Maxtrac 4" spindle 5100s and AAL??
Discussion in 'Suspension' started by bradicus8, Sep 18, 2012.
  1. Sep 18, 2012 at 5:47 PM
    bradicus8
    bradicus8 [OP] Well-Known Member
    Brad
    Phoenix, AZ
    2018 cement Trd sport DCSB
    icon kit 33's ovtune pro grille JL audio subs with custom box
    So before I get made fun of for asking stupid questions I am new, just bought my 06 DC Pre runner TRD sport about a month ago from the dealer...everything is stock and I was looking into the spindle 4" lifts... As much as I would love to go with camburg: #1 I won't be doing off roading #2 I don't want to spend money where I won't neccessarily need it... I've been reading up on the Maxtrac 4" spindles and they seem to be a good fit for some one like me who is new to trucks and lifts, keep in mind also I am lifting for 90% look purposes as well as being able to put some bigger tires... Few questions for y'all 1. If I go with the Maxtrac 4" spindle, could I be able to run that with my Stock shocks and springs?
    2. Would it be wise to upgrade my shocks to billies? If so, in front? Back? Or both? (only what's necessary)
    3. Could I get away with using my stock coils?
    4. Are spacers necessary?
    5. For the rear should go with an AAL? 2.5"?
    I figured so far, by my limited amount of knowledge and research, that this route would be the best considering I don't wanna blow a couple grand on some crazy shit when I dont even off road and these spindles seem to be pretty damn heavy duty and hold up... I don't want shitty ride quality, but it does t have to be the best either, for my first truck and lift, looking for something in the middle range that's dependable and would look sick... ALL input will be well considered nd appreciated!
  2. Sep 21, 2012 at 4:11 AM
    superman2481
    superman2481 Well-Known Member
    i wanna know as well
  3. Sep 21, 2012 at 4:25 AM
    Davtopgun
    Davtopgun Weeeee mod time!
    David
    Central Alabama
    2018 Tundra Platinum
    6112/5160 35" Toyo Open country
    Maxtracs are made to run with stock shocks and coils.
    No spacers required.
    go with a 2" AAL if you want it level.
    This setup will give you a level 4" lift. And will ride just a good as stock.
  4. Sep 21, 2012 at 11:35 AM
    bradicus8
    Brad
    Phoenix, AZ
    thanks a lot man that answered all my questions!!!! going to pick the spindles up in anaheim right now!!!:D
  5. Sep 21, 2012 at 11:43 AM
    Casey05Taco
    Casey05Taco Well-Known Member
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    trd seat covers, bed mat, tinted windows, debadged, mud flaps removed, tinted tails, blacked out center console, Black Rims, 6000k HID in highs and fogs, blacked out front emblem, Pioneer AVH-4300DVD, Gauge Cluster, lower valence, retrofitted, audio system, Maxtrac Spindles, Billies
    When you are asking about spacers are you speaking of wheel spacers? If your truck came with the stock rims then yes you will need the spacers
  6. Sep 21, 2012 at 11:48 AM
    bradicus8
    Brad
    Phoenix, AZ
    ya i was talking about wheel spacers, and i found out last night that i will need those bc i will be running stock rims with 285/70's... spidertraxx are probably goin in
  7. Sep 21, 2012 at 11:50 AM
    Casey05Taco
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    Might want to pick up 2 more for the rear. The spindles will already push them out about 3/4" before wheel spacers
  8. Sep 21, 2012 at 12:13 PM
    bradicus8
    Brad
    Phoenix, AZ
    would this give me that pushed out wide look? to be honest i dont want my tires way the hell out there, i DO like a little bit, but sometimes i see pre runner with spindles and the tires are sticking out waay to far, is the spidertraxx 1 1/4" the smallest spacer i can get? i would want to make it as close as i can
  9. Sep 21, 2012 at 2:25 PM
    Davtopgun
    David
    Central Alabama
    If you plan to run bigger tires, you should really consider a set if wheels with 4.5" backspacing. For only slightly more expensive then a set of 4 spidertrax, you could get a set of wheelers off-road steel black bullet hole wheels brand new. They are made with the right backspacing for these trucks and look great!
    I ran wheel spacers at first, until I could afford a nice set of wheels. Never felt comfortable about using them. Seen a couple people have a wheel fall off do to wheel spacers.
  10. Sep 21, 2012 at 2:29 PM
    Davtopgun
    David
    Central Alabama
    The maxtracs will make the front end approximately 2" wider then the rear on each side. When I got new wheels, I still ran 1.25" spacers in the rear/none in the front and the front still stuck out a little further.
  11. Sep 21, 2012 at 5:55 PM
    bradicus8
    Brad
    Phoenix, AZ
    Ok I'm checkin them out right now, should I get the 15" or 16"? And as far as the spacers you ran, how long did u run them for? Did u off road with them? Cuz I will not be off roading, mall crawlin and daily driver, any problems with those that u had personally? I was more leaning towards painting the stock rims black and running spidertraxx spacers
  12. Sep 21, 2012 at 8:01 PM
    Davtopgun
    David
    Central Alabama
    If you have a second gen Tacoma, the smallest wheel you can run is a 16" wheel.
    Wheel spacers work, just require attention. Thise who have had problems, didnt follow the rules with wheel spacers.
    When installing wheel spacers, you tighten all the bolts to spec. You then drive the truck about 10 miles, then pull the tires back off to check the bolts to make sure none have loosened up. If any of them have, tighten them again. Then drive about 10 more miles. Come home, remove the tires again and check all of the wheel spacer bolts. If any are loose, repeat the steps until all are tight.
    After that, periodically check all the bolts. I checked mine every couple thousand miles once they appeared to be staying. I would have to tighten one here and there, every once in a while for the duration that I had them.
    Most hated part of my truck.
  13. Sep 21, 2012 at 8:31 PM
    bradicus8
    Brad
    Phoenix, AZ
    Mmm I see... For that reason alone I would like to stay away from spacers... Lol how much back space would I need to run these spindles? May just pick up some good condition used black wheels from a TW member
  14. Sep 22, 2012 at 3:33 AM
    Robo02cop
    Robo02cop Well-Known Member
    Island of Nunya
    2012 MGM DCSB SPORT
    TRD Intake, Avic D3 DVD Player, Toyota Bed Extender, & Tinted Windows.
    What kind of lug nuts are you running on your wheels spacers??? If you are running regular size lug nuts you may want to look into the All Pro E.T. Lugnuts for your spacers. They are a little longer so you have extra thread to grab onto and they won't loosen.
  15. Sep 22, 2012 at 3:42 AM
    Davtopgun
    David
    Central Alabama
    I was using the ET lugs. Purchased at a local wheel shop though.
  16. Oct 7, 2012 at 7:37 PM
    Celtaco808
    Celtaco808 Member
    Ewa Beach
    09 Prerunner
    Myself picking up a 2009 prerunner and by going through this fantastic forum, I decided to also go with Maxtrac spindles and a set of bilstein 5100's. This prerunner has 25,000 miles on it and I was wondering if I should change out my front springs also. Thinking of getting eibachs. What you guys think? Where can I get 3" aal for cheap?
  17. Oct 7, 2012 at 7:41 PM
    TuFerLife
    TuFerLife 2 4 LIFE!!!
    Taylor
    Chattanooga, TN
    2011 Ford Raptor (I'm a traitor)
    If you're gonna do a 3" AAL, you should prolly just buy a new all pro leaf pack... That will give you 3"
  18. Oct 7, 2012 at 8:26 PM
    Celtaco808
    Celtaco808 Member
    Ewa Beach
    09 Prerunner
    I just looked up the cost of the 3" aal and shit, didn't realize how much it cost. Looking to spend less than $200 for the rear. Any suggestions? Thanks
  19. Oct 7, 2012 at 8:28 PM
    TuFerLife
    Taylor
    Chattanooga, TN
    I'm sure you can get out for less than $200 with blocks, but I don't know of any other way... Maybe these gents can chime in though...
  20. Oct 7, 2012 at 8:30 PM
    GREEKBOY12295
    GREEKBOY12295 Well-Known Member
    Nick
    Phoenix, AZ
    2005 Toyota Tacoma PreRunner
    Radflo 2.5 Coilovers, Viper Alarm 5902, Bilstein 5100's, Polk Speakers, Blacked out grille and Emblems, All Pro 3" leafs, Pioneer AVH-4300 Double Din, BHLM, 4" Maxtrac Spindle, Aero Turbine 2525xl, Ultra Gauge, Rockford Fosgate 300 mono amp, 10" Kicker CVR
    Quick question. The maxtrac spindles are better than stock spindles for off roading right? Because it almost sounds like every one is meaning they are no good for off road.
