Matt’s Off Road Recovery
Discussion in 'Recovery' started by Thunder Fist, Mar 23, 2020.
  1. Feb 14, 2022 at 11:46 AM
    #421
    hr206
    hr206 Well-Known Member
    Western Washington
    '16 DCSB TRD OR, '98 regular cab 4x4
    Not sure how durable MaxxTraxx are - can you do a couple recoveries a day and have them last a few months? A recovery strap is probably cheaper on a per use basis.
    henryp and BudFriendguy like this.
  2. Feb 14, 2022 at 11:54 AM
    #422
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    They're pretty durable, they are a microfiber reinforced nylon, think power tool bodies, they'll hold up to plenty of recoveries unless you have wheel spin on them. If you spin your tires you can burn through them pretty quickly, a common mod is to take the first three rows or so of the plastic lugs grind them down drill through and replace with 1/4 20 bolts to give more grip that won't be burned off.
    Recovery boards are great for the weekend warrior because they save weight and are good enough but if you're doing it professionally, aluminum tread step would probably be better but at that point a kinetic rope or winch would be best.
    The other benefit of MaxTrax is you can stack them and use them as a ramp or bridge along with winching or snatching.
    hr206[QUOTED] and BudFriendguy like this.
  3. Feb 14, 2022 at 12:01 PM
    #423
    stonylaroux
    stonylaroux Well-Known Member
    Seattle, WA
    2015 Toyota Tacoma TRD Offroad
    Give him long enough hanging out with Rory and Trail Mater and he'll probably have them. Even Trail Mater has some steel/aluminum traction boards. It would certainly beat stacking rocks for low clearance cars like they do a lot of times.
    BudFriendguy and Key-Rei[QUOTED] like this.
  4. Feb 14, 2022 at 12:54 PM
    #424
    gotblika
    gotblika Well-Known Member
    Maui
    2015 DCLB Sport 4X4
    5100'S 887 SPC B110 EL096R
    Someone gifted him a set of traction boards. He doesn’t use them, he has a reason but I don’t remember.
  5. Feb 14, 2022 at 4:07 PM
    #425
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Probly cuz he has that nice yellow kinetic rope.
    madcratebuilder and w.adventures like this.
  6. Feb 16, 2022 at 7:40 AM
    #426
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Advanced technique using both the rope and winch from the same vehicle to pull the Sequoia out
    essjay likes this.
  7. Mar 2, 2022 at 6:02 AM
    #427
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    More Toyota content on Robby Layton's channel :)
  8. Mar 3, 2022 at 10:11 AM
    #428
    roundrocktom
    roundrocktom Well-Known Member
    2021 Silver DCLB Off Road
    Toyota 4Runner. They missed the "road closed sign".
    A couple of friends new to the area went up the mountain to check out the snow, and ended up stranded for three days. The missed the road closed signs and ended up on Cascade Lakes Highway, which is a snowmobile trail in the winter time.
    https://www.youtube.com/watch?v=FeLoUOpbZqM
  9. Mar 9, 2022 at 7:09 AM
    #429
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
  10. Mar 9, 2022 at 8:23 AM
    #430
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
    came here looking for this... lets hear it... looked like a taco outing with the red taco pulling up before rudi came back
  11. Mar 9, 2022 at 12:23 PM
    #431
    3r3Taco
    3r3Taco Well-Known Member
    So.Cal
    17 SR5 DCSB
    Factory Stock
    Definitely sounded like rods knocking
  12. Mar 9, 2022 at 1:14 PM
    #432
    Maxx
    Maxx Well-Known Member
    Oil catch can would have saved that motor. Another reminder I need to grab one.
  13. Mar 9, 2022 at 1:25 PM
    #433
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers a skewp and a bit of droop
  14. Mar 9, 2022 at 2:50 PM
    #434
    usmc2msu
    usmc2msu Well-Known Member
    TJ
    2017 SR5
    Can this be the result of driving at extreme angles? Starving the engine of oil?
    FirstGenTundra, mauctopa and henryp like this.
  15. Mar 9, 2022 at 2:53 PM
    #435
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    Dude you really gotta not be paying attention to miss that road closed sign. They literally gate the road shut with giant stop signs across it. Then in winter once the gate is covered in snow you have about a 10 foot snow bank to get up off the road onto the snow unless you pull into the snowpark and drive up the snowmobile trails and that's far from accidental...
    The dumpster fire is over here:
    https://www.tacomaworld.com/threads/another-blown-engine-m-o-r-r.758212/
  16. Mar 9, 2022 at 3:03 PM
    #436
    usmc2msu
    TJ
    2017 SR5
    Thanks!
    QUOTE="plurpimpin, post: 27026148, member: 60895"]Dude you really gotta not be paying attention to miss that road closed sign. They literally gate the road shut with giant stop signs across it. Then in winter once the gate is covered in snow you have about a 10 foot snow bank to get up off the road onto the snow unless you pull into the snowpark and drive up the snowmobile trails and that's far from accidental...
    https://www.tacomaworld.com/threads/another-blown-engine-m-o-r-r.758212/[/QUOTE]
  17. Mar 9, 2022 at 3:28 PM
    #437
    mauctopa
    mauctopa Well-Known Member
    Yes and on top of that it floods the engine with oil and hydrolocks. This engine like the rest of the truck isn't meant for off roading.
    usmc2msu[QUOTED] likes this.
  18. Mar 9, 2022 at 5:35 PM
    #438
    usmc2msu
    TJ
    2017 SR5
    I guess it really depends on what people define as off-roading. But yeah, if I buy a truck which has the name off-road in it, it better be able to do off-roading.
  19. Mar 9, 2022 at 6:30 PM
    #439
    mauctopa
    Its all marketing, geared high, weak suspension, weak frame, t-case 2.28, no room for bigger tires, bad approach and departure angle, etc.... Its ok for SR and SR5 but for TRD-Off road and TRD-Pro they should have improved on those things.
  20. Mar 10, 2022 at 7:11 AM
    #440
    desertdog71
    desertdog71 New Member
    mike
    1990 toyota truck 4x4
    headers..bigger pipes...31's...
    AAA doesn't cover off road recovery because of liability/damages...Matt performs these difficult recoveries and assumes the increased liability himself, he services and satisfies AAA customers and in turn AAA sue's him....total BS...As a 25 year AAA customer I'm pissed at AAA....feel like cancelling it.
