Maybe some concerns with my 2007 Prerunner
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GT88, Apr 11, 2007.
  1. Apr 17, 2007 at 5:04 PM
    evile
    evile Well-Known Member
    Orlando, Fl
    2006 DoubleCab TRD OffRoad PreRunner
    Bug shield vent visors Westin Chrome bull bar K&N Airfilter Pioneer CD/MP3/Ipod/DVD head unit KC Daylighters, LED map and dome lights, secondary airfilter removed. Black tube steps, 110v outlet in cab
    well see it could be some thing just with 07 TRD off road doublecabs some seems a lot of people have this model or similar so could be an engine or transmission issue that other models dont have.
    what you could do is contact toyota and ask for a Field service Engineer at least thats what Ford calls them. Bassicly an engineer comes out and helps the tech with the issue and 9 times out of 10 they will fix the concern
  2. Apr 17, 2007 at 6:46 PM
    Sneakers
    Sneakers Member
    I had read on another forum about a problem with a sloppy drive shaft spline. The spline is where the front half and the back half connect at the carrier bearing. Apparently some have greater tolerances than others and that is what causes the rumble feeling on deceleration. I'll try to find the post from whatever forum it was on.
  3. Apr 17, 2007 at 7:08 PM
    GT88
    GT88 [OP] Well-Known Member
    Hi all,
    Ok, first off. I do appreciate all the time from each of you in trying to trouble shoot these uncomfortable concerns.
    The vibration is absolutely not tires, if they have been swapped for a completely different brand of tires and the problem still exists than that fairly well removes tires from the equation.
    The problem is somewhere in the drive line, like the drive shaft, u-joints, carrier bearing, torque converter, ring & pinion, and maybe possibly the flywheel but I doubt that.
    My exact model is a 2007 access cab, 4x2, V6, auto, TRD off road, tow package.
    As far as the engine ticking, it is not and I repeat not a manifold or exhaust issue like the earlier TSB for replacing manifolds. My VIN is far outside of the scope of that recall. Also my ticking is very clearly coming from the drivers side...very clearly. The dealer heard it for all of 2 seconds and closed the hood and said the valve covers need to be removed and the valves and or lifters adjusted. Again...not acceptable in a brand new 400 mile truck.
    I take care of all my mechanical machines. I bought a Toyota based on everyone I have ever spoken to that has said and I quote "I've got 250,000 miles on it and all I've ever done is change the oil and tires" end quote.
    I have listened to 3 other 2007 V6 Tacoma's and none had a ticking sound emitting from the engine compartment.
    I wish those of you the very best with yours and any issues you might have. I will happily accept an EXACT replacement from Toyota. Barring that I permanently part company from them.
  4. Apr 17, 2007 at 7:25 PM
    evile
    Orlando, Fl
    dude they arnt going to give you a new truck if they can fix the one you have
    the law down here states the you get 3 repair atempts or 30 days some thing like that on the same concern then you can go lemon law
    if you are reasonable then the dealership will work with you and help you but if you are an ass about it then they are just gonna blow you off and half ass it
    why is it unacceptable? if all needs to be done is adjust the valves then let them your arnt paying for it. and as for the vibration tell the dealership you want an engineer to come out and look at it we do it all the time at ford. Nothing is perfect toyota doesnt build perfection every single time once in a while there is a bad apple, tell them you want some free shit or some thing
  5. Apr 21, 2007 at 8:30 PM
    Steve762us
    Steve762us Well-Known Member
    Observe your tachometer as you decelerate into that speed range...I think you'll see the revs blip up as your AT downshifts.
    I haven't noticed any engine ticking noises.
  6. Apr 22, 2007 at 11:05 AM
    flyman767
    flyman767 Well-Known Member
    frvrngn, I 've been fighting this surging/lurching for quite some time. I've filed complaints with Toyota Corporate/Dealerships/NHTSA. There actually has been at least two forum members who have had fender benders as a result of this and NHTSA is still doing a preliminary investigation to force Toyota to fix this. I know personally about 10-12 other members have filed official complaints with Toyota and NHTSA on this same issue. However, unless more people complain about this nothings ever going to be done about it. Here's the info to file your complaint and anyone who's experiencing the surging/RPM hang.
    HERE IS THE OFFICIAL NHTSA WEBSITE TO FILE YOUR COMPLAINT:http://www-odi.nhtsa.dot.gov/ivoq/
    HERE IS ANOTHER WEBSITE THAT LETS YOU LOAD YOUR VEHICLE AND SHOWS WHAT COMPLAINTS HAVE BEEN FILED TO DATE. http://www.mycarstats.com/
    __________________
    Toyota Customer CaPhone: 800-331-4331
    Mon - Fri, 5:00 am - 6:00 pm PT
    Sat, 7:00 am - 4:00 pm PT
    Fax: 310-468-7814
    Or send correspondence to:
    Toyota Motor Sales, U.S.A., Inc.
    19001 South Western Ave.
    Dept. WC11
    Torrance, CA 90501 re:
  7. Sep 18, 2007 at 9:39 AM
    Archie07
    Archie07 New Member
    07, 4.0 V6, 6 Spd, Access Cab, SR5
    I too am having the vibration or "rumble" around 18 to 25 mph as well as at 61 mph. My 07 has less than 1000 miles on it. It has been to the dealer for this problem and they say it is the tread pattern on the tires....which I think is B.S. It is going to another dealer next week to see if they say the same thing.
  8. Sep 18, 2007 at 3:33 PM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    I talked to the dealership today about my newly arrived vibration at 68 MPH. They said that it is the rotors on the front. Okay. I don't think that is what it is, but if they try to fix it - then they are admitting that there is a problem. So once we get the ball rolling, I know they will make sure it gets fixed.
  9. Nov 9, 2007 at 7:18 PM
    dthecoop
    dthecoop New Member
    08 prerunner 6.1
    I bought a 2008 Tacoma 3 weeks ago. I just noticed the ticking noise at about 350 mi. I'm taking it back to the dealer ASAP.
  10. Jan 11, 2008 at 10:23 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    S.O.S. ...............Different day!
  11. Jan 12, 2008 at 5:15 AM
    kaisersteiner
    kaisersteiner Active Member
    Mine ticks- 15k miles still ticks. No issues. Bought new tires and wheels and vibration is gone. Very happy with truck and it still ticks. Personally I think it just does that. Gets 20-22mpg on the hwy and has plenty of power.
  12. Jan 19, 2008 at 3:08 PM
    Mike_72
    Mike_72 Member
    Tacoma SR5
    I just picked up my '07 Access cab V6 Auto yesterday and I too have the ticking from the drivers side valvecover and also the shudder when decelerating and around 85 kmh. Only 400 km on it.
  13. Jan 20, 2008 at 8:48 AM
    kaisersteiner
    My friend has one with 40k miles on it and his does it too. I really think they just do that.
  14. Jan 20, 2008 at 9:32 AM
    Mike_72
    Mike_72 Member
    Tacoma SR5
    His has the ticking engine or the shudder?....or both??
  15. Jan 20, 2008 at 12:23 PM
    #35
    kaisersteiner
    My engine sometimes shutters on start up. The shutter while driving was cured by new tires and wheels. Those Dunlop tires they come with are garbage....
  16. Jan 20, 2008 at 2:55 PM
    #36
    Mike_72
    Mike_72 Member
    Tacoma SR5
    Mine has Bridgestones
  17. Jan 20, 2008 at 4:31 PM
    #37
    kaisersteiner
    Is it shuttering when driving or just engine shutter?
  18. Jan 20, 2008 at 5:05 PM
    #38
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    No shudder, but ticking, I feel it's just the characteristics of the engine, runs great. :D
  19. Jan 20, 2008 at 6:02 PM
    #39
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    I don't know if it's the same ticking that folks are hearing but it's the nature of VVT-i to have ticking.
    The "shudder", I have it, and more and more it seems like it only happens when the a/c is on.
  20. Jan 21, 2008 at 10:22 AM
    #40
    Mike_72
    Mike_72 Member
    Tacoma SR5
    it shudders when accelerating from a stop under light throttle and at around 90km/h and also when coming to a stop.
