Mean Green Gear Reduction Starter (Item #: MG17672-KK)
Discussion in '1st Gen. Tacomas (1995-2004)' started by alphabravo, Jun 25, 2015.
  1. Jun 25, 2015 at 5:29 PM
    alphabravo
    alphabravo [OP] Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    EDIT: Dropbox is discontinuing support for the "Public" folder. Most of my links in this thread will die 9/1/2017 until I recreate using their new shared folder system. In the meantime, here are PDF copies of the first few pages of the thread.
    Page 1
    Hi guys,
    I just got this starter from MG and wanted to start a thread for it. The specs on their website are pretty brief and generic with respect to size and performance. They claim "100% more cranking power" and 1/3 smaller than OEM.
    http://shop.mean-green.com/2004-95-TACOMA-34L-MG17672-KK.htm
    Weight: 9.75 lbs
    Length overall (from face of mating plate to tail end): 7"
    Length of gear/bearing housing: 5"
    Diameter of solenoid: 2-7/8"
    Circumference overall (oblong): 15"
    Gear reduction is 4.4:1
    At this point I don't have any specs on the actual torque/RPM etc.
    opteron likes this.
  2. Jul 5, 2015 at 3:04 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Ok so I finally got this thing on. Some pics and video below. It sounds pretty sweet and definitely much stronger and faster than the OEM starter.
    I will say that I'm a bit disappointed in MG for advertising this as 1/3 smaller. The housing is identical to OEM. So in other words, it is not any smaller. It does feel a bit heavier so I'm thinking that it has a denser winding on the coil and perhaps some upgraded bearings and different gearing. I haven't gotten any response back from MG on the specific specs.
  3. Jul 7, 2015 at 7:09 PM
    motorhead310
    motorhead310 Well-Known Member
    Pomona , Ca
    2006 Taco Pre-Runner
    Looks good. Why did you choose aftermarket over OEM? Curious as my truck has 240,000 miles and I'm sure I will need a starter sooner than later.
  4. Jul 7, 2015 at 8:42 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    The OEM starter is a bit gutless, especially when it gets cold. I can actually count the turns it is so slow.
  5. Jul 7, 2015 at 8:50 PM
    LogCabins
    LogCabins Well-Known Member
    Robert
    Oahu
    99 SR5 3.4L 4WD
    Was it a bitch to get the old one out and put the MG in? Did you go through the wheel well or from underneath
  6. Jul 7, 2015 at 10:57 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    I needed about 14" of extensions and a universal socket from underneath. Truck on ramps, pull the transmission dipstick, drop the skid plates. It was easier than I was expecting but I took my time and also did the big 3 wiring upgrade.
  7. Jul 7, 2015 at 11:45 PM
    LogCabins
    Robert
    Oahu
    99 SR5 3.4L 4WD
    Thanks for the feedback.....been contemplating buying one for a while, current starter going out so I guess it's time to pull the trigger
  8. Jul 8, 2015 at 8:55 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    While I am all for aftermarket upgrades, I rebuilt my starter for $10 on Amazon, so that's always an option too.
