May want to change the oil WAY before 10k miles on your new tacoma.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by maxmk8, Feb 8, 2021.
  1. Feb 9, 2024 at 9:40 AM
    #601
    Chukar Chaser
    Chukar Chaser Well-Known Member
    Pete
    So Cal
    2019 TRD OR 4X4 DCLB
    Mobil 1 0W20 is often at Costco for ~$30 for 6 quarts. An OEM filter is about $5. It takes me about 45 minutes to change the oil on my Taco, if I take my time. I did the first one at ~800 miles and then at 4000-4500 mile intervals. Hoping to keep the truck a while.
  2. Feb 9, 2024 at 9:53 AM
    #602
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    I do this too. I also put it in to carfax too.
    I wonder with the Toyota app do the records stay with the vehicle even self entered ones. I found out with carfax when you sell the vehicle and remove it from your profile it deletes all self entered records.
  3. Feb 9, 2024 at 12:16 PM
    #603
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    one reason why I print out maintenance entries that I place in the Toyota app
    Barsoom likes this.
  4. Feb 9, 2024 at 12:22 PM
    #604
    SmoothTRD
    SmoothTRD Well-Known Member
    Nah, 10k for me easy peasy, 235k miles now
  5. Feb 9, 2024 at 12:55 PM
    #605
    maxmk8
    maxmk8 [OP] Well-Known Member
    2022 Electric Lime M/T Taco
    Page 31 reminder.
    THIS IS ABOUT THE INITIAL OIL CHANGE ON A NEW TRUCK
  6. Feb 9, 2024 at 1:16 PM
    #606
    SmoothTRD
    Not necessary
    hiPSI likes this.
  7. Feb 9, 2024 at 2:31 PM
    #607
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    It’s an oil thread
    They alaways go astray
    You got your answers/opinions early on
    wombatz likes this.
  8. Feb 9, 2024 at 2:41 PM
    #608
    2Shoes
    2Shoes Well-Known Member
    2021 TRD Off-Road
    My last Toyota was a 1st Gen Tundra, at 437K miles I hadn't changed the oil in maybe 80K or more, just kept adding a pour or two everything time it seems a little low.
    If if this brings out the rage in you, you are welcome, it's sarcasm and not actually, true. Get over it!
    faawrenchbndr likes this.
  9. Feb 9, 2024 at 2:43 PM
    #609
    Chukar Chaser
    Pete
    So Cal
    Lots of rage out there... I'm gonna get a cold one....
  10. Feb 9, 2024 at 5:05 PM
    #610
    Taco_mike73
    York, PA
    I have a book with it all written out too.
    on thing I noticed with carfax is sometimes when a shop puts in an entry it is vague. Like they might just say "vehicle serviced" when the actual service might have been something complex like say a timing belt service. cant trust them to be actuate either.
  11. Feb 9, 2024 at 5:21 PM
    #611
    lavrishevo
    lavrishevo Well-Known Member
    2023 Trail Edition
    I’ve posted many times about why I do my first oil changes very early for this exact reason. It’s above most on here. Great post though. I actually did my first OCI at 250 miles then again at 600 miles. All that metal in the oil equals microscopic scoring. Gets to get that shit out asap.
    maxmk8[QUOTED][OP] likes this.
  12. Feb 9, 2024 at 6:18 PM
    #612
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    It's Friday, so I won't tell you what you don't know. Have a great weekend!
    Lt. Dangle likes this.
  13. Feb 10, 2024 at 6:31 AM
    #613
    SmoothTRD
  14. Feb 17, 2024 at 7:18 PM
    #614
    goingplacesanddoingstuff
    goingplacesanddoingstuff Well-Known Member
    2019 TRD Off Road
    2.5” OME lift, Koenig Six Shooter wheels, 275/70r17 Nokian Outpost AT, CMC, Nitro 4.88s, Greenlane aluminum sliders, CBI aluminum skid, Greenlane aluminum front bumper, Out Gear Solutions HC rear bumper, Baja SAE fogs
    It depends on what you mean by “engine failure.” On one end there’s catastrophic breakdown, and on the other hand there’s coked up, stuck rings leading to cylinder wall wear, oil consumption, blow-by, loss of power and mpg, and slow agonizing death.
    The latter is more likely to occur earlier with extended drain intervals. That’s just a fact - the longer an oil is in use, the more prone to forming deposits it becomes. Whether fouled rings occur before another problem condemns the vehicle is open to many factors already explored in the post you responded to.
    I personally think that people running 10k intervals should stick with only the very highest quality oil and filters and change early if they push the engine in an interval.
    While I agree that 5k is probably the best course for most people, your truck will not make 800,000 miles. You’ll be lucky to get half that.
  15. Feb 17, 2024 at 8:44 PM
    #615
    SmoothTRD
    Synthetic every 10k doesn't matter what brand your engine will last way longer than you will keep the vehicle
    BillyE likes this.
  16. Feb 17, 2024 at 9:05 PM
    #616
    2019 TRD Off Road
    You have a 2010 with the 4.0 that doesn’t have direct injection or take 0w20.
    With the 2gr-fks, I don’t know. DI is harder on oil, and I’ve seen UOAs clearly showing it has been degraded in fewer than 10k miles. Also, 0w20 doesn’t leave an HTHS cushion for fuel dilution, which again is more common with DI.
    It may be possible that modified trucks driven hard in tough conditions using certain 0w20 for 10k intervals could end up with coked cylinders or worn bearings earlier than they otherwise would if other variables were friendlier.
  17. Feb 17, 2024 at 9:56 PM
    #617
    2019 TRD Off Road
    In other words, two things are different between the 4.0 and 3.5: the 3.5 engine is harder on oil, and the specified oil has less margin of safety. Most 0w20s have an HTHS value at or below 2.8 cP. Increased wear can occur around 2.6-2.7 cP. it doesn’t take unrealistic fuel dilution to get to those values.
    These variables are different than on the previous v6s in Tacomas. It doesn’t mean the 3.5 cannot do 10k intervals, but it does mean that there is a higher chance of shear, degradation, and fuel dilution to cause increased wear depending on many variables.
    Anyone pushing to 10k on the third gen’s 3.5 engine should validate that their chosen oil can handle the interval given the driving habits, climate, their particular engine, and typical load by using UOAs. Choosing an oil that exceeds GF-6a and/or has a thicker operating viscosity and higher HTHS than 0w20 can increase the chances of safe 10k intervals.
    Blanket statements that say 10k is always appropriate for every engine technology and every oil and every driving style and every load and every climate, etc. are inaccurate.
  18. Feb 17, 2024 at 10:02 PM
    #618
    SmoothTRD
    Nah I'll stand by 10k changes, any brand synthetic and the engine will last longer than you own your vehicle
  19. Feb 17, 2024 at 10:10 PM
    #619
    2019 TRD Off Road
    That is more likely for you because your engine lacks direct injection and uses 5w30.
    A part of my suggestion is simply to match what you are doing.
    Barsoom likes this.
  20. Feb 18, 2024 at 2:22 AM
    #620
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Good to hear your opinion.
    Keep in mind, there are opinions that differ.
    According to the OWNERS MANUAL, I’ll stay with the 5k oci it calls for.
