MAXTRAX GROUP BUY **FEELER**
Discussion in 'Recovery' started by GARSHA91, Jan 31, 2020.
  1. Apr 9, 2020 at 8:09 AM
    #121
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I'd be so worried about chewing up tires with those.
    "The alloy teeth are significantly harder and more durable than the rubber found in your tires, this means you can expect faster and more secure engagement with the tire tread. This not only makes XTREME the most durable recovery track on the market, but also the fastest."
    WrecklessAbandon likes this.
  2. Apr 9, 2020 at 8:10 AM
    #122
    Shellshock
    Iowa
    Exactly. I thought about cheap ones but the more i thought about it the more sense it made to spend the extra for maxtrax. One of the biggest things is they will flex. They don’t break.
    mine rode in the back of my truck for a long time without getting used. First time I used them I was stuck in the snow and got out in 30 seconds. Second time I was out west and used them to bridge a gap and as a result didn’t rip off my rear bumper or get stuck. Easily for themselves already.
    I’d rather spend the money and have them last.
  3. Apr 9, 2020 at 8:10 AM
    #123
    mikeaesq
    mikeaesq Well-Known Member
    TRD Off-road 4x4
    In sincerity though, the only video I watched shows the x-bull boards doing the same thing as maxtrax. So, was truly curious of that was the case. I learned that there is a difference in longevity, which isn’t too important to me since I won’t use them often.
  4. Apr 9, 2020 at 8:12 AM
    #124
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Is this happening or what?
  5. Apr 9, 2020 at 8:13 AM
    #125
    Shellshock
    Iowa
    I’ve not used them, but I’ve not burned off any teeth from the mkII I have. I be sure to jam them in so they grab right away.
  6. Apr 9, 2020 at 8:13 AM
    #126
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    Same....
    mikeaesq[QUOTED] likes this.
  7. Apr 9, 2020 at 8:15 AM
    #127
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    The x bull boards I referenced in my initial reply to you were brand new, and cracked on the first trip out. They lived a short life. I would want something more reliable than that and not worry about it failing when I need it most.
    I used to have the same mentality for offroad lights.
    "Psh I never use them much so I'll buy 10 pairs of these cheap Amazon ones for the same cost as some Baja design." Well after going through enough sets of the cheap shitty ones I upgraded and it lit up my world. Easily worth the increase in price. Goes back to "you get what you pay for". For some, the cheap stuff is fine based on their needs and what they want to spend. Some would rather spend more and get a nicer quality thing.
    Shellshock and In&out like this.
  8. Apr 9, 2020 at 8:21 AM
    #128
    andrewtheadventurer
    andrewtheadventurer Well-Known Member
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    Thats a thought i had too..
  9. Apr 9, 2020 at 8:34 AM
    #129
    andrewtheadventurer
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    YOU WANNA BICKER.... THEN LETS BICKER!!
  10. Apr 9, 2020 at 8:34 AM
    #130
    Shellshock
    Iowa
    Same. I figured when I needed them, the last thing I wanted to worry about was them failing.
    definitely agree on lighting too. People say I wasted my money, then they see the output my truck has compared to theirs and they suddenly understand there is actually a difference
    EatSleepTacos[QUOTED] likes this.
  11. Apr 9, 2020 at 8:37 AM
    #131
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    :redxfall:
  12. Apr 9, 2020 at 8:37 AM
    #132
    Midnight_Terror
    Midnight_Terror IG: PNW_PRO
    2019 SW Tacoma TRD Pro
    I've messaged them on social media and sent an email asking for more info. I will post as soon as I hear back from them.
    ohheythatguy likes this.
  13. Apr 9, 2020 at 8:39 AM
    #133
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    xbulls do not like cold weather I had a pair and they pretty much exploded the first time I used them to get out of a snow drift. If you don't live somewhere cold then maybe they work fine I dunno.
  14. Apr 9, 2020 at 11:36 AM
    #134
    GARSHA91
    GARSHA91 [OP] YES, that is me on that Facebook group
    Chicago
    2015 TRD Off-Road DCSB
    Just a grocery getter
    Im not trying to change anyones mind because I wont be held accountable. I buy the stuff that has been proven and tested time and time again. Do it right and do it once.
    Update: with everything going on I have yet to hear anything. I am about to get off work in a bit and I will be sending yet another email
    HMM, Yann, gemiv19 and 4 others like this.
  15. Apr 9, 2020 at 11:43 AM
    #135
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    Thanks
    andrewtheadventurer likes this.
  16. Apr 9, 2020 at 7:54 PM
    #136
    RockinU
    RockinU Well-Known Member
    Texas
    That's the video that made my mind up for me.
    Shellshock[QUOTED] likes this.
  17. Apr 9, 2020 at 8:03 PM
    #137
    RockinU
    Texas
    Then you need to watch the 4 wheeling Australia video that's been posted in this thread. It clearly shows the difference is more than longevity.
  18. Apr 9, 2020 at 9:02 PM
    #138
    Apollo14
    Apollo14 EEF Brand Ambassador
    Jonathan
    Vail, CO
    2018 Cement Taco TRDOR DCSB
    Buy nice or pay twice... :thumbsup:
  19. Apr 10, 2020 at 6:17 AM
    #139
    savethewheels
    savethewheels Well-Known Member
    Nashville, TN
    truck
    You can buy 8 Xbull traction boards from Amazon for the price of 2 Maxtrax... Sooo I bought a pair a little while back.
    I've been holding my breath for this effort/thread but tbh, it doesn't seem like it's going anywhere. I've organized group buys in the past, and if a vendor is interested then they typically jump at the opportunity fairly quickly.
  20. Apr 10, 2020 at 6:18 AM
    #140
    GARSHA91
    Chicago
    Heard back from them last night. Theyre looking at it now and they hope to have something today. so fingers crossed :fingerscrossed:
    Yann and Startleflinch like this.
