Mech LSD or open diff?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toy Yoda, Sep 9, 2012.
  1. Sep 9, 2012 at 2:01 PM
    Toy Yoda
    Toy Yoda [OP] gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
    Specs:
    06 DCLB SR5 prerunner
    I'm confused because my rear diff has the "LSD oil Only" sticker and I've read thats an easy way to tell if you have the mechanical lsd, i also read that if you jack up the rear off the ground and spin one tire, if the other spins in the same direction you have the LSD, well i have the sticker but when i spin one tire the other tire spins in the opposite direction, when put in reverse both back tires spin and when put in drive (while still in the air) both tires spin as well, the sticker confuses me but I'm pretty sure its open diff based off of the tire spin directions, any advice? other than buying a locker hahaha
  2. Sep 9, 2012 at 2:33 PM
    landphil
    landphil Wishin' I was Fishin'
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    You probably have a LSD diff with a worn out clutch pack.
  3. Sep 9, 2012 at 3:11 PM
    Toy Yoda
    Garrett
    06 DCLB
    How does that get worn out? Idk if it matter but it's an automatic with only 57k miles
  4. Sep 9, 2012 at 4:55 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    It would certainly be premature wear at that milage, but thats certainly possible. Limited slip is just that, limited. Which means the clutch pack limits the differential action, it does not lock it completely like a locker. If someone was stuck with one wheel with good traction, the other very poor traction, it will still slip. Hammering the throttle in a situation like that will very quicly end the clutch pack's life. Did you recently get this truck?
  5. Sep 9, 2012 at 5:10 PM
    lipster
    lipster Well-Known Member
    Northern MN
    2004 ext cab 3.4 auto TRD
    License plate frame
    running 2 different sized tires (like one old, one new) will wear it out as well.
    Just drive it.
  6. Sep 22, 2012 at 10:48 PM
    Toy Yoda
    Garrett
    06 DCLB
    Had the truck for over 40k miles, all the tires were put on at the same time, don't think I've worn anything out, 85% of my driving in highway
  7. Sep 22, 2012 at 10:59 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2008 F-350 Powerstroke
    Step on it when you are making a turn onto a street. You'll know. The inside tire will break loose every time and you'll likely fishtail. One thing I hate about mine. Wet roads are the worst. It annoys me even more because nine times out of ten my BFG's will bark a little and cause undue attention, even though I'm not really stepping on the gas.
  8. Sep 23, 2012 at 8:00 AM
    Brandon H
    Brandon H Well-Known Member
    Newhall, CA
    07 DC Offroad
    FUlly Locked, Icon Extended Travel CO's w/ remote resis., Alcan AAL's,Icon Remote Resi Rear Shocks, All Pro Front bumper w/ warn 9.5xp,winchline synthetic winch cable,All Pro IFS Skid plate, OME Shims, OME Carrier Bearing drop, Trail Gear Sliders, Yakima Load Warrior Basket, OEM Roof Rack, Hi Lift Extreme, Cobra model 19, Wilson Lil Wil Antenna, Yaesu ft-7800
    Its normal. Drive it. Make sure when it comes time for an oil change that you use a gear oil with a friction modifier (AKA LSD Oil) only.
  9. Sep 23, 2012 at 9:34 AM
    Toy Yoda
    Garrett
    06 DCLB
    I definitely know what you're talking about...
  10. Sep 23, 2012 at 3:07 PM
    brian
    Elizabeth City, NC
  11. Sep 23, 2012 at 3:38 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Locker time
  12. Sep 24, 2012 at 10:02 AM
    Toy Yoda
    Garrett
    06 DCLB
    this
  13. Sep 24, 2012 at 11:20 PM
    brian
    Elizabeth City, NC
    Meh. I would vouch against it. Unless you're hardcore wheeling.... a little education on how to use a LSD does wonders. I've gone plenty of places with mine.
  14. Sep 24, 2012 at 11:24 PM
    krimson
    krimson Nothin
    TRD Off Road
    He's A PreRunner, so A locker would give him more help than an LSD would for his setup.
  15. Sep 25, 2012 at 6:43 AM
    Brandon H
    Newhall, CA
    07 DC Offroad
    This is coming from the guy whose signature says lockers are for pussies? LOL
