Maybe Unique A/C Problem?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SManZ, Aug 5, 2014.
  1. Aug 5, 2014 at 3:30 PM
    SManZ
    SManZ [OP] Sold the Taco in June 2020
    Fauquier County, VA
    Current, 2020 Ford Super Duty Tremor, Previously 2010 Supercharged 4x4 Tacoma Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    I've searched the forums pretty good and cannot find another post with these similar symptoms. Most AC problems seem to come with a blinking AC button light or a noisy compressor and I have neither.
    The clutch on my A/C compressor engages intermittently, about every 3 or 4 secs at idle. The result is a barely cool truck at max cool settings.
    I've replaced both the magnetic clutch relay and the A/C relay in the fuse box under the hood.
    I've recharged the system. It was slightly low.
    Blower motor and vent switches work fine at all settings.
    AC indicator light stays on, does not blink.
    No funny noises from compressor, pulley turns smooth.
    Unrelated to the AC diagnosis, I replaced the serpentine belt about 1k mi ago.
    The AC does work better at higher rpms. Not sure if its because the compressor is engaged the entire time or if its just turning faster for the periods that it is engaged.
    What are some other things I can check?
    Thanks!
  2. Aug 5, 2014 at 3:35 PM
    BAMS
    BAMS Well-Known Member
    Ray
    New Hampshire
    2011 TX TRD Access
    Sounds like it is over pressured. I went through this last week on my wifes car. The fact that it cycles on so much leads me to believe that there is too much pressure. Just my experience.
  3. Aug 5, 2014 at 3:39 PM
    SManZ
    Fauquier County, VA
    Thanks for the reply!
    How can I bleed off some pressure? I do have the hose with the gauge and fitting that pierces the cans of refrigerant. If I attach this to the low pressure port without the refrigerant can and pull the trigger will it vent out of that end or is there a one way check valve on these things?
  4. Aug 5, 2014 at 3:43 PM
    BAMS
    Ray
    New Hampshire
    2011 TX TRD Access
    Check the pressure with the gauge on the can. If it is too much, use a nail or small screwdriver on the low pressure side to bleed some off. Be careful not to freeze your fingers though.
  5. Aug 5, 2014 at 3:49 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Did you use a manifold gauge set that attaches to both the high and low pressure sides or one of the AC kits that only have a low pressure hose? There could be several issues that cause poor cooling such as a partial blockage, etc... You may not be able to tell with just a low pressure gauge. Hopefully it's just overcharged and pulling a little out will fix it.
  6. Aug 5, 2014 at 3:51 PM
    TacomaToday
    TacomaToday Well-Known Member
    Keye
    Orange
    BSP 2010 4x4 Double Cab LB
    De-Badged, Satoshi Grill/Grillcraft insert, SnugTop lid, LS460R Retrofit Headlights by AndrewTRS. VLED 5000K LED Foglight bulbs, Blacked Depot Tail lights with VLED bulbs.
    I had a similar problem, my AC unit would randomly just stop working while I'm driving. The dealer changed out a relay switch in my tacoma 2010. It was causing my AC line to freeze up completely so blower/clutch wouldn't turn on. Easy way to check is when it's happening, open your hood and look at the AC line, you'll start seeing frost build up on the line. Part number is TOY 90987-02028. Maybe that might be your problem. My dealer was running into a couple trucks with this issue.
  7. Aug 5, 2014 at 4:01 PM
    SManZ
    Fauquier County, VA
    Thanks much for the info! I'll check the system pressure, bleed off if necessary, and report back :)
    vssman, I used a single gauge on the low pressure side.
    TacomaToday; I replaced that relay yesterday :) Found it at NAPA...expensive little bugger at $27. Its for the magnetic clutch. The other relay is in a smaller box attached to the main fuse box under the hood. It has a single relay for A/C in it. :confused: Replaced that one too.
  8. Aug 5, 2014 at 4:07 PM
    evile
    evile Well-Known Member
    Orlando, Fl
    2006 DoubleCab TRD OffRoad PreRunner
    Bug shield vent visors Westin Chrome bull bar K&N Airfilter Pioneer CD/MP3/Ipod/DVD head unit KC Daylighters, LED map and dome lights, secondary airfilter removed. Black tube steps, 110v outlet in cab
    If it works at higher rpms 9/10 times you have a bad compressor
  9. Aug 5, 2014 at 4:37 PM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Ok. The can should tell you that the pressure is correct when the compressor is on. Make sure that is the reading you're using and not when it's not cycling. You can overfill if measured when the compressor is off.
  10. Aug 5, 2014 at 4:50 PM
    OCNutty
    OCNutty Well-Known Member
    Northern, Va.
    Silver Prerunner DC v6 SR5 Tow
    If it's cycling that fast, it's either way overcharged (covered above), very undercharged (low pressure drops fast when compressor kicks on which opens low side switch, but high pressure doesn't go up much) or possibly there's a plugged expansion valve (expansion valve is in evaporator).
    how do you know it's undercharged (slightly low) in op? with a full gauge set?
  11. Aug 5, 2014 at 5:05 PM
    evile
    Orlando, Fl
    what are your pressures reading at idle with max ac on
  12. Aug 5, 2014 at 5:57 PM
    SManZ
    Fauquier County, VA
    It was reading around 50psi initially. After bleeding some off its reading just over 40psi. Compressor was running constantly in the parking lot after I bled off pressure. Going to run it around tomorrow and see how it does.
    Hopefully this fixes it. This experience has allowed me to learn way more about ACs than I ever wanted to haha. Seemingly complicated stuff.
  13. Aug 5, 2014 at 7:01 PM
    evile
    Orlando, Fl
    This
  14. Aug 5, 2014 at 7:07 PM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Too much pressure then. I bet it will start working fine now
  15. Aug 6, 2014 at 7:53 AM
    OCNutty
    Northern, Va.
    Watch it and make sure compressor is cycling in normal usage. If it's running full time, esp in moderate weather, there's still something not quite right. In humid weather should show a pretty good drip from the condensate tube.
  16. Aug 7, 2014 at 9:09 AM
    SManZ
    Fauquier County, VA
    Seems to be running fine and blowing nice and cold! This was a thankfully easy fix :)
  17. Aug 7, 2014 at 9:14 AM
    BAMS
    Ray
    New Hampshire
    2011 TX TRD Access
    Nice! Glad to hear it.
  18. Sep 8, 2014 at 7:31 AM
    muddog15
    muddog15 Member
    2012 Tacoma 4x4
    I have a 2012 Tacoma, I'm still under my warrenty I also bought the extended warranty. I'm trying to get the dealer to fix a similar problem with my A/C. It doesn't want to cool if I'm sitting and the truck is running. They replaced the clutch recently. What else can make the A/C blow hot air or stop cooling if the truck sits at an idel for a while? They want to reproduce the problem before they fix it, but it's intermittent.
  19. Sep 8, 2014 at 11:22 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Low charge or over charge is the most common cause. Have they checked the pressures?
  20. Sep 9, 2014 at 3:54 AM
    muddog15
    muddog15 Member
    2012 Tacoma 4x4
    They said they checked the entire system when they replaced the clutch. I'm not sure what they did, I'm not a DIY mechanic, so I don't know much about this kind of stuff. I have always had/paid somebody else do the work for me.
