Max tire with 2.5" F / 2" R lift
Discussion in 'Wheels & Tires' started by adavis22, Jan 13, 2010.
  1. Jan 13, 2010 at 11:34 AM
    adavis22
    adavis22 [OP] Member
    Allen
    Texas
    TRD Sport 4X4
    Hey guys, I'm pretty new here. I've recently installed a 2.5 inch front 2 inch rear lift on my 09 TRD sport 4x4 dbl cab taco. I'm looking at the Toyo Open Country ATs. I can't decide on the 285/70R17s (~33) or the 275/65R17s (~31.somethings). Comes stock with 30's i think. Anyway, if i go with the larger, wider tire, will it rub? Not sure here, and don't want to order em and find out the hard way.
    thanks. I'll post some before and after pics soon.
  2. Jan 13, 2010 at 3:11 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    Most 285's will rub. I believe you'll also rub your upper control arm if you don't get spacers or a new upper control arm. Largest tire you can run without any rubbing at full lock or when stuffing it is 265/70r17 iirc.
  3. Jan 14, 2010 at 10:17 AM
    prae
    prae Well-Known Member
    Calgary, AB
    06 4x4 SR5 BSP DCLB
    Bilstein 5100s, eibach springs, AAL, TRD anthracite FJC rims, PIAA Fogs, Pace-Edwards hard rolling tonneau
    Correction, most 285mm wide tires will rub with stock rims.
    If you run spacers, or rims with less backspacing (~4.5"), 285 will fit.
  4. Jan 14, 2010 at 10:25 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    I have the Toyo Open country A/T's and I dont like them very much. The previous owner put them on the truck. They dont have a very agressive tread pattern like other AT tires do and they haven't lasted that long. Look around at some other tires before you set yourself to the toyo's.
