Mazda's New "Skyactiv" Technology
Discussion in 'Off-Topic Discussion' started by myname150, Oct 26, 2011.
  1. Oct 26, 2011 at 3:48 PM
    myname150
    myname150 [OP] Well-Known Member
    I've been seeing the new Mazda commercials and they've been toutuing this new Skyactiv stuff.
    Supposedly their new Gasoline motor has a compression ratio of 14.0:1, the highest of any passenger car? The Skyactiv technology is also implemented in the chasis and transmission.
    The Diesel is pretty impressive too...Man, If Mazda can pull off a small diesel, Toyota can too. They already have the amazing 3.0L D4D from the Hilux, would it really need that much changing?
    Here's the gasoline motor:
    http://www.mazda.com/mazdaspirit/skyactiv/engine/skyactiv-g.html
    Their Diesel:
    http://www.mazda.com/mazdaspirit/skyactiv/engine/skyactiv-d.html
    What do you guys think?
  2. Oct 26, 2011 at 3:51 PM
    myname150
    Oh bah :p.
    If Mazda can do it so can Toyotaaa!
  3. Oct 26, 2011 at 3:51 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    :facepalm:
    I didnt bother reading the article but Im assuming you have to run race gas in that gas ENGINE.
  4. Oct 26, 2011 at 3:53 PM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    well maybe toyota should listen to their largest fan base in the us. the country they consistently screw out of their awesome little diesel mill and just offer one across the model range already lol.
  5. Oct 26, 2011 at 3:53 PM
    myname150
    I saw High Compression, and I instantly thought you'd definitely need premium gasoline.
    lol, i wonder what mazda will do with owners who happen to fill up with 87 :D.
  6. Oct 26, 2011 at 3:54 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    i like mazda they make a nice little car i traded a loaded up 2010 6 speed mazda 3 i on my tacoma actually i sort of miss it. they make a great product imo
  7. Oct 26, 2011 at 4:09 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    This takes things a step further still.
    Long story short, with a 4 to 1 header design that has short runners, exhaust gases from cylinders will actually pressurize the manifold and hinder the exhaust from leaving the other cylinders completely. This means that the heat in each cylinder is much higher because it never truly gets rid of all the hot exhaust gas.
    The 4 to 2 to 1 design (matching cylinders by firing order) fixes this problem because the exhaust gas would have to travel such a great distance down the manifold and then back up to get to another cylinder....it doesn't affect it. This leads to lower cylinder temperatures and will reduce knock meaning you don't need higher octane fuel.
    Simple concept when you think about it but really great benefits just from being clever.
  8. Oct 26, 2011 at 4:42 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    cool!
    Ive wanted a mazdaspeed3 for a while now, not enough to get rid of the truck though.
  9. Oct 26, 2011 at 5:39 PM
    myname150
    As Did I.
    Yeah. I'd keep the truck. I'll always have a truck.
  10. Oct 26, 2011 at 6:50 PM
    ItalynStylion
    Steven
    DFW, Tx.
    My friend had a speed3. Makes a TON of power with mods but you'll need to replace the fuel pump to get past a certain power point. The stock cam-driven one is wimpy as fuck. They do have problems with motor mounts (probably because they're really torquey) and there is an issue with carbon buildup on the piston heads causing rod knock and early engine failure. My friend's was replaced under warranty, luck him.
    Just fyi
  11. Oct 26, 2011 at 6:55 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Yeah I've heard of a lot of them blowing holes in the block for no apparent reason.
  12. Oct 26, 2011 at 7:01 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    my bronco had speed holes on the rockers. Naturally made by rust.
  13. Oct 26, 2011 at 7:10 PM
    mntbiker2008
    mntbiker2008 First I derp.. then I herp
    Aaron
    Cincinnati, OH
    93 Pick up 4x4 (sold), 10' Mazda 3
    I have noticed, even from day one, a little bit of a knocking sound every now and then. That is about the only thing I have to complain about with the engine. I have the 4 cyl. 5 speed manual and that sucker can get up and haul some ass real fast. I drove the automatic and i was practically saying "yabbi dabba doo" and flinstoning it up the road. lol
    Really curious to see where they take this new technology.
  14. Oct 26, 2011 at 7:55 PM
    ItalynStylion
    Steven
    DFW, Tx.
    Mazdaspeed3 or normal 3? I thought the speed3 was a 6speed manual?
  15. Oct 26, 2011 at 8:10 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    In the end, we buy Toyotas because of their powertrain reliability. There are some technologies Toyota opted not to use in truck engines for durability reasons. For example, direct injection is in the LS460 V8, but not in the GX460/Tundra V8 based on the same block. Hell, the LS400 4.0 V8 was making 280 horsepower 15 years ago, without VVTi.
  16. Oct 26, 2011 at 8:21 PM
    futuretacoowner
    futuretacoowner Well-Known Member
    Andrew
    Canada
    02 2.7L xtra cab
    I want diesel Tacoma!!!
    and the 4-2-1 exhaust is pretty cool.
  17. Oct 26, 2011 at 8:24 PM
    KenLyns
    Belly of the Beast
    I believe most 4-cyl sport bikes have 4-2-1 headers available either OEM or aftermarket. They run pretty high compression ratios too.
  18. Oct 27, 2011 at 6:17 AM
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    Bilstein 5100's @ 2.0", Wheelers 1.5" AAL, 265/75/16's
    I am going to look into getting a 5 door hatchback with the skyactiv 2.0 gas motor in a few years as a DD.
  19. Oct 27, 2011 at 9:34 AM
    KenLyns
    Belly of the Beast
    Don't see any advantage of the Mazda3 over a Subaru Impreza.
  20. Oct 27, 2011 at 11:36 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    not awd so simpler. better MPG. Cheaper to buy.
