Maximum tire size for reg cab 2nd gen
Discussion in 'Wheels & Tires' started by hexnutter, Mar 25, 2022.
  1. Mar 25, 2022 at 8:09 AM
    hexnutter
    hexnutter [OP] Well-Known Member
    doug
    Tacoma
    Hello every one. I posted this on the 2nd gen section but it seems more appropriate here.
    I had 265/75/16 BFG KO's and it had no problems. Now with the Toyo Open Country it seems more jerky when shifting from 1st and 2nd. Unfortunately I also got E load rated. From what I read I should have gotten 265/70/16's
    Im worried about toasting my clutch. Any advice much appreciated.
  2. Mar 25, 2022 at 10:10 AM
    hexnutter
    doug
    Tacoma
    So they are 116 load rated actually and I dont know the letter.
  3. Apr 7, 2022 at 3:14 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    You should be able to run 265/75/16 no problems. Swapping to new tires shouldn't cause a truck to be more jerky. This might sounds dumb, but make sure all 4 tires are all the same size.
  4. Apr 7, 2022 at 5:46 PM
    hexnutter
    doug
    Tacoma
    I had walmart put tires on my odyssey once and they put one of the tires on in the wrong size. I think the shifting is just they way they are.
    Not sure but the Toyo's seem to make some road noise, not the tires, too true. Idiot before me put in 3 inch spacers.
    844's and billies on the way. Im not sure what the 20mm of the /265/ gets you.
