Maximum Caster w/Near Zero Camber
Discussion in 'Suspension' started by erok81, Jan 6, 2017.
  1. Jan 6, 2017 at 8:56 PM
    erok81
    erok81 [OP] Well-Known Member
    Imposter
    Hi!
    After trying to jam 35's on my 2016 Tacoma with only a 2.5" lift, as one woulsguess the tires rub on the cab mount.
    To get this out of the way. I've smashed the pinch weld flat and done the max cmc possible. They still rub when reversing with full lock. I'm sure off road it'll rip the cab off the frame. ;)
    With that out of the way...
    How much difference does caster make? Right now I'm running around 2.5* caster and 0* camber. I'm thinking of cruising back to the alignment shop and seeing if they can get a little more caster to help with clearance.
    I have an icon stage 5 with tubular uca. I don't know how much extra caster I can get leaving camber at 0*.
    With that said...how much extra clearance (assuming I can even get the much) will adding another degree of caster get me?
    Im sure I could calculate this myself, but perhaps someone knows a rough estimate. I don't want to pull the wheel off and measure in sub freezing temps. :)
  2. Jan 7, 2017 at 2:20 PM
    PETEREDGE
    PETEREDGE Well-Known Member
    PETER
    TEXAS
    2012 BAJA BLACK 4X4
    ARB FRONT BUMPER...16x8 SR8 RIMS ,YOKAHAMA MT'S,DEMELLO SLIDERS,UPGRADED SOUND SYSTEM...
    ADD A 1" BODYLIFT AND TRY TO GET 3.0 CASTER AND YOU SHOULD BE OK.
  3. Jan 7, 2017 at 2:26 PM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    you need at least 3.0 caster
  4. Jan 7, 2017 at 2:33 PM
    gottaToy
    JJ
    1985 Moped
    You need over 3.0 caster. I was able to get 4.7 with 0.0 camber when adjusted for full caster just to see how far it would go on one side. Only have 285's, so backed to 3.5, 3.2 final caster with .8 and 1.0 camber. You'll need to trim fenders,too or the shitty body spacers(look like shit).
  5. Jan 7, 2017 at 2:35 PM
    PETEREDGE
    PETER
    TEXAS
    2012 BAJA BLACK 4X4
    WHAT UCA'S DO YOU HAVE??
  6. Jan 7, 2017 at 5:11 PM
    erok81
    Imposter
    Sweet. I'll give the alignment shop another go.
    I've already trimmed a couple inches from the fender. The flare. And max cmc. So all that's left is alignment.
  7. Jul 18, 2017 at 12:37 PM
    sti06
    sti06 New Member
    13 TRD off-road
    Stock
    Bump where you able to get more castor out of it. I did a 3 in lift with all pro uca. Took it to the alignment shop and they said they only can get .8 extra on my castor. Went from 2.1 to 2.9 trying to find solution
  8. Dec 4, 2017 at 4:55 PM
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    same delimma, going to a suggested alignment shop in my area, I have 2.7* allegedly. well see. If not light racing uca's are going to be purchased, bummer because the camburgs I got I really like.
  9. Jan 30, 2018 at 6:35 PM
    gman36
    gman36 Well-Known Member
    San Diego, CA
    2018 Cement DCSB OR
    I just got 5 degrees of caster and 0.5deg of camber with camburg UCAs. Preload set at 2.5in.
  10. Jan 30, 2018 at 6:40 PM
    eldedo
    Mojave Desert
    '16 DCSBOR 4X4
    Got 3.9/4.1 after the realignment then trimmed my ass off along with pinchweld beating, all gtg
  11. Jan 30, 2018 at 6:44 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  12. Jan 30, 2018 at 6:48 PM
    gman36
    San Diego, CA
    2018 Cement DCSB OR
    How big of a tire were you trying to stuff?
  13. Jan 30, 2018 at 9:18 PM
    eldedo
    Mojave Desert
    '16 DCSBOR 4X4
    285/70/17.....but the rim is 8.5 wide with 4.3 bs and -10mm os, so....
