Max's wanna be overland build
Discussion in '2nd Gen. Builds (2005-2015)' started by 92LandCruiser, Jul 1, 2010.
  1. Mar 31, 2012 at 8:26 PM
    #441
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    look at the suspension set up closer, Max. 1/2 plate pushes the coilover further down at the MOUNTING POINT of the coilover on the LCA. Therefore the lower shock bolt is pushed down 1/2 inch. But the coilover is mounted inboard of the wheel mounting surface. The further in on the control arm you push down, the more is it pushed down on the wheel mount surface.
    know what i mean?
  2. Mar 31, 2012 at 8:48 PM
    #442
    Spoonman
    Jamie
    Alberta
    Ok Max. i spend too much time on this diagram because i am bored. examine this, good sir.
    lets say that spacer is 1/2 inch.
    the amount of lift youll get at point A. you'll get about 1 inch. At point B. is 1/2 inch. At point C. you'll get maybe 1/16 inch. Because the control is swinging(up and down) from the point in which it is mounted to the frame. The further out on the control arm you are, the more actual lift you will get.
  3. Mar 31, 2012 at 8:57 PM
    #443
    92LandCruiser
    92LandCruiser [OP] Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    :cookiemonster:
    Okay, I get it now. Thanks haha, nothing like ms paint!
  4. Mar 31, 2012 at 8:58 PM
    #444
    Spoonman
    Jamie
    Alberta
    dude i used photoshop CS2 for that. how insulting :p
  5. Apr 1, 2012 at 12:41 AM
    #445
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Alright... that all makes sense!
    CS2, Paint, it's a good picture. :anonymous:
    and I appreciate the effort!
  6. Apr 1, 2012 at 12:48 AM
    #446
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    I've been thinking maybe I ought to have Eric cut out some spacers from steel. 4 of em from 3/16 and then on two of em make pierces so we can tack two of em together.
    If a 3/8 spacer makes a 1/4" difference might be a little better on the CVs. It looks damn good but the CVs are steep now.
    I dunno. Also be nice to have a couple more threads poking out the top of the nut. Right now theres about one.
    Might have to slide out the cv boots using hose clamps.
    edit: I forgot to say I got all my wheel bearing parts and a spare u-joint and inner/outer TREs. Whoo!
  7. Apr 3, 2012 at 9:31 PM
    #447
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    That doesn't look good.
    Not good at all.
    Discount Tire is replacing free since I have their certificates, I just had to get another certificate for 43.01.
    That's two tires replaced now.
  8. Apr 3, 2012 at 9:52 PM
    #448
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Damn ripping off lugs!
  9. Apr 3, 2012 at 10:36 PM
    #449
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    LOL wouldn't have happened with duratracs!
    Just kidding... but I have killed two bfgs now.
  10. Apr 3, 2012 at 10:51 PM
    #450
    ROCKSLINGER
    ROCKSLINGER Zombie Response Team
    Robert
    Reno Nv
    14 MGM DBL CAB 6 SPEED
    Fox Coilover with reservoir, Fox Remote Rear reservoir, Wheeler's 3 pack AAL, Grillcraft Grille color matched, Rampage 50" LED Light Bar, Relentless 1/4" IFS-Mid and Transfer case Skids, Relentless High Clearance Rear Bumper, Kenwood 1800 watt Amp, 12" Rockford Fosgate P3 Shallow Sub, 1 Farad Capacitor, Redline Hood Struts, Weathertech Floor Mats, Doug Thorley Long Tube Headers, Flowmaster Delta 40, URD MAF Calibrator, URD Short Shifter, CST Black Leather W/Red Stich, On Board Air, Train Horns,
    Damn what were you doing to make that happen?
  11. Apr 3, 2012 at 10:56 PM
    #451
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Spinning my tires through something I guess? Probably on my last trip to dog valley. I hit a bit of snow and mud where I had to get on the throttle. Not sure though for certain.
  12. Apr 3, 2012 at 11:39 PM
    #452
    Manwithoutaplan
    ID
  13. Apr 3, 2012 at 11:52 PM
    #453
    92LandCruiser
    Nevada
    Cummins, tons, 40s
  14. Apr 4, 2012 at 6:45 AM
    #454
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    Hey Max. I was just on a business trip to Reno last week and pretty sure I saw your truck. I was stopped at a red light on S. Virginia between Peppermill and Atlantis, looked next to me and saw a grey Taco with a snorkel, ARB front and HC rear and assumed it was yours. Nice looking Tacoma. :cool: I was bummed I had a rental - looks like a truck playground anywhere you go outside of the main city.
  15. Apr 4, 2012 at 7:37 AM
    #455
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    good to know discount will replace tires due to lug damage...
  16. Apr 4, 2012 at 8:26 AM
    #456
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    That was me! :) :wave:
    How often do you get down here?
  17. Apr 4, 2012 at 8:26 AM
    #457
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    They will if it goes down to the belts.
  18. Apr 4, 2012 at 8:28 AM
    #458
    DonnoD
    DonnoD Well-Known Member
    don
    las vegas
    07 dc 4x4 v6
    why did you need a top plate spacer with the 886s?
  19. Apr 4, 2012 at 8:30 AM
    #459
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Truck did not sit level. Not even close.
  20. Apr 4, 2012 at 8:33 AM
    #460
    DonnoD
    don
    las vegas
    07 dc 4x4 v6
    ahhh... got it, yea i didnt think you needed more lift for clearance issues
