, 2021 at 12:38 PM
    #165
    MatosTaco
    96 Toyota Tacoma
    I needed a better work space for modding and maintaining my Tacoma, Miata, and Camaro, so it was time to remodel the garage. I made good use of the free time generated by corona virus/kept myself from going nuts at home, by doing new lights, paint, and epoxy floors.
    Here is part one
    https://youtu.be/kIN4KzA1luA
  6. Mar 12, 2021 at 12:38 PM
    #166
    MatosTaco
    96 Toyota Tacoma
    Here is part 2 of my garage remodel. It consists of prep work needed before painting, such as floor etching and removal of appliances.
    https://youtu.be/EM9mj0AQLDc
  7. Mar 12, 2021 at 12:39 PM
    #167
    MatosTaco
    96 Toyota Tacoma
    Here is part 3 of my garage remodel. I got the masking done and began the process of painting, touchups, mounting the attic frame, and coating the floors with 1 part epoxy.
    https://youtu.be/08UabuAIEtk
  8. Mar 12, 2021 at 12:39 PM
    #168
    MatosTaco
    96 Toyota Tacoma
  9. Mar 12, 2021 at 12:40 PM
    #169
    MatosTaco
    96 Toyota Tacoma
    Quick update on next phases for the garage project
  10. Mar 12, 2021 at 12:41 PM
    #170
    MatosTaco
    96 Toyota Tacoma
    Got my tool drawer and 3D Printer in. Back in business!
  11. Mar 12, 2021 at 12:42 PM
    #171
    MatosTaco
    96 Toyota Tacoma
    01-2021
    Back to working on the old Taco! My LCE short shifter blew out the shift bushings...again... so I got a new set of Dorman bushings from AutoZone. That felt great for a while, until it didn't... went right back to feeling like a chicken wing when you break it at the joint. I had also grown sick and tired of the one piece short shifter amplifying the transmission noise into that cabin. Talk about tinnitus inducing! To remedy this, I ordered a URD shifter that simply extends the stock 2 piece shifter and it includes a thicker shift plate (about 1/4" thicker than the LCE one) so throws are even shorter. The stock shifter also helps to quiet the interior, sits the shift knob further away from the radio/closer to the steering wheel, and doesn't tend to blow out shift bushings. For now, I am using a new set of Dorman bushings, but I have some Delrin ones coming from Marlin Crawler. I realized that my issue with the previous Marlin Crawler bushings was that the o-ring from the bottom of the factory shifter had remained in the shift neck. This didn't allow the new bushing to sit down far enough. The URD short shifter feels great as is with the squishy Dorman bushing, I can't wait to try it with the Marlin Crawler!
    [​IMG]20210119_174735 by Jose, on Flickr
    There are a couple of notes I would like to make about this install. One is that the extender did not slide smoothly over my factory shift ball and I had to beat the shifter into a 2x4 to get the adapter to seat.
    [​IMG]20210119_182515 by Jose, on Flickr
    The other is that this setup uses Allen head bolts and there is no way you are getting a wrench and Allen adapter in the back two bolts. This is because they sit behind the shifter cutout and the gap between the top of the bolt and the metal of the transmission tunnel is not large enough. I remedied this by turning the Allen adapter with a 1/4" flat wrench. These bolts are to be torqued to 13 lb-ft per the instructions, you should be able to apply that with your bare hands.
    [​IMG]20210120_132027 by Jose, on Flickr
    [​IMG]20210120_132800 by Jose, on Flickr
    Final result, and yes, I need a new shift knob!
    [​IMG]20210122_103433 by Jose, on Flickr
  12. Mar 12, 2021 at 12:43 PM
    #172
    MatosTaco
    96 Toyota Tacoma
    Video of me putting the short shifter in
  13. Mar 12, 2021 at 12:43 PM
    #173
    MatosTaco
    96 Toyota Tacoma
  14. Mar 12, 2021 at 12:44 PM
    #174
    MatosTaco
    96 Toyota Tacoma
    As promised, here is the video of my impressions after driving the truck with the short shifter
  15. Mar 12, 2021 at 12:44 PM
    #175
    MatosTaco
    96 Toyota Tacoma
    Did a quick video with some highlights of upcoming mods. I think you guys will like this stuff. Check it out below:
  16. Mar 17, 2021 at 12:48 PM
    #176
    MatosTaco
    96 Toyota Tacoma
    Started to accumulate more parts for my 8.8 axle swap. Unfortunately, the supply shortages that are appearing as of late are hindering my progress. In particular, it is hard to get 8.8 replacement clutches and I really don't want to use the ones in my diff as I don't know how good they are. I will have to measure each pack and see how thick it is. I suppose if they are above the 0.635" minimum thickness, I can leave them in. Stock is 0.645" and performance ones (what I wanted) are >0.655" and would result in a tighter differential. So far, I have the 8.8, Evo 8 rear rotors, ZL1 rear Brembo calipers, and Permatex Gear Oil Gasket maker. The diff fluid, friction modifier, and u-bolts are on their way.
  17. Mar 17, 2021 at 4:51 PM
    #177
    MatosTaco
    96 Toyota Tacoma
  18. Mar 17, 2021 at 5:17 PM
    #178
    Taco1004
    Taco1004 Boats Hoes and Fishy Tacos!!
    WestMonster, MD
    ‘20 TRD-S
    Yakima roof basket Yakima bike rack (x2) Yakima snow rack (fishing rods) K&N intake kit K&N throttle module AFE Silver Bullet TB spacer MBRP stainless off-road exhaust SpiderTrax spacers Enkei RPT1’s 18x9-0 offset CBI front bumper CBI Overland Bed Bars TRD Pro front skid TRD Pro shift knob TufSkinz carbon trim everywhere MESO trim kit MESO MOLLE rack MESO Stage 1 Tails MESO side markers Diode Dynamics fogs Kicker tweeters (Subaru) Kicker CS 3-Way 6x9’s Kicker CS 2-Way 6.5’s JL Audio Stealth 10” sub JL Audio 300w amp Eibach 2.0 Pro front coils Eibach rear shocks SuperLift billet 1.5” rear blocks Camburg UCA’s ECGS Mountain Hatch tailgate panel AVS taillight covers AVS slim window visors AVS slim hood visor Morimoto LB and HB LED’s MaxTrax MK2 recovery boards Hi-Lift jack Custom surf fishing mount GTS headlight lenses RIPP coil packs Taco Troopers wrap
    Hats off! I just came across your build and this is awesome! I love mini truck builds... in fact, I’m looking to find a SCSB automatic 2wd 1st Gen myself and start a project truck with my son.
    The work you have done is great, hands down some of the best driveway craftsmanship I’ve ever seen. Definitely subscribed to this thread. When you going to start the 2JZ swap? Lol! Thank you for documenting this all!!
    ~cheers!
  19. Mar 17, 2021 at 5:23 PM
    #179
    MatosTaco
    96 Toyota Tacoma
    Thank you, I appreciate that! There is definitely a lot more to come. I want this one to handle well and be as light as possible, so no 2JZ for it, but I have considered purchasing another one for this very purpose- we'll see what happens.
    Taco1004[QUOTED] likes this.
  20. Mar 18, 2021 at 2:02 PM
    #180
    MatosTaco
    96 Toyota Tacoma
    The parts keep piling up for the 8.8 swap. I took the diff apart earlier and checked the thickness of the clutch pack, it is only at 0.604," so I will definitely have to order a new set.
    [​IMG]by Jose, on Flickr
