Mazda Rims on a stock 5 luger
Discussion in '5 Lug' started by TacomaGuyEH, Jan 19, 2013.
  1. Jan 19, 2013 at 3:54 AM
    TacomaGuyEH
    TacomaGuyEH [OP] Member
    toronto,ontario
    tacoma SR5
    I found a set of Mazda 5 rims 17 x 6.5 with a back spacing of 42 to 50 would like to know if this back spacing would work if so which tires would you recommend with this size rim.
  2. Jan 19, 2013 at 5:31 PM
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    whats the bolt pattern?
  3. Jan 19, 2013 at 8:30 PM
    TacomaGuyEH
    toronto,ontario
    tacoma SR5
    2008 Mazda 5 Bolt Pattern (in):5x4.50
    Bolt Pattern (mm):5x114.5
    Offset Range (mm):42 to 50
    Front Center Bore (mm):67
    Rear Center Bore (mm):67
    stud size 12x1.5
  4. Jan 19, 2013 at 9:04 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    Test fit the wheel if you can. 2nd gens are picky with wheels
  5. Jan 23, 2013 at 9:10 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    Wheel will work. As for preferred tire size, 235/45R17 should work, same outer dia. and width as Kelson's tire.
  6. Jan 24, 2013 at 11:40 AM
    TacomaGuyEH
    toronto,ontario
    tacoma SR5
    How about 235 65 R17 will that work.
  7. Jan 24, 2013 at 2:17 PM
    KenLyns
    Belly of the Beast
    That's a 30" tire. Not sure if it'll work at stock height, but will for sure work if the truck is lifted.
  8. Jan 24, 2013 at 3:46 PM
    carattini
    carattini Well-Known Member
    David
    Puerto Rico
    08 base model
    I put a Mazda CX7 on my Taco for figment purpose and they fit perfect Fallow the link in the signature.
