mb tko fit 17-8.5 6 139.7 25mtb
Discussion in 'Wheels & Tires' started by 06tacoma2013, Mar 10, 2013.
  1. Mar 10, 2013 at 2:46 PM
    06tacoma2013
    06tacoma2013 [OP] Member
    Hey guys I'm new here having transfered from a FJ to a Tacoma. My question is I have found a good deal on some MB TKO rims that are hub centric and the size is 17/8.5 6 139.7 25mtb. Same rim for my truck on discounts website has the same rim but with 6mtb, so is that much of a difference? the rims came off of a chevy Z71. Ive been reading almost every thing on this forum but havent seen an answer. Any help would be great
  2. Mar 10, 2013 at 2:56 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Wheels that are hub centric for a Chevy will not fit a toyota. The hub bore is too small by a good amount. 78mm vs 106mm
  3. Mar 10, 2013 at 3:01 PM
    06tacoma2013
    so if its both hub and lug centric its still no good for toyota, right? the guy is telling me its both hub and lug centric, and i can remove the center hub ring
  4. Mar 10, 2013 at 3:05 PM
    KPT
    09 Prerunner
    If you can remove the center ring and the bore is over 106mm then it will work.
    However those have too much offset anyways for a toyota. They actually have more backspacing than the stock wheels.
  5. Mar 10, 2013 at 3:08 PM
    06tacoma2013
    so should i just get the ones that are 6mtb? or look for a different rim?
  6. Mar 10, 2013 at 3:13 PM
    KPT
    09 Prerunner
    That depends on what size tires you want to run now, and may want to run in the future.
  7. Mar 10, 2013 at 3:16 PM
    06tacoma2013
    just looking to run 265/70/17. nothing bigger. put the 3 inch lift on in the summer. wish i could go with the chevy takeoffs but if they dont fit they dont fit.
  8. Mar 10, 2013 at 3:20 PM
    KPT
    09 Prerunner
    The +6 offset will be okay for 265s, but if you want to go up to 285s after the lift, they will sit too close to the uca.
  9. Mar 10, 2013 at 3:22 PM
    06tacoma2013
    what offset will i need for 285? wifes running 285 on her H3
  10. Mar 10, 2013 at 3:53 PM
    KPT
    09 Prerunner
    4.5" of backspacing, and a 3" lift
