Maximum Lift without Drive shaft angle problems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Niknaq, Jul 16, 2009.
  1. Jul 16, 2009 at 9:27 AM
    Niknaq
    Niknaq [OP] Phightin Phils 2008 Champs
    Nick
    FLA
    2009 4wd 2.7L Regular Cab
    Dumped exhaust, 35 % factory tint, kobalt slim line toolbox, afe pro dry, toyota all weather mats, fog lights soon.
    On my 05 jeep TJ the maximum hieght you can lift it without having to drop the transfer case and modify control arms is 2.5"
    What is the "Magic #" of an 09 Tacoma, are there slight vibrations at that lift?
    thanks for the help!
  2. Jul 16, 2009 at 1:19 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Just like a TJ...it probably depends. Each situation is different.
    I had a 96 tacoma that had 3" lift in the rear after the lift was installed - I needed 2.5* shims. THe lift settled down to about 2.5".
    If might also vary in what cab size you have.....reg cab, access cab, double cab short bed, double cab long bed. The longer the distance between the tcase & diff...the better.
