Max AC Come on Automatically?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoLarry, Jul 18, 2014.
  1. Jul 18, 2014 at 7:03 PM
    TacoLarry
    TacoLarry [OP] Well-Known Member
    Larry
    PacNW
    14 Tacoma DCLB Myca Pyrite 4WD
    2014 DCLB: long freeway driving on a very hot day (97+ degree), I notice very ocassionally the Max AC light will illuminate for varying lengths of time and then go out. Is there an internal sensor to assist the standard cooling, or as I am towing could a hard hill climb draw down the vacuum enough to close a bypass door, or something. All seems to cool OK.
    Thanks.
  2. Jul 18, 2014 at 7:22 PM
    mdcmn7
    mdcmn7 Well-Known Member
    Chuck
    East Coast
    Not sure what the max ac light is?
    My 14 if I switch it to max ac on the dial, the ac light and the recirc light comes on
    Is there another?
  3. Jul 18, 2014 at 7:33 PM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    Did you have it in the defrost mode by chance?
  4. Jul 18, 2014 at 7:43 PM
    TacoLarry
    Larry
    PacNW
    Thanks, I meant the Recirc Light, thinking that it meant the same as if the switch were in the Max AC positiin.
  5. Jul 18, 2014 at 7:43 PM
    TacoLarry
    Larry
    PacNW
    No, either dash vents or dash/floor.
  6. Jul 19, 2014 at 12:58 PM
    miniceptor86
    miniceptor86 Well-Known Member
    Jim
    McGregor,IA
    07 Speedway Blue Prerunner Dbl cab
    TRD sport exhaust and cold air intake, nerf and bull bar, RideRide, ProEFX towing mirrors, BakFlip F1 trifold tonneau
    Max air simply means that air from outside is being draw into the evaporator coil to be cooled. It's meant to be used when first cooling off the interior when the vehicle has been sitting in the sun, the outside air even though hot will be cooler than the interior air. So my guess is that periodically the 'puter tells the ventilation system to air some fresh air to the cabin to dilute the possible beer farts and or body oder and add some O2 to stave off the sleepys caused by higher CO2 levels.
    Calling it "max air" makes as much sense to me as clicking on "start" to turn off your 'puter.
  7. Jul 19, 2014 at 1:07 PM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Wut?
  8. Jul 19, 2014 at 1:28 PM
    JustMe
    JustMe Active Member
    Put down the crack pipe!
  9. Jul 19, 2014 at 1:37 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  10. Jul 19, 2014 at 4:44 PM
    dm1215al
    dm1215al Well-Known Member
    Dan
    Fl
    2014 TRD Offroad 4x4
    Step tubes,Window tint, HomelinK rear view mirror, changed the entune image screen Rear Differential Breather Relocation Extended AC condensate hose KB Voodoo tailgate cap Redline Tuning QuickLIFT ELITE hood lift system.
    Now I understand:confused:
  11. Jul 19, 2014 at 7:23 PM
    mdcmn7
    Chuck
    East Coast
    I always thought max ac meant it turns the ac on and the recirc at the same time because pushing both buttons it too hard and I want heated effing mirrors
  12. Jul 19, 2014 at 7:25 PM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    It does, and me too.
  13. Jul 20, 2014 at 6:20 AM
    TacoLarry
    Larry
    PacNW
    True & I apologize for miswording the title, but is there a sensor that periodically activates the recirc? Driving along in normal that light will very occassionally illuminate without pushing the recirc button.
  14. Jul 20, 2014 at 7:42 AM
    judgeman6970
    judgeman6970 Well-Known Member
    Bob
    Long Island, NY
    you have it backwards.....
  15. Jul 21, 2014 at 9:52 AM
    miniceptor86
    Jim
    McGregor,IA
    I'll stick with my statement with the qualification that that's how it works for some of the vehicles I have had but since there is no industry standard for what "MAX A/C" means your vehicle may be different. My 07 Tacoma does not have a max ac selection.
  16. Jul 21, 2014 at 10:15 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Never have I once seen a vehicle with max a/c option do anything but switch to recirc. It would just make no sense at all, if it didn't. :crazy:
  17. Jul 21, 2014 at 10:34 AM
    ziggynagy
    ziggynagy All Glory To The Hypnotoad
    Stoughton, MA
    '11 Sport AC 4x4 V6 Auto Tow
    Westin step bars, led dome & map lights, tailgate hoseclamp, BluLogic, MetalMiller emblem, 35 tinted front windows, extra OEM d-rings, WeatherTech front/rear
    From the manual regarding MAX A/C: For quick cooling, turn the temperature control dial to the MAX A/C position. The air conditioning will automatically turn on and the air intake selector will be set to recirculated air mode.
    Going back to OP's original question, answer is also in the manual:
    ■ If the ambient temperature drops while using the recirculated
    air mode:
    The air intake mode automatically changes from recirculated air
    mode to outside air mode after a few minutes.
    To cancel this function:
    Press and hold (recirc button) for longer than 2 seconds.
    To reactivate this function:
    Turn the engine switch to the LOCK or ACC position
    Attached the page as a pdf so you can see it. Really wish I could smoke whatever miniceptor is on, but he probably has to free base that shit!
  18. Jul 21, 2014 at 3:52 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Thanks ! did not know that!
  19. Jul 21, 2014 at 7:24 PM
    TacoLarry
    Larry
    PacNW
    That is probably the circuit that derped. Mine was on outside air and automatically switched to recirc (inside air), but only happened a couple of times and very briefly.
  20. Jul 21, 2014 at 10:11 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    If it has ac it does.
