MaxTrac 2007 – 2014 TOYOTA TUNDRA 2WD 3.5″ Lift Spindles
Discussion in 'Tundras' started by Chas of MRT, Mar 14, 2014.
  1. Mar 14, 2014 at 2:56 PM
    Chas of MRT
    Chas of MRT [OP] Total Automotive Performance
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    MSRP: 875
    Tundras.com Forum Special: 616 delivered to lower 48!
    Product Description
    Solid, indestructible, proven – these are the qualities you want for important parts on your truck. Our single piece ductile iron lift spindles provide more stability than anything that comes stock from the factory, reinforcing key mounting locations like upper ball joint mounts and tie rod ends. Proven sturdiness show that these new spindles will stand up to the toughest conditions. Give your truck the height required to fit those larger wheels and tires and to eliminate the enormous rake, with simple bolt on parts that require no cutting, welding, or additional parts to accommodate. Extended stainless steel brake lines, DOT approved, come equipped with our lift spindles, rather than cost-cutting bracket extensions found in other kits. These have been test fit on 2014 Toyota Tundra’s and they work great!
    SPECIFICATIONS
    • 3.5” Lift Spindles
    • Extended Brakelines (DOT)
    • Limited Lifetime Warranty
    • Bolt On Installation
    • No cutting or welding
    • 18” Wheel Minimum
    • 18” Wheel Backspacing at 6.5” or less
    • +1.0” Track Width per side
