MAX tire size with 3in lift
Discussion in 'Wheels & Tires' started by x2Kawa, Aug 11, 2010.
  1. Aug 11, 2010 at 6:59 PM
    x2Kawa
    x2Kawa [OP] Member
    Taylor
    Houston, TX
    Hey guys I was wondering if anyone knows the max tire size i can put on my double cab 2007 with a 3in toytec lift 2WD. Would prefer zero to minimal rubbing.
  2. Aug 11, 2010 at 7:01 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    265/75/16 no rubbing
    285/75/16 with some fender wheel trimming and without proper wheel a cab mount chop
  3. Aug 11, 2010 at 7:10 PM
    AriZonaD54
    AriZonaD54 BANNED in 49 states...
    Andrew
    Valley of the Sun
    295s with lots of trimming
    305s with lots of trimming and cab mount chop
  4. Aug 11, 2010 at 7:12 PM
    x2Kawa
    x2Kawa [OP] Member
    Taylor
    Houston, TX
    Could you explain "proper wheel a cab mount chop" ? and how far out would the 285 stick out?
  5. Aug 11, 2010 at 7:14 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    315 with so much trimming and cab chop to the max and then still additional rubbing
  6. Aug 11, 2010 at 7:29 PM
    08pretaco
    az
    proper wheel. cab mount chop. 2 seperate things. cab mount chop is what your cab mounts to on the frame. proper wheels meaning backspacing, offset and such
  7. Aug 11, 2010 at 7:33 PM
    x2Kawa
    x2Kawa [OP] Member
    Taylor
    Houston, TX
    Ok I found the cab mount chop thread, what would be the proper back spacing?
  8. Aug 11, 2010 at 7:33 PM
    x2Kawa
    x2Kawa [OP] Member
    Taylor
    Houston, TX
    and does anyone have pictures of the trimming?
  9. Aug 11, 2010 at 7:34 PM
    08pretaco
    az
    whatever you think. I think with anything smaller than 285 maybe 295/75/16 4.5 BS should be ok but if you go any wider than that then 4" or less and definetly a wider than 8" rim.
  10. Aug 11, 2010 at 7:39 PM
    08pretaco
    az
  11. Aug 14, 2010 at 1:11 AM
    x2Kawa
    x2Kawa [OP] Member
    Taylor
    Houston, TX
    so for a 285/75/16 what would be the right wheel size and BS?
  12. Sep 21, 2010 at 3:09 PM
    x2Kawa
    x2Kawa [OP] Member
    Taylor
    Houston, TX
  13. Sep 21, 2010 at 3:20 PM
    mj918
    mj918 Well-Known Member
    Meg
    Wyoming
    2012 TRD Off Road Sliver
    3" Toytec Ulitmate Lift 285/70 Wrangler Duracturs 17" American Racing wheels TRD SUPERCHARGER!!! :) TRD Catback to come . . .
    I just got a 3" Toytec lift, and have 285/70/17 BFG AT's. My wheels have a backspacing of 4.75" and a 0 mm offset. I had some minimal trimming done on the plastic inside the fender and my front mud flaps. There is hardly any rubbing. I think it was good fit.
  14. Sep 21, 2010 at 3:24 PM
    x2Kawa
    x2Kawa [OP] Member
    Taylor
    Houston, TX
    awesome do you have any pics of it?
  15. Sep 21, 2010 at 3:28 PM
    mj918
    Meg
    Wyoming
    Ah soon, very soon. Hopefully post some tonight or tomorrow. If you read around the threads, the magic number for backspacing is 4-4.5", so I was worried about the wheels I chose, but everything workout better than I could imagine. Surprised on how sharp I can still turn without it rubbing!
  16. Sep 21, 2010 at 3:32 PM
    x2Kawa
    x2Kawa [OP] Member
    Taylor
    Houston, TX
    You didn't even have to do a cab mount chop?
  17. Sep 21, 2010 at 3:52 PM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    Me and a few other members have 315/75/16's on 3" of lift. A lot of chopping was involved to make them fit though.
  18. Sep 21, 2010 at 3:58 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Prolly 6 on 5.5, 16x8, 4.5" backspacing, 0 to -5 offset.
  19. Sep 21, 2010 at 4:00 PM
    mj918
    Meg
    Wyoming
    Nope I didnt! Minimal trimming thats all :D
  20. Sep 21, 2010 at 4:56 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Which I take to mean that you rub if you turn all the way lock to lock?
