Mechanic installed my new rack.. Now this defect... Does this look bad?
Discussion in '1st Gen. Tacomas (1995-2004)' started by prerunnerSD, Oct 6, 2021.
Thread Status:
Not open for further replies.
  1. Oct 8, 2021 at 8:06 PM
    #101
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    Points..
    No threads of this caliber shall die before a Friday
    If OP is that concerned he should negotiate with his mechanic. OP pays for a new part and mechanic installs the part for his cost of labor.
    I want to go to Japan, or get some sushi before it is too late tonight.
  2. Oct 8, 2021 at 8:33 PM
    #102
    prerunnerSD
    prerunnerSD [OP] Well-Known Member
    USA
    01 Tacoma Limited 6 cylinder 4X4
    Grill guard Front and rear Bilstein 5100's Front Coilovers Rear AAL "I Brake for Tailgaters" Firestone Destination A/T (P265/75/R16)
    Here's a taste of Japan. This is pics from 2019 when I went to the Tokyo Skytree. Tallest self-supporting tower in the world and the second tallest structure in the world after the Burj Khalifa. It dwarfs anything in the USA... Its also built on one of the most earthquake prone areas on the planet, an engineering marvel. Tokyo is BOLD. Talk about a flex... its owned by the local train company "Tobu" and its sole purpose is basically a tourist/leisure attraction and also a place to mount antennas. Tokyo is the best example I've seen of super advanced modern life blended with traditional culture.
    Here's another from the hotel.
  3. Oct 8, 2021 at 8:44 PM
    #103
    brs127s
    brs127s Well-Known Member
    O'Fallon, MO
    04 D-Cab 4x4 Limited TRD
    TRD Headers, Aero Turbine AT2525XL Deckplate Mod, TRD tranny cooler, King Coilovers, LR UCAs, Alcan 5 Leaf springs and Bilstein 5100s, Shrockworks front bumper, CBI rear bumper.
    OP...do you work on your own stuff?
    I can tell you what your mechanic did is what 99% of all mechanics do. As others have said, they do whatever is necessary to get the job done in as little time as possible.
    Case in point, I had to replace the front exhaust pipe from the manifold to the cat on my son's 93 Toyota pickup. I can guarantee you that this had never been off his truck since it was built. The bolts that held the front pipe to the cat were rust-welded in the holes that went through the flanges on the pipe and cat. I had to cut, grind, drill, pry; and beat the heck out of the bolts and flanges to get it apart. Midway through that process I was discouraged as he'll and called my buddy who is a mechanic. He told me that shops do the same thing and to just keep smacking away till it came apart. Well I finally got everything apart and replaced the front pipe. Did everything look perfect when I was done? No, but everything bolted back together and the flanges all sealed back together. Am I worried about it? Nope...my kid is back on the road and not sniffing exhaust fumes in the cab anymore.
    Just looking at the pic you provided, he hit the part with a chisel and creased one of the heaviest parts of the rag joint. The metal is not brittle and was soft enough to crease. The pinch bolt went back in and tightened down without damaging the threads, so there was no structural damage done. Just drive your truck and enjoy it.
    prerunnerSD[OP] likes this.
  4. Oct 8, 2021 at 9:06 PM
    #104
    prerunnerSD
    USA
    Heres another pic
    I do work on certain things, like oil changes, fluid changes. I also put the new bushings in the rack on Sunday. When it comes to putting in a new rack I have to defer to a trained mechanic because I'd rather not F it up. I'm going to switch out my sway bar end links and bushings next. That's something I can do without help.
    If it were my exhaust dented I wouldn't question it as much.. to me that would be like a dent in the bumper.. That's "down stream" to me and has more margin for error. Exhaust work is kind of an art form anyway with all the creative welding people do. Guess I'll just leave this be for now... If I ever wanna trigger the trolls tho I'll be sure to have it done and post lotsa pix, lol. I'm actually tempted.
  5. Oct 9, 2021 at 8:14 AM
    #105
    se7enine
    se7enine MCMLXXIX
    Reno, NV
  6. Oct 9, 2021 at 8:25 AM
    #106
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    $100 bucks he drives in his truck alone with 3 masks and gloves on!!!:eek::eek::eek:
  7. Oct 9, 2021 at 12:15 PM
    #107
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    Good contribution
  8. Oct 11, 2021 at 2:54 AM
    #108
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    This is the most depressing view I could only imagine. :puke:I guess, only the moon landing can beat that
    :threadjacked:
  9. Oct 11, 2021 at 3:20 AM
    #109
    TrdSurgie
    TrdSurgie revised
    Oahu
    Read the first page of posts. Dumpster fire.
    It's fine. Good luck.
  10. Oct 13, 2021 at 4:04 PM
    #110
    prerunnerSD
    USA
    I guess things hit differently when you look out the window from the Ritz Carlton Tokyo..
    Seemed like a fine view to me for a city in the northern hemisphere in January. (winter)
  11. Oct 13, 2021 at 4:44 PM
    #111
    RysiuM
    Rysiu
    Whatever makes you happy :D
    My preference of the "view of the city on the northern hemisphere" is this
    Rastopher likes this.
  12. Oct 13, 2021 at 5:09 PM
    #112
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
  13. Oct 13, 2021 at 5:15 PM
    #113
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    OP after looking at that side view pic you posted of your truck, I see it's in really excellent shape. I think if a picture and description of how nicely you keep your truck had also been put in the first post, it would have helped to have people understand a little bit more about your being frustrated. Not everyone would have necessarily agreed, but at least been a little more understanding. I get why you would want that part to be unflawed after the work at this point, but you're not running any risk with it the way it is. I would only even consider replacing it if you were working on the rack or steering column for other reasons and labor wouldn't be a huge cost.
    As I said in my original post, I would absolutely be looking at videos from @Timmah! 's channel on YouTube and DIY write ups on here that relate to any other service you have in the future if you're going to do the work yourself or with someone else and school yourself on the tips and challenges of each repair. It will help you keep a mechanic informed or see where you can assist by pre-soaking joints / bolts, etc. that are prone to getting stuck in penetrating fluid.
    https://www.youtube.com/c/TimmyTheToolman
    Timmah! and prerunnerSD[OP] like this.
  14. Oct 13, 2021 at 6:59 PM
    #114
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Nah, bigger pry bar might be more accurate
  15. Oct 13, 2021 at 7:21 PM
    #115
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Well.....I enjoyed the post......sorry a bunch of trol-bullies showed up....
    This is one of the reason I do everything on my truck.....except for the stupid things(things I'd be stupid to attempt)...
    like rebuild my engine....or do an alignment........
    Thank the good Lord there's a ton of UT videos on these very trucks....
    OR I'D BE SCREWED......
  16. Oct 13, 2021 at 7:23 PM
    #116
    O'Silver_Taco
    MD
    However there's bunch of sharp taco owners here....
    always check with these guys 1st....when you get hit with something...
    Bunch of em own a family pack of these......
    And iT looks like its easy to piss SOME of them off.......
Thread Status:
