May have ruined my engine with water?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by StaticFilter, Mar 14, 2010.
  1. Mar 14, 2010 at 6:52 PM
    StaticFilter
    StaticFilter [OP] Well-Known Member
    Cedar Hills, UT
    2008 Blue FJ Cruiser
    Lifted, N-Fab steps, Roof rack light bar, Grill guard, Volant Snorkel (not installed ye)
    Okay, I'll start off by saying I'm not an engine guy.
    Decided to go do a little sunday offroading with my wife and daughter... lots of water/mud. hit the puddles pretty good, got water in the top of my engine compartment, tried climbing one last very muddy hill without success, made it halfway in 4-Lo and started backing down, started getting a horrible noise and gas smell in the cab so i shut it down and rolled it down. Took it out of 4-Lo, out of 4-Hi, popped the hood, saw a lot of water on my intake cover etc. decided to start it, started right up but noise coming from engine area, and throttle jumping up and down, idling it revs from 10,000 to 15,000 and back on it's own. drives okay, no check engine light, but still a bad noise coming from the spark plug area. Any ideas? I HAVE to drive 80 miles in the morning to work so it's drying out in the garage for now...
  2. Mar 14, 2010 at 6:59 PM
    singlefin
    singlefin Well-Known Member
    Portland, OR
    Syncro
    Pull your plugs make sure they dry/let them dry...Remove your MAF and make sure its clean and dry.
  3. Mar 14, 2010 at 7:01 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    also your air filter may be damp
  4. Mar 14, 2010 at 7:02 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    X2
  5. Mar 14, 2010 at 7:03 PM
    dog tired
    dog tired Well-Known Member
    NE Ohio
    Well you did not hydro lock it so it most likely is just still wet
    new filters - air - oil
    new oil
    diff fluid change front and rear
    dry out the plugs
    playing in water gets expensive - thats why I don't do it too much
  6. Mar 14, 2010 at 7:06 PM
    StaticFilter
    Cedar Hills, UT
    Will I be okay for the trip in the morning if i cant get new filters til after?
  7. Mar 14, 2010 at 7:06 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    should be okay
  8. Mar 14, 2010 at 7:26 PM
    StaticFilter
    Cedar Hills, UT
    Okay so i pulled my manifold cover off and was checking things out. saw a hose had come off, not sure how, maybe excess pressure from rolling backwards while in 4-Lo. popped the hose back on and started the engine, sounded fine and dandy, pulled that hose off and it started having the issues so i think im okay. Thanks for the input guys. the foam on the bottom of the manifold cover was wet heh...
  9. Mar 14, 2010 at 7:27 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Debadged, GC Mesh Grill, Yellow Fogs, Color Matched Headlights w/ Retros, Diff Breather Mod; mickey thompson classic IIs, 5100s, toytec springs, Dakar Leaf pack, ss brake lines, Lots more...just check the build page.
    2nd. I'd pull them out and let em dry. Replacing them right now is probably out of the question since you have to drive to work in a few hours. You can always crank the motor w/ the plugs out to see if it'll spit any water out.
    Usually if you get water in the motor, it'll stop and wont crank since you cant compress the water thats in there. You can bend valves this way too. In an event, I dont think thats what happened in your case, or doesnt necessarily sound like it anyway.
  10. Mar 14, 2010 at 7:29 PM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    Glad you found the culprit! Put a clamp on the hose next time you think of it.
    And if you think any moisture did get in the motor, changing the oil would be a good idea, as mentioned above.
  11. Mar 14, 2010 at 7:31 PM
    StaticFilter
    Cedar Hills, UT
    this crazy thing is, it has one of those squeeze clamps on it...
  12. Mar 14, 2010 at 7:33 PM
    Brunes
    Brunes abides.
    Rotorhead
    That's not what happened- Hydrolocking won't let the truck run.
    It sounds like he found some loose stuff and got it worked out. When you've got the time- Clean it all out and think about swapping fluids. If you are driving thru deep water I'd be more worried about it- but thru puddles and mud- Not as big an issue.
  13. Mar 14, 2010 at 7:43 PM
    StaticFilter
    Cedar Hills, UT
    Well, water hitting the hood from INSIDE the engine bay probably isn't good eh?
  14. Mar 14, 2010 at 7:47 PM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    The biggest concern (outside the intake sucking it in) would be the electrical connections. Other than that, not much to be worried about imo.
  15. Mar 14, 2010 at 7:50 PM
    Brunes
    Brunes abides.
    Rotorhead
    It's no biggie like Chris NJ said. You get water in there from rain and car washes....Not great but not bad. Driving thru deep water is where the problems usually start.
  16. Mar 14, 2010 at 10:23 PM
    nighthawk87
    nighthawk87 Well-Known Member
    Prob can't sell the truck on this site now....people know the truth!
  17. Mar 14, 2010 at 10:31 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    id never sell my truck for 2 reasons
    1 i love my truck
    2 if i sold it to someone, knowing what my truck has gone through, if it died shortly after id have a load on my conscience equivelent to being sent to hell and being ass raped by satin
  18. Mar 14, 2010 at 10:40 PM
    nighthawk87
    What else have u done to it
  19. Mar 14, 2010 at 10:42 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    me or op?
  20. Mar 14, 2010 at 10:43 PM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    STi Short Shifter.OEM floor illumination kit. Rally Armor Mud Flaps. BC BR Coilovers. Invidia N1 Exhaust
    i was just gonna say pull your spark plugs and make sure thyere dry
    EDIT: btw please make a build thread i am sure im not the only one wnating to see your beast
