Matte Black KMC XD Addict 17x9 wheel/tire question
Discussion in 'Wheels & Tires' started by Motorjock 721, May 9, 2010.
  1. May 9, 2010 at 8:56 AM
    Motorjock 721
    Motorjock 721 [OP] Well-Known Member
    Wylie Texas
    2018 TRD Sport double cab 2wd inferno
    None yet
    Grettings from Texas,
    Ok, Here is the deal. I have a 2009 2wd Prerunner double cab ( TRD Off road package with the 16'' wheel/tires). I plan on upgrading to 17'' wheels and tires. I do not have or plan on getting a lift or level kit.
    I am wanting to go with KMC XD Addict wheels ( matte black) in 17x9, 6x5.5, -12 offset, 4.53 backspace. I also plan on getting 265/70/17 tires, havent decided on what brand yet.
    My question to all the Guru's out there, going from my old 16'' to this 17'' wheel and tire combo, will this work?
    Thanks everyone
    AB
  2. May 9, 2010 at 9:01 AM
    THROUGHITALLDUDE
    THROUGHITALLDUDE Someone didnt put the tailgate down!
    Jeff
    Southern California
    2005 Silver Tacoma
    285-75-17 Definity ATs - 16'' Chrome Moto Metal 951s - 4'' Maxtrac spindles - Rear Icon Progressive Leaf Pack - Magnaflow exhaust - Aftermarket LED Taillights - BHLM - Custom Wet Okle Seat Covers - Moog Tire Rods - US Spec Ipod - K&N High Flow Filter - Daytime Running Lights - TRD Skid Plate - Grillcraft - Hellas Mounted behind the grill
    you will have no problem making the size switch just make sure you calculate what size tire to get since you plan on not lifting so theres not insane amounts of rubbing use this http://www.tacomaworld.com/forum/wheels-tires/12697-tire-size-tool.html this will help you figure out how much of a difference a larger tire or wheel etc. will be but i do know the newer sport tacomas come with 17's instead of 16's so youll be fine
  3. May 9, 2010 at 9:02 AM
    tim920
    tim920 Never seen Forest Gump
    Tim
    Boston, MA
    2005 4Runner Limited V6
    Yes, they'll work. I just did that. I went from 16" to 17" wheels. Mine was a 4.5 backspacing with -10 offset. I have Goodyear Duratracs 265/70/17 and they rub. I believe (and was told) the reason why they're rubbing is because of the after wheel. The backspacing and the negative offset pushes the tire out past the fender a little and I guess that's why it's rubbing against the mudflaps. I removed my mudflaps and now it rubs less. I guess the next thing to do is to get either bilsteins or some other type of lift to raise it at least an inch to two.
  4. May 10, 2010 at 11:17 AM
    Motorjock 721
    Wylie Texas
    None yet
    Ok,
    I just got off the phone with NTB in reference with the wheels and tires. The 17x9 Addicts that are listed on the website that will fit my truck are listed as 17x9, 6x5.5 with a +18 mm offset. They dont list a backspace spec. With the 265/70/17 tire, is this going to rub at all with no lift????? Sorry to keep askin. Thanks
  5. May 10, 2010 at 11:29 AM
    tim920
    Tim
    Boston, MA
    I think all companies/vendors will say that you would need a positive offset with those wheels. The reason is because of what I tried to explain....the tires will be sticking out if you went with a -12 offset. I think NTB would want you to buy the XD Addicts with a +18 offset so that the tires will not be sticking out pass the fenders.
    You now have the option of choosing the -12 or +18.
    Do you want the tires to stick out past the fender about maybe an inch or do you want to make sure you don't stick out at all?
    My wheels is 17x9 with 4.5 backspacing -10 offset ( with 265/70/17 Goodyear Duratracs). My tires rub a little because of the negative offset. NTB wants to make sure you don't rub so they're telling you to get a positive offset.
  6. May 10, 2010 at 12:05 PM
    Motorjock 721
    Wylie Texas
    None yet
    The lightbulb just came on !
    Thanks for the explanation. I dont really want to have my tires/wheels extending or rubbing, so what you have told me and I understand now is that I am good to go.
    I appriciate your time to respond.
  7. May 10, 2010 at 1:01 PM
    tim920
    Tim
    Boston, MA
    I don't know if you plan on buying online but the cheapest place that I found for XD Monsters (this was what I wanted at first) was at http://www.rimzoneonline.com/
    The XD Addicts would come out to a little under $600 including shipping. Maybe you can call them for a tire & wheel package type of deal.
  8. May 10, 2010 at 1:26 PM
    Motorjock 721
    Wylie Texas
    None yet
  9. Feb 18, 2011 at 2:05 PM
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    Price is now $159 each, free shipping. That's the best price I've seen for XD Addicts.
  10. Jul 10, 2012 at 9:17 AM
    TacoPat08
    TacoPat08 New Member
    patrick
    lacey washington
    n/a
    n/a
    hey motorjock.
    did you go with 17"addicts with -12offset or 18 offset? Im thinking of doing the same set up. 17" addicts -12 offset and 4.5 backspacing on a 265/70/17. not planning on getting aa lift either.
