MatthewMay1's SUPERCHARGED Build Thread
Discussion in '1st Gen. Builds (1995-2004)' started by MatthewMay1, Dec 8, 2014.
  1. May 16, 2016 at 8:25 PM
    #821
    Holy schmidt
    Holy schmidt Well-Known Member
    Wyatt
    Nebraska
    Buy the leaf pack then worry about tires when you can afford them? :notsure:
  2. May 16, 2016 at 8:25 PM
    #822
    cbechtold
    cbechtold IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    I meant either buy tires or a new leaf pack. New tires and wheels will run you $1500 -$2000 easily, depending on what you go with. Suspension will be the better bet for now.
  3. May 16, 2016 at 8:26 PM
    #823
    MatthewMay1
    MatthewMay1 [OP] I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    I also don't have $400 right now. Just spent that much on brakes.
  4. May 16, 2016 at 8:26 PM
    #824
    MatthewMay1
    Matthew
    Lone Star Republic
    Not going to be getting new wheels. I like the stock ones. I'll be going with a 255 tire, so I shouldn't need any different amount of backspacing.
  5. May 16, 2016 at 8:28 PM
    #825
    cbechtold
    Cory
    Pleasanton, CA
    Since when do people like the stock rims? :confused::puke:
  6. May 16, 2016 at 8:28 PM
    #826
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
  7. May 16, 2016 at 8:29 PM
    #827
    MatthewMay1
    Matthew
    Lone Star Republic
    :notsure: But I like mine with the satin finish. The only other wheels I would want are SCS F5's and those aren't exactly cheap
  8. May 16, 2016 at 8:29 PM
    #828
    MatthewMay1
    Matthew
    Lone Star Republic
    Thanks for the input. I've never looked at it before so I don't know how it used to be
  9. May 16, 2016 at 8:29 PM
    #829
    AR15xAR10
    Tight.
  10. May 16, 2016 at 8:30 PM
    #830
    MatthewMay1
    Matthew
    Lone Star Republic
    Well one can assume so. But I don't know if it has gotten significantly worse lately or not
  11. May 16, 2016 at 8:30 PM
    #831
    Holy schmidt
    Wyatt
    Nebraska
    I meant do that before tires since they look fine for now. An aal if just money down the drain if you are going to a leaf pack anyways
  12. May 16, 2016 at 8:31 PM
    #832
    MatthewMay1
    Matthew
    Lone Star Republic
    True... TW spending my money I don't have again...
    Holy schmidt[QUOTED] likes this.
  13. May 16, 2016 at 8:31 PM
    #833
    AR15xAR10
    The lift angle change will have put some strain on it. Probably enough to create that play you found. Don't know if that is your problem though.
  14. May 16, 2016 at 8:32 PM
    #834
    AR15xAR10
    I did suspesnion first...
    Now saving for wheels AND tires
  15. May 16, 2016 at 8:32 PM
    #835
    cbechtold
    Cory
    Pleasanton, CA
    Ehh... $150 isn't bad. I was looking at the TR Beadlocks for the longest time. Though spending $1300 on rims was not really worth it to me at the time. I'll do the TR Beadlocks when I SAS the truck. :cool:
  16. May 16, 2016 at 8:32 PM
    #836
    MatthewMay1
    Matthew
    Lone Star Republic
    Hmm. The problem has just come up within the past month or so. My lift has been on much longer than that. Not to mention that it's sagging like an old woman's tits now.
    cbechtold likes this.
  17. May 16, 2016 at 8:34 PM
    #837
    cbechtold
    Cory
    Pleasanton, CA
    lol :rofl:
  18. May 16, 2016 at 8:37 PM
    #838
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Go for a blem set
  19. May 16, 2016 at 8:38 PM
    #839
    MatthewMay1
    Matthew
    Lone Star Republic
    I could... But there's no issue with my current wheels! I see no reason to switch them out. That's money that would be better spent elsewhere IMO
    Holy schmidt likes this.
  20. May 16, 2016 at 8:38 PM
    #840
    cbechtold
    Cory
    Pleasanton, CA
    LEAF PACK OMG :anonymous:
