MatthewMay1's SUPERCHARGED Build Thread
Discussion in '1st Gen. Builds (1995-2004)' started by MatthewMay1, Dec 8, 2014.
  1. May 16, 2016 at 8:40 PM
    #841
    MatthewMay1
    MatthewMay1 [OP] I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    I also don't know which pack to get. I really like the flex you get out of Chevy 63's. I don't like the amount of custom work you have to do for them though.
  2. May 16, 2016 at 8:42 PM
    #842
    MatthewMay1
    Matthew
    Lone Star Republic
    If I got Dakars, I'd want to get off of the 5100's too. That would be a good chunk of change for Nirtochargers in the rear also...
  3. May 16, 2016 at 8:42 PM
    #843
    Holy schmidt
    Holy schmidt Well-Known Member
    Wyatt
    Nebraska
    But you dont have to right away. You can do the leafs first then wait
  4. May 16, 2016 at 8:44 PM
    #844
    MatthewMay1
    Matthew
    Lone Star Republic
    True, but I don't like doing that.
    I'm not happy with how my stock springs are toast after only 3 years
  5. May 16, 2016 at 8:49 PM
    #845
    Holy schmidt
    Wyatt
    Nebraska
    It seems they go to they worn level then kinda chill there as mine havent lost any ride height since ive had the truck. With Dakars the nitrochargers limit the droop with the stock shock mounts too right? another thing to consider
  6. May 16, 2016 at 8:52 PM
    #846
    MatthewMay1
    Matthew
    Lone Star Republic
    I will be relocating rear shocks when I get a new pack
    Holy schmidt[QUOTED] likes this.
  7. May 16, 2016 at 8:55 PM
    #847
    cbechtold
    cbechtold IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    Look at what Monte (@Blackdawg) did. He just got a set and took a bunch of leafs out.
  8. May 16, 2016 at 9:03 PM
    #848
    MatthewMay1
    Matthew
    Lone Star Republic
    Took out a bunch of leafs? All you need to do is take out the overload. I just don't like the idea of it being irreversible. And I hear axle wrap is an issue with them
  9. May 16, 2016 at 9:10 PM
    #849
    cbechtold
    Cory
    Pleasanton, CA
    Deaver you can get made custom. OME Dakar is probably the best overall. All Pro Expedition Leafs have the best carrying capacity, but you don't have any weight in the rear. There's always a bit of axle wrap. If minimal axle wrap, then you're looking at getting a traction bar, which I believe you could get one from RuffStuff for not that much.
  10. May 16, 2016 at 9:10 PM
    #850
    Holy schmidt
    Wyatt
    Nebraska
    I thought monte had the wheelers 5 pack wit has extra leafs added? And a wheelers 8 pack on his other truck
  11. May 16, 2016 at 9:13 PM
    #851
    MatthewMay1
    Matthew
    Lone Star Republic
    Is the Dakar pack what you have?
  12. May 16, 2016 at 9:14 PM
    #852
    cbechtold
    Cory
    Pleasanton, CA
    Yes. I'll probably end up getting the AAL soon.
  13. May 16, 2016 at 9:15 PM
    #853
    MatthewMay1
    Matthew
    Lone Star Republic
    How much lift do you have without the AAL?
  14. May 16, 2016 at 9:20 PM
    #854
    cbechtold
    Cory
    Pleasanton, CA
    Right now I'm sitting at ~2.5" of lift, but then factor in the 270lbs of bumper, spare, and bed rack and you realize why I only get that much. When I first did the lift I got ~3.5" of lift and it settled at ~3.25" of lift. The thing about the Dakars is that they're meant to run flat, meaning that they'll barely have any arch to them. I personally love them, but the D43XL adds ~220lbs of carrying capacity, which would be great with how much weight I have on the rear of my truck.
  15. May 16, 2016 at 9:23 PM
    #855
    MatthewMay1
    Matthew
    Lone Star Republic
    Wow, yeah I don't have anything back there. Especially since I don't have the shell on anymore
  16. May 16, 2016 at 9:26 PM
    #856
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Don't forget your 3/8" block lift ;)
    cbechtold[QUOTED] likes this.
  17. May 16, 2016 at 9:27 PM
    #857
    cbechtold
    Cory
    Pleasanton, CA
    Yea. You have the OEM rear bumper and a soft top, which in total probably weighs 3lbs :p The ride though wasn't bad though when I first did it. Little stiff for the first few hundred miles, but after that they were pretty soft. I've also had ~500lbs of gear in the bed with the lift and it was really good. Rear sagged a bit, but it did really well.
  18. May 16, 2016 at 9:27 PM
    #858
    cbechtold
    Cory
    Pleasanton, CA
    ^^^ THIS GUY lol Do get the axle relocation plates from 4crawler. You'll eat your fender if you don't
  19. May 16, 2016 at 9:37 PM
    #859
    MatthewMay1
    Matthew
    Lone Star Republic
    I'd rather it ride stiff than like a boat, which is what it's like now
  20. May 16, 2016 at 9:41 PM
    #860
    cbechtold
    Cory
    Pleasanton, CA
    Soft as in you won't feel EVERY single bump in the road. Dakars keep the rear in control and stable, which is what you'd want. It ain't no Rolls Royce ride, if you thought I implied that. :p
