Maybe Toyota Won't Let the Manual Die After All
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoJonn, Aug 11, 2017.
  1. Aug 11, 2017 at 9:56 AM
    TacoJonn
    TacoJonn [OP] Well-Known Member
    Jon
    Laramie, Wyoming
    '13 DCLB Sport 4x4, '78 FJ40
    Toyko Joe likes this.
  2. Aug 11, 2017 at 9:58 AM
    harrycary
    harrycary Well-Known Member
    Harry
    2016 Tacoma TRD Off Road
    The hammer and specter208 like this.
  3. Aug 11, 2017 at 9:58 AM
    03 NIGHT TACO
    03 NIGHT TACO Well-Known Member
    Jack
    Eastern Washington
    3.4 5 speed TRD
    Kings/Dakars/ARB
  4. Aug 11, 2017 at 10:02 AM
    TacoJonn
    Jon
    Laramie, Wyoming
    Maybe if you like driving the numb, lethargic slushbox auto.
  5. Aug 11, 2017 at 10:03 AM
    harrycary
    Harry
    I HATE the auto trans. It is the biggest piece of cost reduced sh!t I ever experienced in a modern automobile.
  6. Aug 11, 2017 at 10:13 AM
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    So you don't like automatics, but you are interested in a new system that takes control away from a driver of a manual transmission (automatic coasting, gear change restrictions)?
    rlx02, cosmicfires and bullaculla like this.
  7. Aug 11, 2017 at 10:19 AM
    BarcelonaTom67
    BarcelonaTom67 Lost in Translation....
    Tom
    Laurel County, Kentucky
    2017 Barcelona Red Off-Road DCSB M/T
    I must have gotten a model year 2020 rather than a 2017. Mine can already go into neutral when going downhill (when I push in the clutch and shift into neutral :fistbump:)
    joeyv141, Leonel, PvilleJohn and 7 others like this.
  8. Aug 11, 2017 at 10:21 AM
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    I know nothing besides the posted article, but from info in the article, I do not want this. WTF ,miss shifting 2nd to 5th or whatever and if I want to coast... WHOA I slip into neutral :rofl::rofl:
  9. Aug 11, 2017 at 10:21 AM
    Snwghst
    Snwghst Well-Known Member
    What about compression braking from the engine?
    I constantly use it, especially when I lived around mountain passes
    Dannyblues, Garyji, rlx02 and 3 others like this.
  10. Aug 11, 2017 at 10:22 AM
    TacoJonn
    Jon
    Laramie, Wyoming
    If incorporating this system means people can still row their own gears then I am all for it. My 2013 is actually an auto (my 78 FJ40 is not however) and I don't mind it but wish it were a manual. I am not against autos. Just against the death of manuals. One of the reasons manuals are dying is because autos get better MPG now. This might help manuals narrow the gap a bit.
  11. Aug 11, 2017 at 10:23 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Meh. Toyota just filed a patent. Doesn't mean it will get implemented. Boeing has patent US20110018740 for a warning system that pokes the pilot in the ass. To my knowledge it has not been implemented.
  12. Aug 11, 2017 at 10:24 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    It seems like having the vehicle shift itself into neutral when you're going down a hill would be counterproductive. Modern fuel injectors already close when you're coasting, so the engine is just cycling and using zero fuel. If they have the transmission shift to neutral (and therefore disengage the engine), they'll have to use fuel to keep the engine idling.
    The reason that the old Saabs used a freewheel mechanism was because they were a two stroke.
    Engine braking? Zero lubrication to the engine. Very bad.
    Stepping on the throttle to keep the engine lubed? Very fast downhill speed. Very bad.
    Stepping on the throttle and the brakes to control your speed while lubing the engine? Very bad.
    The solution? Freewheeling.
    But since modern cars are neither 2 strokes OR carburated, the tech doesn't make any sense to pursue to me. :notsure:
    rlx02, jowybyo, brich999 and 2 others like this.
  13. Aug 11, 2017 at 10:27 AM
    Schlappesepple
    Joe
    2020 4Runner ORP
    I hear you.
    Reading the article, I'm kind of picturing a tiptronic transmission with a stick gear selector instead of a sequential lever / paddles. It could still have the benefits of gear selection, but keep you from blowing stuff up.
  14. Aug 11, 2017 at 10:28 AM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    I thought bmw has this patent already?
    As far as injectors I assume they will change so they also cut in this "neutral mode" is activated
  15. Aug 11, 2017 at 10:33 AM
    rnicholls
    rnicholls Well-Known Member
    2016 TRD OR DCLB
    LOL
  16. Aug 11, 2017 at 10:39 AM
    Comb
    Comb Known Member
    2017 TRD Sport 4x4 DCSB 6MT BBP ABCDEFG
    OVTune Verified Purchase
    mbarbay, Lawfarin, m603holden and 3 others like this.
  17. Aug 11, 2017 at 10:53 AM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    No clutch = not a manual.
  18. Aug 11, 2017 at 2:13 PM
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    That would be silly.....modern EFI engines don't use fuel when coasting. Its completely cut-off. If you coast in neutral, you must supply fuel to idle. Are they going to let the engine turn off like start/stop technology?
    Edit: actually read the article now...OK...Start/Stop was mentioned.
  19. Aug 11, 2017 at 2:15 PM
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    That is my guess. They are not idiots, they will probably set it up so it still cuts in neutral or something
  20. Aug 11, 2017 at 2:16 PM
    harrycary
    Harry
    That would be a great way to sell more starters.
