Max tire size with leveling kit?
Discussion in '1st Gen. Tacomas (1995-2004)' started by CUtigerfan, Jul 12, 2009.
  1. Jul 12, 2009 at 11:06 AM
    CUtigerfan
    CUtigerfan [OP] Well-Known Member
    South Carolina
    04 Base
    Daystar 1.5" coil spacers, bedlined bumpers, clear corners, aftermarket stereo, 20% tint, half debadged
    does anybody know what the biggest tire size that can be run on a base model truck with just a 1.5in. leveling kit? I want to go ahead and replace the tires on it now and put big enough tires that I won't have to replace again when I get the money for a lift. I really would like to get 29-30inch tires on it but 30 sounds optimistic. it would fit in the wheel well no prob but I know it will probably rub. (looking to put 15in. american eagle series 101s with Toyo Open Country AT) also Fabtech lift I want says to run bigger tire backspace on rim has to be 3.75in. or less
  2. Jul 20, 2009 at 8:02 PM
    blkcoma32
    blkcoma32 Well-Known Member
    Illinois
    98' 4x4 on tirty trees
    3 inch coilover and add-a leaf lift
    u should not have a problem fitting 31s even stock
  3. Jul 20, 2009 at 8:06 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    He has a 5 lug, I would say 29 is probably the biggest you should go.
  4. Jul 31, 2009 at 4:06 PM
    CUtigerfan
    South Carolina
    04 Base
    Thanks for the responses! was wondering for a while if I was the only one who ended up buying a 5 lug tacoma. so according to WhatThePho? 29s will fit with just the 1.5" leveling kit anybody wanna second that or offer any other advice?!?
