Max Tongue Weight
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rraiderr, Jul 11, 2024.
  1. Jul 11, 2024 at 11:59 AM
    Rraiderr
    Rraiderr [OP] Well-Known Member
    Great White North
    2017 Tacoma TRD off road
    Working now a list
    Can anyone confirm max trailer hitch tongue weight for the 3RD Gen TRD Off Road with tow package.
    The dealer is saying 300 pounds but data online says both higher and lower max weight numbers.
    Thanks
  2. Jul 11, 2024 at 12:04 PM
    abou824
    abou824 Well-Known Member
    Aidan
    Central PA
    '21 TRDOR Army Green 6MT, '13 Lexus RX350
    TRD Lift (Toyota 5100's) LT265/75 AT4W Method MR305 16x8 Bronze ARB Diff Breather Subaru Tweeters Garmin Dash Cam Clutch accumulator delete plate Vibration dampers on MT driveshaft shield
    650lbs
    hiPSI and Rraiderr[OP] like this.
  3. Jul 11, 2024 at 12:04 PM
    mrh2727
    mrh2727 Well-Known Member
    Mathew
    DFW
    2023 TRD off road Barcelona Red
    Rraiderr[OP] likes this.
  4. Jul 11, 2024 at 12:12 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I’m not aware of an official tongue weight spec published by Toyota. I would just use the max payload of the truck (varies by truck) and maybe subtract a bit because the weight is at the farthest point behind the rear axle.
    It is also usually a dynamic weight, so maybe subtract even more.
    EDIT: the hitch might have a tongue weight spec, but I don’t think that it is that simple as I described above.
    EDIT: a weight distribution hitch changes the equation.
    GilbertOz and Rraiderr[OP] like this.
  5. Jul 11, 2024 at 12:12 PM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    10% to 15% of the towed trailer weight to a max of 650#.
  6. Jul 11, 2024 at 12:21 PM
    gudujarlson
    Minnesota
    Where is 650lbs coming from?
  7. Jul 11, 2024 at 12:46 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    The brochure specs chart. Its always fixed at 10% of tow cap, so 680 for 2WD models, 650 for 4x4.
    The manual contravenes this by saying the hitch weight should always be 9-11% of net trailer weight, which is the truer statement.
  8. Jul 11, 2024 at 12:59 PM
    gudujarlson
    Minnesota
  9. Jul 11, 2024 at 2:21 PM
    RichochetRabbit
    RichochetRabbit Ping Ping Ping
    I think the driver door had frozen shut by that point in the "unofficial" testing.
    denimdan73 likes this.
  10. Jul 11, 2024 at 7:17 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
  11. Jul 11, 2024 at 7:24 PM
    lbhsbz
    lbhsbz Well-Known Member
    650lbs of tongue weight without a weight distributing hitch will be miserable
  12. Jul 11, 2024 at 8:49 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Agreed, but I have done the whole 6,500lb towing capacity without the sway bar on the hitch. I-5 from Sacramento to Seattle and beyond, amazed at how many hills/mountains were on that trek.
  13. Jul 12, 2024 at 4:16 AM
    abou824
    Aidan
    Central PA
    I'm sure that wasn't very fun. What kind of load?
  14. Jul 12, 2024 at 6:10 AM
    Toycoma2021
    24’ cargo trailer. See picture on the left.
    abou824[QUOTED] likes this.
  15. Jul 12, 2024 at 7:00 AM
    Propsoto
    Propsoto Active Member
    2022 TRD OR DCSB Midnight Black Metallic
    Crawl under there, pretty sure it's labeled.
