Max lift without drop bracket
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 03f5sp, Dec 2, 2012.
  1. Dec 2, 2012 at 2:01 PM
    03f5sp
    03f5sp [OP] Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    What's the biggest lift lift possible without any major problems or drop brackets on a 4wd? V6 dcsb
  2. Dec 2, 2012 at 2:04 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    ~ 3inches unless you go LT then maybe 4.
  3. Dec 2, 2012 at 2:13 PM
    BakerTaco
    BakerTaco Well-Known Member
    Will
    Lower Alabama
    2006 4x4 SR5
    Black UWS Toolbox, Window Tint, Weathertech mats, OME lift: 885x coils, top plate spacer, OME shocks all around, 2 inch AAL driver side trim packer, Toytec diff drop, Grillcraft, Colormatched grille, CHLM, 6000k HIDs - headlights and fogs, Smittybilt shackle hitch, ARB snatch strap, Pioneer avic x940bt headunit,
    6.. With a 3" suspension lift and an ugly ass body lift
  4. Dec 2, 2012 at 2:26 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Fixed that for you.
    Been more than one posting related to the cab bolts shearing off in an accident and pitching the cab.
  5. Dec 2, 2012 at 2:31 PM
    Gotcha88
    Gotcha88 Well-Known Member
    CA
    2012 DCSB PreRunner TRD Sport
    Bilstein 5100s all around, Toytec Eibach coils, Toytec 1.5" AAL, Light Racing UCAs, 285/70r17 Nitto Terra Grapplers, 17x9 Eagle 185s, 20% tint all around, Magnaflow 11256, Cobra CB with 2' Firestik, De-Badged, BHLM, UltraGauge, K&N Drop-in, OEM Bed Mat, OEM All-Weather Mats.
    :eek:
  6. Dec 2, 2012 at 2:42 PM
    BakerTaco
    Will
    Lower Alabama
    2006 4x4 SR5
    x2 damnnn
  7. Dec 2, 2012 at 4:20 PM
    03f5sp
    Bill
    Wisconsin
    Anyone else? I'd think with long travel you could get at least 5" and still have enough down travel.
  8. Dec 2, 2012 at 4:23 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    long travel is a completely different suspension system, not a "lift" so that doesnt count
    3"
    anything above that = shit ride, and will make your parts shit quicker
    I had my eibachs/5100's installed accidentally at 2.5 on top of the coils, so I was running 5.5+ in the front for a week
    rode like shit
    both my cv boots blew the week after
  9. Dec 2, 2012 at 6:44 PM
    03f5sp
    Bill
    Wisconsin
    I know LT is different than a lift, but because LT has so much more travel i don't see why you couldn't use some of that extra travel to make the truck sit taller.
  10. Dec 2, 2012 at 6:48 PM
    95 taco
    95 taco Battle Born
  11. Dec 2, 2012 at 6:49 PM
    BakerTaco
    Will
    Lower Alabama
    2006 4x4 SR5
    You can't do spindles so just stick with three-ish inches or go to a drop bracket
  12. Dec 2, 2012 at 6:51 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    CV angles are CV angles though.
    If you exceed a static lift equivalent angle of 3", it's the same as cranking the stock front end.
    You can get a little more than 3"... but it's healthier for the CVs to keep it down.
  13. Dec 2, 2012 at 6:53 PM
    DevL
    DevL Well-Known Member
    If you do long travel you can go infinitely high as you go infinitely wide. Its not a reasonable comparison. The answer you are looking for is 3".
  14. Dec 2, 2012 at 6:55 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    That kinda defeats the purpose of having LT. You're better off with a 3" mid travel set up.
  15. Dec 3, 2012 at 2:29 AM
    03f5sp
    Bill
    Wisconsin
    Good point, I didn't think of that.
  16. Nov 14, 2016 at 11:09 AM
    urban
    urban Well-Known Member
    Illinois/Michigan
    12 DCLB sport OME lift
    305/65r17's on 17x9.5 Rotiforms Cab mount chop 4.10 gears Detroit true track OME 885's Dakars Camburg UCA's Undercover SE Weathertech liners and visors Black headlight mod Debadged Rock Blokz mudflapps (oversized)
    Obviously the more angle the more the cvs have to bend as they rotate but as far as I understand the big thing is damaging the boots. If you stretch the boots, exactly how bad is it for the CVs? like just not ideal or will fail and how much over 3 can you push with stretched boots?
