Maxxis Razr AT-811, The Ranger's Review
Discussion in 'Wheels & Tires' started by Maticuno, Aug 12, 2021.
  1. Aug 12, 2021 at 8:19 PM
    Maticuno
    Maticuno [OP] Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    First and foremost, yes, this review is covering the tires as installed on a Silverado 2500. While not in the same realm as most of the trucks on this site, this is where I started writing tire reviews, and Tacoma World has far more traffic than any of the Duramax forums. You're stuck with me, folks.
    I had been on the search for a new set of tires almost immediately after buying my truck. At the time, there was nothing really wrong with the Kelly Edge AT tires that came new on it, but they were just so boring that I daydreamed and window shopped for more interesting options. Fast forward a year, and the Kelly's developed a cracking ring in the middle of the sidewall on all four tires, which sped up my search. While the Falken Wildpeak AT3W was my go to tire for quite some time, Falken seems to have realized their budget performer could command a premium, and prices reflect this. Another thread in this sub-forum brought the Maxxis Razr AT-811 into my consciousness. I had only ever known Maxxis tires from their ROV/ATV lines, so I was surprised to find that, not only did they make truck tires, they are actually quite popular among our off-roading allies in Australia. For an LT265/75R16E tire, the Razr AT is approximately $20 per tire cheaper than the Falkens. I pulled the trigger through SimpleTire and had them shipped to an American Tire Depot near me. Installation was paid for in advance, through SimpleTire. All I did was order, select an install date, and show up for the appointment. The only additional out of pocket was the California Tire Disposal Fee.
    Installation went really well, and they balanced out better than almost any other tire I've run. One tire has 3oz of weight, one has 2oz, one has only 1/2oz, and one had no weights at all! The balance is glass smooth at all (legal) speeds I've had a chance to run them so far. After a bit of adjustment for ride harshness and a chalk test, the tires are set at 46psi front and 35psi rear for no-load, daily driving. With California's extreme drought, I doubt I'll get any wet weather driving experience anytime soon. For now, I wanted to start the review and picture dump, and I'll update as I go along.
    15/32" measured tread depth new.
    13/32" measured siping depth.
    Approximately 8.5" tread width.
    Approximately 30.5" mounted and loaded tire height.
    On Road Handling
    For as aggressive looking as the tread patch is on these tires, the typical AT howl is barely noticeable at speed. They track straight and true; no pulling left or right. Turn in is immediate, with only a little bit of lug roll before they catch up and give you full steering input. There is no "walking" feeling you get at low speeds like is common in other, large void all terrains. While running late to an appointment today, I had a chance to get the truck up to (redacted)MPH on the freeway. They seem as smooth as any other fairly aggressive all-terrain: not glassy, but definitely not a swamper. Acceleration onto the on ramp felt planted, with no tendency to hop or side shift, even when hitting expansion joints on the long, circular ramp. Lane changes and moderate stops were predictable and confident.
    Off Road Handling
    The Maxxis Razr offers up a ton of traction on hard packed dirt and soft sand. It took a fair amount of throttle, even with the diesel torque, to make them break loose while climbing hills. They were also (to my kids disappointment) very resistance to drifting corners. I'd have needed clearer lines of sight and a fair bit more pedal to wag the tail for funsies. While the soft sand I tested in wasn't terribly deep, the Razrs did not really want to sink in. As you can see from the photos, even with a heavy diesel truck, they would only settle down a little bit before the sidewall biters dug in and pulled the truck through. Engaging 4 wheel drive was not necessary, even after stopping on a rutted hill for a photo op. The G80 diff worked well to keep both rear tires applying forward progress. I'm very impressed with the abilities of the Maxxis Razr so far.
    7,500 Mile Update
    After 7,500 miles, I reached my first tire rotation. Tires have worn to about 11-12/32nds. Not unreasonable for being on a heavy diesel truck. Shortly after rotating the tires, I traded the Duramax in for a newer, fully loaded Suburban 2500. I like the Maxxis Razr so much that I had the dealer work in swapping the wheels and tires from my traded Silverado to the 'Burb. Fit perfectly and look great!
    20,000 Mile Update:
    With 20k on the clock, the Maxxis Razr is still performing well. Wear seems to have slowed a bit, holding at 8/32nds as of this post. Current estimate is 40k before they will be done, which is about average for how I drive. I have had these in heavy rain, light snow and ice, and road construction mud. They still perform extremely well, and are still very quiet. I was actually in the process of ordering a bunch of these for my work fleet, but right before I could pull the trigger, a new mandatory tire contract dropped.
    PDKTaco, atc250r, Evostaco and 9 others like this.
  2. Aug 13, 2021 at 12:43 PM
    OuchIDied
    OuchIDied Well-Known Member
    2021 Silver Sky Tacoma Off-Road
    You're 100% welcomed here with the reviews and insight you provide on tires. Thanks man. New truck and these tires on are the radar.
  3. Aug 14, 2021 at 2:37 PM
    Maticuno
    2011 Suburban 2500
    Updated with a bit of on and off-road experience.
    Loan Wolve likes this.
  4. Aug 19, 2021 at 11:40 AM
    Maticuno
    2011 Suburban 2500
    Another small update with more highway-oriented driving.
    MAC07 and Soul Surfer like this.
  5. Jul 8, 2022 at 4:59 PM
    Maticuno
    2011 Suburban 2500
    7,500 mile / new vehicle update.
  6. Nov 29, 2022 at 7:50 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Still digging these? The wife got a 5th gen t4r and it came with BFG at ko2s I can't wait to get off and saw these in 285/70 for under $200 a piece I'm thinking about putting on it
    Maticuno[OP] likes this.
  7. Dec 4, 2022 at 12:47 PM
    Maticuno
    2011 Suburban 2500
    I'm considering buying these in bulk to throw on my off-road work fleet.
    yota243 likes this.
  8. May 5, 2023 at 7:45 PM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    Just wanted to say thanks for taking the time to write this review. I’m trying to decide on my next set of tires and this was helpful.
  9. May 19, 2023 at 8:03 AM
    MulletTaco
    MulletTaco Wannabe prerunner
    Kevin
    Somewhere in AZ
    21 TRD Sport 4x4 DCLB
    Removed some stuff, added some stuff.
    Definitely considering these. Thanks for the leg work!
    Road_Warrior and Maticuno[OP] like this.
  10. Jun 25, 2023 at 10:34 AM
    Maticuno
    2011 Suburban 2500
    20K mile update.
    Road_Warrior likes this.
  11. Jun 25, 2023 at 10:40 AM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Thanks for providing the continued updates. These are in the top 2 for my next tire thanks to your reviews.
    Maticuno[QUOTED][OP] likes this.
  12. Jun 6, 2024 at 10:00 AM
    TA-5650
    TA-5650 Well-Known Member
    Wilmington, DE
    2017 TRD OR DCSB, Blazing Blue Pearl
    I love these tires. I’m pretty sure I’m close to 50k on mine with plenty of tread.
    Maticuno[OP] and Road_Warrior like this.
  13. Jun 7, 2024 at 2:23 PM
    Lthompson
    Lthompson Well-Known Member
    My experience hasn’t been necessarily great with these tires…. Odd wear, and they road walk and bump steer like crazy as they have worn down. I don’t know what else to attribute it to. I’ve replaced everything else, and had multiple alignments. But I’ve had pretty uneven wear and cupping on the edges front and rear, and they follow any imperfections really bad and push me all over the road. Kinda at a loss for what to do
  14. Jun 10, 2024 at 5:45 AM
    Maticuno
    2011 Suburban 2500
    What PSI are you running in them, and are you using the SL or E load?
    TA-5650 likes this.
  15. Jun 12, 2024 at 9:55 AM
    Lthompson
    SL, 285/70/17. Typically around 32 psi daily driving.
  16. Jun 12, 2024 at 1:03 PM
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    Sounds like more than a tire issue
    TA-5650 likes this.
  17. Aug 3, 2024 at 4:02 PM
    yota243
    E.J.
    north Alabama
    Finally got rid of the bfgs. Excited to run these on my wife's t4r, they are p rated so quite a bit lighter, supposedly a lot quieter... IMG_20240803_175614_436.jpg IMG_20240803_175625_589.jpg IMG_20240803_175600_670~2.jpg
  18. Aug 4, 2024 at 12:11 PM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Nice, they look great.
    I’ve been running the MTs for a while now and I don’t see a need to ever switch tire brands other than just curiosity.
    yota243[QUOTED] likes this.
  19. Aug 4, 2024 at 8:31 PM
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    Walmart?
  20. Aug 5, 2024 at 3:06 AM
    yota243
    E.J.
    north Alabama
    Yeah 167 each
    Gmak621[QUOTED] likes this.
