MaxTrax Xtreme
Discussion in 'Recovery' started by suomiM31, Nov 7, 2022.
  1. Nov 7, 2022 at 12:57 PM
    suomiM31
    suomiM31 [OP] Well-Known Member
    Anyone with information about these? They cost $200 (Canadian) more than the MaxTrax MKII version.
    Thanks for any info!
  2. Nov 8, 2022 at 4:00 PM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    The difference is molded in plastic vs replaceable metal teeth. Otherwise they're the same. Doesn't really seem worth $200 to me...
  3. Nov 8, 2022 at 4:45 PM
    Gutentight
    Gutentight Well-Known Member
    IL
    2021 Cement Off-Road 4x4 DCSB 3.5L AT
    Looks like they tweaked the design a little in their extreme version. Maybe a year ago I think they still had bolts with nuts on the topside. Probably just using some new special design nuts on top now.
    They used to have an FAQ that if the regular version nylon teeth got burned up from wheel spin you can drill out the tooth, and install regular 1/4” hex bolts. Which made it the same as the extreme version of the time. I don’t remember the length they noted, but it had probably 1/4”threads exposed beyond the nut. That included an extra disclaimer that any wheel spin will tear up the tires once converted to the extreme version.
    Edit:
    Disregard above statement about MaxTrax
    I was mixing up with the US based ActionTrax. Those are the ones that state to repair with bolts. Not sure if MaxTrax extreme boards have any difference in the molding.
    Thanks for the reminder @3JOH22A
    Side note I have the cheaper ActionTrax version, and it has worked great for me.
    3JOH22A and reallifedog like this.
  4. Nov 8, 2022 at 5:02 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    They have replaceable aluminum teeth installed with a torx bit: https://www.maxtrax.com.au/xtreme-replacement-teeth-set
    Might be easier on the tires than stainless bolts (which are still used on the US-based ActionTrax boards selling for about the same price).
