Max extended droop specs for 2nd gen?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by memario1214, May 26, 2016.
  1. Nov 14, 2016 at 6:42 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    I gained 2" of droop/travel with LR UCAs and extended travel Fox 2.5s up front. Didn't measure the gains in the rear with the Dakar pack with 3rd leaf removed but it's close 6" if not more.
    Pics of the rear here
    stickyTaco's eff cancer build and ramblings
  2. Nov 14, 2016 at 9:26 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I looked uo the specs on them some time ago. I believe so.
  3. Nov 15, 2016 at 9:43 AM
    urban
    urban Well-Known Member
    Illinois/Michigan
    12 DCLB sport OME lift
    305/65r17's on 17x9.5 Rotiforms Cab mount chop 4.10 gears Detroit true track OME 885's Dakars Camburg UCA's Undercover SE Weathertech liners and visors Black headlight mod Debadged Rock Blokz mudflapps (oversized)
    Those are still good and fine even with tyne stock UCA I think. that's the same shock on the trd pro's. are you sure 22 extended shock length is as much as can be done before limiting straps are needed?
  4. Nov 15, 2016 at 12:11 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Depends what UCA you run, but regardless if you are running extended travel shocks, coilovers, whatever, in the front you are going to want limiting straps. You don't want to damage your balljoint or uniball cage, or misalignment spacers (for uniball equipped trucks).
    I'd rather max out suspension travel before shock travel, but if you want to be able to max it out safely without causing any damage, limiting straps should be installed in place as a safeguard.
  5. Nov 15, 2016 at 12:26 PM
    Pigpen
    Dan
    Northwest Montana
    Full droop with 5100s, 885 coils, and LR UCAs puts my CVs and tie rod ends at angles that makes me nervous.
