Maybe a dumb question
Discussion in '1st Gen. Tacomas (1995-2004)' started by 02-5Lug, Jul 13, 2019.
  1. Jul 13, 2019 at 6:02 PM
    02-5Lug
    02-5Lug [OP] Active Member
    Christian
    Gainesville, GA
    2002 xtra cab 2RZFE 5sp
    This may sound dumb, but after 180k miles most of which is just me driving I have noticed that my truck sits a little lower on the driver’s side, about 3/4” I’m thinking about swapping the front coils and the rear leaf springs left to right. Is that doable or are they side specific. If it was you would you just buy 4 new springs, or do nothing at all.
    I’m not small, but not obese. About 6’1” 220 lbs.
  2. Jul 13, 2019 at 6:10 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Taco lean.
  3. Jul 13, 2019 at 6:14 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Rear leafs are most definetely side specific. However at that mileage, its all likely clapped out and in need of replacement. Also taco lean as mentioned above. The drivers will sag over time due to the weight of the battery, fuel tank, and driver all constantly weighing it down.
  4. Jul 13, 2019 at 6:16 PM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    The "taco lean", as mentioned above, is defnitely more likely to be apparent after your suspension starts to age. Battery, steering column, driver, and fuel tank (plus transfer case on 4x4) all add up to make the left side more of a burden on the suspension.
    If you haven't replaced your shocks, rear springs/front coils, might be time.
    crazytacoman likes this.
  5. Jul 13, 2019 at 9:39 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Lifting the front driver side a little would help correct the lean some. They make lean soacers for this reason
  6. Jul 13, 2019 at 9:52 PM
    jtaco11
    jtaco11 Well-Known Member
    It would be dumber not to ask
  7. Jul 14, 2019 at 2:37 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Hes a 5 lug though if that matters
  8. Jul 14, 2019 at 7:10 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Didn’t pay attention. Think same rules apply. Just its a pain in te ass to work on the fromt suspension. Better off replacing stuff
