Max Tire Size On My Taco With Lift?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ryank 5, Nov 30, 2011.
  1. Nov 30, 2011 at 9:01 AM
    ryank 5
    ryank 5 [OP] Well-Known Member
    Jefferson County, PA
    2006 Radiant Red Taco - Access Cab 4WD TRD
    OME Dakars, OME 884's, 5100's all around (0" setting), SPC UCA's, 17" 4-Runner Trail Edition Wheels with Dynapro's, ABS Killswitch Mod, Extang Tonneau
    Hello everyone,
    I have an 06 tacoma and I was wondering what the maximum tire size is with a rough country lift shown here http://www.roughcountry.com/toyota_4wd_tacoma_3.html
    I don't want to do any trimming. I just want to know what I could fit without doing anything to it. Also, how much would the tires stick out of the fender flares? We have laws in P.A. that say they can't stick out more than a couple inches.
    Thanks!
  2. Nov 30, 2011 at 9:03 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    265x75r16 or 265r70r17
    With no trimming.
    Ps. Save your scheckles and clams and get a real lift. Blocks and spacers are crap.
  3. Nov 30, 2011 at 9:04 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    Will you be running aftermarket wheels?
  4. Nov 30, 2011 at 9:11 AM
    ryank 5
    yes i am. what difference will this make?
  5. Nov 30, 2011 at 9:17 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    How far the tires will stick out. Stock rims with the sizes I mentioned will fit perfect. Throw on aftermarket rims and now the backspacing might push them out. And fucking with the backspacing will also possibly contribute to rubbing.
  6. Nov 30, 2011 at 9:17 AM
    TacoSupreem
    Hayden
    Kentucky
    Edit: Read the post wrong!
    what is the spec's on your wheels? Is your truck a trd or sr5?
  7. Nov 30, 2011 at 9:18 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    You're funny.
  8. Nov 30, 2011 at 9:18 AM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Yes. We know that, don't we. I had to go DOWN a tire size. :(
  9. Nov 30, 2011 at 9:23 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Put a lift on. Then tell curbs to kiss your ass
  10. Nov 30, 2011 at 1:48 PM
    ryank 5
    It's a trd. And it has the stock wheels, which i believe are 16x7. What's the widest (in inches) do you think i could get without rubbing? and krazie, i've been looking for some good lifts. i just don't want to pay a couple grand for them. any suggestions?
  11. Nov 30, 2011 at 2:12 PM
    Dustyroades
    Dustyroades Well-Known Member
    London, Ontario
    2019 TRD Sport
    Tons of options out there, search the suspension forum. One of the most popular/best value for money is Bilstein 5100s with an AAL for $400-500. Check out Toytec's website for more info.
  12. Nov 30, 2011 at 2:17 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Billie 5100. You can dial them up to 2.5" if you want with stock coils.
    I'm partial to OME cause it's what I have on my truck. 2.5"-3" of lift. Front shocks and coils will run you under a grand easy. Probably closer to 800. But I can promise you, if you get blocks, you're going to upgrade to shocks/coils eventually. Why waste the money? Buy the good stuff the first time.
    But no rubbing even with a lift the biggest you can go is a 32" tire. If you go larger chances are very good you'll rub. I do. But I don't care. :p
  13. Nov 30, 2011 at 2:36 PM
    ryank 5
    got any links for bilstein lifts?
  14. Nov 30, 2011 at 2:48 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Toyteclifts.com
    Downsouthmotorsports.com
    Wheelersoffroad.com
    Check out the vendor section on this site, some of them offer discounts to members.
  15. Nov 30, 2011 at 3:14 PM
    ryank 5
    what all will i need? 5100's in the front and in the back? AAL?
  16. Nov 30, 2011 at 3:49 PM
    Dustyroades
    London, Ontario
    2019 TRD Sport
    Yup. The add-a-leaf gives you the lift in the back as the rear shocks are not height adjustable and do not provide lift.
    Be aware though that some have had issues topping out their rear 5100s offroad. OME N182s are a good, similarly priced alternative for the rear.
  17. Nov 30, 2011 at 4:37 PM
    Smirky
    Smirky Active Member
    Orlando, FL
    4x4 TRD Sport
    Work in progress
    I'm lifting my 07 dbl cab sport this weekend with the Toytec 3" lift and adding 1.25" Sydertrax wheel spacers so I can clear the UCA's w/o swapping out the stock 17" wheels just yet. Can anyone confirm that the BFG AT's 275/70/17 will fit ok? They are special order, not sure why but the 285's are too wide and don't want to settle for the 265 width, what do you think??
  18. Nov 30, 2011 at 7:16 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Should be fine. That's a 32" tire. If you have a genuine 3" of lift in the front you'll clear that real easy.
  19. Nov 30, 2011 at 10:48 PM
    csjumper2003
    csjumper2003 Jumper's Leds Vendor
    Savannah, GA
    2014 SSM Trd Off Road 4x4 Auto
    Sorry for the thread jack
    im confused I thought that the 285 is the heighth? and so a 285/75 is 2 inches higher than the 265/75, and the ratio is the 75 between heighth and width?
  20. Dec 1, 2011 at 4:00 AM
    Smirky
    Orlando, FL
    4x4 TRD Sport
    Work in progress
    I believe the 285 is 20mm not 2inches wider than the 265 and the 70 is the height/width ratio
