Maxxis RAZR AT in E and SL
Discussion in 'Wheels & Tires' started by canyonchaser, Oct 1, 2020.
  1. Dec 29, 2020 at 8:26 AM
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
    R4D4G4ST likes this.
  2. Dec 29, 2020 at 8:35 AM
    R4D4G4ST
    R4D4G4ST Well-Known Member
    21 LR TRD PRO MT
    Maxxis Militia
    I broke three wheels over the course of six months. Cush Cores were the only reasonable answer. I ran them in Aluminum wheels long before I put them into Carbon. You run Cush Cores not for wheel protection but for two stage damping. You get so much more grip and compliance with them. I'm telling you. You want Cush Cores! :D
    Also, in Utah, typically everything is loose over hard.
  3. Dec 29, 2020 at 8:37 AM
    R4D4G4ST
    21 LR TRD PRO MT
    Maxxis Militia
  4. Dec 29, 2020 at 8:44 AM
    R4D4G4ST
    21 LR TRD PRO MT
    Maxxis Militia
    LarryDangerfield likes this.
  5. Dec 29, 2020 at 8:45 AM
    reg0928
    reg0928 Well-Known Member
    Ross
    Crestone, Colorado
    05 TRD OR Access Cab
    3"OME, 255/85R16
    On the MTB topic, I run DHF front and Aggressor rear. Set em up tubeless and they're perfect for the stuff I ride here in CO.
  6. Dec 29, 2020 at 8:50 AM
    R4D4G4ST
    21 LR TRD PRO MT
    Maxxis Militia
    Thats the combo I used to run. As you well know, how you ride has a lot to do with tire choice. I'm on a Nomad and do a lot of rocky chunk, I climb a lot, but I climb to descend. I'm not chasing Strava times up the mountain, so switching to the Assegai/Dissector was a great move for me. It's like everything you like about the DHF/Aggressor turned up one notch. (but get you some Cush Cores, you'll thank me)
    *I am not affiliated with CC in any way, they sound like a gimmick, but they are amazing. Everyone I've known who puts them in says the same thing.
  7. Dec 29, 2020 at 9:08 AM
    reg0928
    Ross
    Crestone, Colorado
    3"OME, 255/85R16
    I'll look into the Assegai when it's time for a new set. I'm on a Remedy, and my riding sounds similar to yours. I love to climb, but I do it so that I can mob downhill afterwards. Mostly dry, chunky, techy stuff.
    I'll be taking a look at the Cush Cores, too. You're not the first person I've heard good things about them from
    R4D4G4ST[QUOTED] likes this.
  8. Dec 29, 2020 at 9:28 AM
    Revmedia
    Revmedia Active Member
    J
    Oregon
    2021 Taco Sport
    Definitely interested in these VS the wildpeaks. Anyone get a set yet? Also here for the hot MTB talk. Came in looking for truck tires, now I gotta go put in an order for Cush cores.
  9. Dec 29, 2020 at 9:34 AM
    Minny Taco
    Minny Taco For the Horde!
    Minnesota
    2015 TRD Off Road DCSB
    - Dobinsons shocks and leaf pack - Level 8 MK6 wheels - 265/70/17 Goodyear Wrangler Duratracs load C - SPC UCA - Moog LCA - TRD Pro headlights - Bullet Proof Fab skid plate w/ Line-X - 3M Matte Black roof vinyl - Astrostart remote - Debadged - Black shifter bezel - Front window tint 50% - Color matched grill surround - MESO LED red/white map lights - Osram Super Bright H4 bulbs - Headlight Services upgraded wiring harness - Auxito LED reverse lights - Zulu Nylon Gear MOLLE visor cover - Truxedo Lo Pro QT tonneau - Weathertech floor mats - Weathertech vent visors - Redline Tuning Elite hood struts - OEM bed mat - AJT Design custom shift knob - AJT Design custom climate knobs - Center console organizer - Salex glove box organizer - 1" driver seat spacers - AntennaX 14" antenna - AVS door sill protectors - Trimmed OEM mud flaps - Candyapple red tow hook - Painted pinch weld and radiator frame - Custom radio knobs from Hondo Garage - Xtunes black tail lights - Black LED third brake light - Ruff Tuff Kryptek Typhon seat covers - ACEkraut license plate relocation bracket - Cali Raised Side Shooter ditch lights w/ lo-pro mounts - Subaru tweeters + Rockford Fosgate speakers - Thinkware F800 Pro dash cam - Stickers n shit
    These seem to have everything I'm looking for in tires right now. Was leaning towards Duratracs but these make me reconsider. I wish they'd come in C load though. They're 53 lbs compared to 45 lbs on my Toyo Open Country A/T II. Duratracs are 45 lbs in C load so I may just stick with those HOWEVER I don't think they're snowflake rated whereas the Maxxis' are.
  10. Dec 29, 2020 at 10:11 AM
    R4D4G4ST
    21 LR TRD PRO MT
    Maxxis Militia
    Yeah, exactly. I'm interested in the SL rated - and at 38.5 lbs, they become a bit of a goldilocks tire for me.
  11. Dec 29, 2020 at 10:15 AM
    Minny Taco
    Minnesota
    What's the main difference between SL and Light Truck? Just weight?
  12. Dec 29, 2020 at 11:29 AM
    R4D4G4ST
    21 LR TRD PRO MT
    Maxxis Militia
    So, basically, tires are rated for how much air they can hold, which determines how much weight they can carry. LT tires are designed for super heavy loads, so they are supposed to hold 80psi. The tires that come on the tacoma are 112T (SL) rated, which is 1120Kg, 2500 lbs. More weight than the rear axle can carry.
    An E-rated LT tire might be rated for 3175 lbs at 80 psi. Ironically, if you run an E-rated tire at 30 psi, then the weight rating of that tire is lower than the equivalent SL rated tire at the same pressure.
    A lot of guys insist on running E-rated tires because A) most really cool looking tires only come in an LT size because there are way more Full-size trucks in American and B) they go with the assumption that LT tires are 10-ply tires and that means they can resist punctures better. But all tires, LT and SL are either two to three plys in the sidewall, regardless. So the construction of the tire has as much to do with it's resistance to puncture as anything else.
    The reality is, however, an E-rated/LT tire is heavier and does tend to survive better at ultra-low pressure over sharp rocks. I mean, an LT tire is heavy AF. The LT might be 59/60 lbs per tire, where the SL may only be 40/41 lbs. But on the flip-side, thats 20lbs more of sprung, rotating mass, per tire, that the truck has to spin up, slow down and that the suspension has to damp over bumps. LT tires on light vehicles makes for a miserable ride, and a loss in handling, braking and acceleration.
    So the TLDR is. Unless you are driving at ultra-low pressures over sharp rocks on the regular, the vaaaast majority of us will be much happier running an appropriate SL rated tire on our svelte Tacomas.
    and Double TLDR, why the SL Maxxis is so interesting to me. It looks really cool, it has serious off-road cred in NZ and Australia, and it's light.
  13. Dec 29, 2020 at 11:49 AM
    Minny Taco
    Minnesota
    That's super helpful, thanks. I run C load at about 32 lbs right now but they are LT. The ride isn't super soft on the city streets. I rarely get into gnarly stuff so SL is probably a good choice for me, which points me to the Duratrac. I don't see the Razr in 265/75/16 C load SL anywhere. They are super cool looking though.
  14. Dec 29, 2020 at 12:03 PM
    R4D4G4ST
    21 LR TRD PRO MT
    Maxxis Militia
    C-load is different than SL. C-loads were designed for even lighter jeeps and may have a lower weight rating than an SL, depending on the tire.
    and according to Maxxis the have the 265/70-16 is SL, which is fine enough for me. But I'd love to see someone with them or even know if local tire dealers are carrying them yet.
    Minny Taco[QUOTED] likes this.
  15. Dec 29, 2020 at 12:24 PM
    #35
    Minny Taco
    Minnesota
    I did see that but I want to run 265/75/16 as they're a little larger. The Maxxis website shows dealers across the US that are carrying Maxxis tires. I'd have a couple hour drive from my place to the nearest.
  16. Dec 29, 2020 at 2:04 PM
    #36
    tahoeskitaco
    tahoeskitaco Well-Known Member
    KLH
    North Tahoe
    2002 SR5 Xtra Cab + 2019 TRD OR Dbl Cab
    Stock. Custom hettich bed slide
  17. Dec 29, 2020 at 3:08 PM
    #37
    bigShawn
    bigShawn Active Member
    Shawn
    I actually ordered the Razr AT 285/70r17 SL load last week. Should be arriving Saturday. Only about $160ea. Weight was a big factor for me, only 43lbs for an aggressive looking 33” tire.
  18. Dec 29, 2020 at 3:35 PM
    #38
    R4D4G4ST
    21 LR TRD PRO MT
    Maxxis Militia
    Anxiously awaiting photos and feedback! :D
    bigShawn[QUOTED] likes this.
  19. Dec 31, 2020 at 9:42 AM
    #39
    Revmedia
    J
    Oregon
    2021 Taco Sport
    Me too! Got a pair in my cart waiting to pull the trigger but I’m nervous about it. Was sure I was going with wildpeaks after doing so much research, but these seem like they could be a great option for slightly less money. Feel like I may just jump in with both feet.
  20. Dec 31, 2020 at 10:06 AM
    #40
    R4D4G4ST
    21 LR TRD PRO MT
    Maxxis Militia
    We've not received any snow, so I don't need to replace the dogshit OEM tires just yet, so I'm waiting. Their popularity in NZ is very encouraging, but I'd like to see some actual photos of some (not just the computer renders), you know?
    Revmedia[QUOTED] likes this.
