Max bed weight you've had?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2006whitetacoma, Oct 13, 2018.
  1. Oct 14, 2018 at 6:52 AM
    Mongoose
    Mongoose Well-Known Member
    Catskill Mts. NY
    I heat with rice coal and haul it myself, I make 2 or 3 trips per year. This is a picture of one of this years load, it's 2100 pounds, you can see the coal very near the top of the bed. The truck sits level because I installed Air Lift Ride Control air bags Kit #59561 in the rear (@50 psi). I don't advise loading that much weight, it's not legal, but can be done. I only have to drive about 25 miles loaded. 20180924_163701.jpg
  2. Oct 14, 2018 at 8:03 AM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
  3. Oct 14, 2018 at 8:24 AM
    jsi
    jsi Well-Known Member
    native earthling
    Multiple people have said it, I live it. Use a trailer. Here's mine -
    I've had it for 25 years and love the thing. Even when I had a 1 ton dually pickup that could easily handle your load I still chose to use this instead of the bed of my truck.
    Here it is hauling some big ass load of cut sod off to the dump. That much weigh would have flattened the springs on my truck -
  4. Oct 14, 2018 at 9:32 AM
    jross20
    jross20 Well-Known Member
    Georgia
    2000 4Runner SR5 4x4 | V6 | Auto
    Tundra 5100s F+R, OME 880s+890s, duro bumps, etc
    Maybe with some mega leaf springs O.O
  5. Oct 14, 2018 at 9:45 AM
    4drtaco03
    4drtaco03 Well-Known Member
    BAY AREA
    2003 TRD/ 2004 / 2019 SR5 4x4… now awd sprinter
    This is on the original suspension. Prob the Max I would do with the hills and the 4 cylinder in San Francisco. it’s about 600 pounds
    Sweeet spoiler right????
  6. Oct 25, 2018 at 11:14 AM
    gliebig
    gliebig Well-Known Member
    2017 Silver Spark Off Road Ext Cab LB
    I was thinking about hauling a 1ton pallet of heating pellets. Only about 3miles, but sounds making it 2 trips would be smart.?
  7. Oct 25, 2018 at 11:18 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Or rent a trailer. That sort of weight would wreck your springs if you loaded it into the bed, but will tow easily on a trailer.
    I married my tacoma likes this.
  8. Oct 25, 2018 at 12:53 PM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    That shit made me laugh.
  9. Oct 25, 2018 at 1:16 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    This is so random
    Captainskidmark likes this.
  10. Oct 25, 2018 at 2:17 PM
    Captainskidmark
    Captainskidmark Well-Known Member
    Northern Illinois
    2015 4X4 TRD SPORT DCLB ~ Black
    ECGS 4.56 gears with Detroit True Trac in the rear. Camburg Ball Joint UCAs Dirt King LCA Dobinson IMS rear shocks Dobinson IMS w/ 352 coils DAKAR EL096 HD LEAFS AR172 17"x8" BAJA RIMS (5 wheel/tire rotation) GX470 Front Brake Upgrade SS extended brake lines Front and Rear (Toytec) 285/70/17 BFG A/T Toyota Roof Rack over Cab A.R.E. Z series CAP with Rhino Rack rooftop rails , -RED/WHITE LED BED LIGHTING -12V AUX POWER AND USB MAGNAFLOW CAT BACK RAAMmat Sound Abatement Pioneer AVH-2440NEX w/ Android Auto + Morel Speakers 120 VAC Block Heater Pelfreybilt Front/Mid Skids ATH Bed Braces ATH FRONT BUMPER - FULL LOOP BAJA DESIGNS FOGS HERETIC 20" LIGHT BAR ATH REAR BUMPER - STANDARD RIGID FLUSH MOUNT REVERSE LIGHTS Weathertech floor mats Rear Diff Breather Mod Wheeler's Super Bumps + Ubolt Flip Kit ABS Kill Switch Mod Northstar AGM Battery Pedal Commander Desert Does It Seat Spacers
    Dkurtz42, Tn Jeff, uurx and 2 others like this.
  11. Oct 25, 2018 at 2:49 PM
    jsi
    native earthling
    And how exactly was he planning on getting the boulder out of the truck? Yeah - don't be that guy
  12. Nov 7, 2018 at 1:11 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    550lbs of useless crap around the house.
    27F8AEF1-96A8-497C-AE80-F271AE96C698.jpg EDA50964-234B-44ED-9C6A-CB21429E4F54.jpg
    b_r_o likes this.
  13. Nov 7, 2018 at 1:17 PM
    TacomaMike37
    13' DCLB MGM
    I think a homeless guy was squating in your truck
  14. Nov 7, 2018 at 1:21 PM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    I’ve put about 1,500-1,600lbs in the bed at one given time.
    Payload is around 1,100lbs WITH all passengers and anything in the truck.
    I have towing and hauling experience. I’ve moved 4,000lbs in the bed of a diesel.
    I would not move 2,000lbs in the Tacoma. #1 any company you buy the stones from should not let you leave that overweight. #2 speeds over 50mph your probably going to be doing some swaying.
    You’ll trash your leaf springs and just be a massive liability. You’ll be on your bump stops at 1300-1400lbs.
    But you’ll hit a woman a call her a crack whore so maybe your judgement is different than mine...
    b_r_o likes this.
  15. Nov 7, 2018 at 1:29 PM
    #35
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
  16. Nov 7, 2018 at 1:37 PM
    #36
    Noelie84
    Noel
    Wales, Maine
    Had a couple of moderately heavy loads when I had my Tacoma, but nothing excessive.
    Bricks:
    Some Swamp Maple:
    I never really overloaded it, though, because I've always used the work truck for the actual work. Holds more and handles it better.
    And now I've got a 3/4 ton, so that gets the 'heavy hauling' assignments by default. :notsure:
    That being said, at around 1200lbs my Tacoma was always resting pretty firmly on the bump stops.
  17. Nov 7, 2018 at 1:56 PM
    #37
    Mad4268
    Mad4268 Active Member
    Erie, PA
    06 Blue Tacoma TRD-OR 6-Spd STD
    I recently hauled a ton of wood pellets in my '17 Tacoma rental (my '06 is in shop getting frame replaced) and I still couldn't bring myself to go over the payload rating lol. Did it in 2 trips.
  18. Nov 7, 2018 at 3:36 PM
    #38
    jsi
    native earthling
    Not the maximum load I've ever carried, but certainly the maximum value. IMG_6426.jpg
  19. Nov 7, 2018 at 3:58 PM
    #39
    smithe3006
    smithe3006 Member
    Pittsburgh
    2015 magnetic gray trd sport
    hahaha sadly I can relate to this...
    OP, I’d probably find a trailer. One time I overloaded a tundra by about 800lbs of wood. Nothing bad happened so you’re probably good right?
  20. Nov 7, 2018 at 5:25 PM
    #40
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
