May I see some rusted frame pics?
Discussion in '1st Gen. Tacomas (1995-2004)' started by xSpyderguyx, Feb 19, 2010.
  1. Feb 19, 2010 at 7:58 PM
    xSpyderguyx
    xSpyderguyx [OP] Well-Known Member
    Caleb
    Washinton State
    2001 3.4L v6 SR5
    s40 Flowmaster 33" Toyo M/T tires 16" P.A wheels 3" revteck Suspension lift
    Hey guys, I was just wondering where I should look on my 2001 tacoma for frame rust? I looked but didnt see any rust but I wasnt sure where to look! :confused:
    Thanks guys
  2. Feb 19, 2010 at 8:29 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    You could do the hammer test.... or try looking on the Inside of the frame, bc thats where the rust will start. And the hammer test is where you just tap your frame with a hammer.
  3. Feb 24, 2010 at 5:06 PM
    thenrie
    thenrie Well-Known Member
    Stafford, VA
    2000 Tacoma, SR5, TRD, 2.7L (LEV), 4wd, 5sp m
    Magnaflow cat and cat-back exhaust, AFE Stage 2 cold-air intake system, 2.5" lift via Skyjacker leaf packs, Bilstein 5100s.
    The place the rust will show up first in on the inside of the frame rails just forward of the front spring mounts for the rear springs. The frames rust from the inside-out at that point. I bought a 97 a couple years ago after visually inspecting the frame and finding only a little surface rust here and there. When I got home and did a more thorough inspection I found a little flaking on the inside of the left frame rail, just where I indicated above. That area was blocked by the gas tank during my initial visual inspection. I reached under and felt the frame rail and found some flaking, so I grabbed the frame rail and applied hard hand pressure on the inside of the frame. It crushed in my hand. Literally.
    Luckily the guy hadn't yet cashed my check and I stopped payment. I returned it to him. He was honest and didn't know about the rust and took the pickup back without a problem. Shortly after that was when Toyota came out with their replace/repair/buyout policy.
    I bought the 2000 I currently have shortly after and it passed Toyota's inspection in 2007. Last week I noticed the left frame rail has started to rust through right in that same spot. Looks like I'll be talking to Toyota soon.
  4. Feb 28, 2010 at 7:23 PM
    Tic Taco
    Tic Taco Well-Known Member
    2002 Tacoma Ext. cab.
    90,000 miles :mad:
  5. Feb 28, 2010 at 7:26 PM
    tacomaforlife
    tacomaforlife Well-Known Member
    Robbie
    AIKEN, SC
    Its a Toyota what more is there to say.....
    TRD S/C 3" sky jacker suspension lift,33" kumho road venture mt kl71's 16" 320c pacer wheels,billet grill,EBC slotted and dimpled rotors,super 44 muffler with gutted cat,smoked l.e.d. tail lights, deck plate mod with K&N filter,fog/blinker mod,cobra cb with 4' firestick antenna/100W PA,clear corners with l.e.d bulbs,55w back up lights,urd O2 sim., blue l.e.d bulbs behind gauge cluster.
    holy sh!t thats bad!!:eek:
  6. Feb 28, 2010 at 7:27 PM
    jandrews
    '09 FourDubDee TRD OR
    Yes you may. Thank you for your excellent grammar.
    Although I have no idea why you needed my permission.
  7. Feb 28, 2010 at 8:18 PM
    ywen
    ywen Well-Known Member
    purple truck? eh.. not much of a loss I guess... :D
  8. Mar 4, 2010 at 10:34 AM
    Tic Taco
    Wrong, not "purple", its a factory red :)
