Matt Gecko LED truck cap lighting
Discussion in 'Lighting' started by mavrick6382, Feb 10, 2020.
  1. Feb 10, 2020 at 10:51 AM
    mavrick6382
    mavrick6382 [OP] Well-Known Member
    2017 Tacoma SR5, DCLB, MGM
    Icon ext. travel coilovers Icon 2.0 VS rear reservoir shocks Deaver Expo leaf springs Total Chaos Upper Control Arms P285/75R17 Toyo Open Country ATII Method NV A.R.E. Z-Series Front Runner Slimline II WeatherTech floor mats Clazzio leather seat covers De-badged
    I recently added some LED lighting to my truck bed shell and thought I’d post up the details.
    Vehicle: 2017 SR5 DCLB
    Camper Shell: ARE Z-Series
    Lighting: Matt Gecko LED set me up with the following kit:
    1.) Cool White LED's: 48" LED strip - 12" wire harness - 36" LED strip - 12" wire harness - 48" LED strip - 36" wire harness
    2.) Remote option pre-wired to bed switch
    3.) Quick disconnect plug
    The “standard” setup is to either adhere the LED strips to the underside of the bed rails OR use Velcro to stick the strips to the interior carpet headliner of the cap. I didn’t like either setup so I decided to utilize the frames of my camper shell windows. The LED strips Matt sells are 10mm wide and that fit perfectly on the shell’s window frames. The left/right windows have 4’ long strips, and the front window has a 3’ strip. Matt took care of wiring up connector harnesses (12”) in between each light strip. All I had to do to start the install was unroll the lights and stick them on.
    The actual install was fairly straight forward. Matt gave me 3’ of extra wire off the right light strip. I ran that wire through .25” split loom and then cut it to connect to the harness. I then ran the rest of the wire (again in split loom) through a 3/8” hole in the side of my truck bed (see below).
    Next up was to install the push-button switch. I opted to install mine in the location pictured below. The backside of this location is the right rear taillight cavity, which gave me a nice open space to hide all the wires. There is also a plate back there that works perfectly as a ground wire mount location.
    Next up was the actual wiring of the remote module, push button, ground wire, etc. I won’t be getting into that here as Matt Gecko LED provides a wiring diagram and instructions for install.
    Top Arrow = ground wire
    Right Arrow = Wiring from LED lights in truck bed
    Bottom Left Arrow = Wiring from harness to battery
    Last up was to run the wires from the taillight location to the battery. Matt Gecko’s instructions denote running the wires along the passenger side of the truck. I opted to run the down from the right taillight, across the back of the truck, and then along the driver’s side. There is a factory wire loom running along that route and was thus easier to zip-tie the LED loom to that.
    Wire coming out of the taillight cavity
    Wire running across the back of the truck, following existing harness
    Wire following the existing wire loom on the driver’s side
    Just run the wire along the driver’s side and then up into the engine compartment. Connect to the battery and you’re good to go.
  2. Feb 11, 2020 at 4:24 PM
    Tacospike
    Two Trucks
    Nice write up buddy
  3. Sep 22, 2024 at 1:33 AM
    KB09TRD
    KB09TRD Active Member
    Kyle
    2017 DCLB TRD Sport
    Are you still happy with the location of the lights versus on the roof? I just got some lights from Matt and considering doing this same thing. Still plenty bright enough to see everything in the bottom of the bed?
  4. Sep 22, 2024 at 5:47 AM
    mavrick6382
    Yeah I like it. It’s suited me well for years. If you are planning to use some sort of bed platform, however, then you may want to consider lighting down low.
  5. Sep 24, 2024 at 8:17 AM
    KB09TRD
    Kyle
    2017 DCLB TRD Sport
    Thanks! I set mine up the same way and I’m very happy with how it is set up.
  6. Sep 24, 2024 at 8:17 AM
    KB09TRD
    Kyle
    2017 DCLB TRD Sport
  7. Sep 24, 2024 at 8:25 AM
    mavrick6382
    Nice! Looks great
  8. Oct 17, 2024 at 4:00 AM
    Coopsdaddy
    Coopsdaddy Well-Known Member
    Quinton
    2012 dclb tacoma
    6112/5160 Deaver stage 1 Are topper Steelies,255/80/17
    Do you ever use the red?
    Ever wish you could turn light on if just opening one side door?
    I’m having my topper made now and chose no lights because I figured these would be better and I can tailor to my needs.
