Mechanic / Maintenance Advice? **Random Taco Pics** lol
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Airmanaaron, Mar 11, 2022.
  1. Mar 11, 2022 at 6:29 PM
    Airmanaaron
    Airmanaaron [OP] Member
    2006 Tacoma DoubleCab PreRunner
    Hey There,
    2006 Tacoma 4.0 PreRunner, with 149K miles. Just did an oil change and inspection at the dealer and they gave me a crap ton of maintenance recommendations. I’ll list them out, but I was wondering if I could get some advice on how urgently I need to get these things done, as there really is no record of them being done from previous owners. Thank you!
    • Brake fluid service
    • Front diff service
    • Rear diff service
    • Transfer case fluid service
    • Transmission fluid service
    • Coolant service
    • Tune up* assuming spark plugs / water pump etc
    • Does have Timing cover leak
  2. Mar 11, 2022 at 7:08 PM
    MA_TACO
    MA_TACO Well-Known Member
    Wesley Chapel, FL
    1. Brake fluid service - If brake fluid in reservoir is showing clear no need for service
    2. Front diff service - it's a Prerunner. It doesnt have a front diff
    3. Rear diff service - something you can do at home easily
    4. Transfer case fluid service - Again, it's a Prerunner. It doesnt have a transfer case
    5. Transmission fluid service - Another thing you can do in the comfort of your drive way
    6. Coolant service - not really needed unless you have a leak somewhere
    7. Tune up - Another easy DIY, sparkplugs, air filter, pcv valve etc
    8. Timing cover leak - thats a known Taco issue for early model 2nd gens. Big job if you do it yourself but it's not mandatory. I bought a can of Permatex leak seal spray, cleaned the area and sprayed it down. Hasn't leaked since.
    Its obvious that the dealer didn't even look at the truck when they're recommending service for a 4x4.
  3. Mar 11, 2022 at 7:20 PM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    WOW... yeah, so don't go back to that shop!
  4. Mar 11, 2022 at 7:20 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Not sure what they are trying to pull if they indeed told you you need a transfer case and front diff service if you have a pre-runner (2wd).
    As for the rest of the list:
    Brake fluid: Ideally should be changed around every 5 years but in reality most vehicles never have it changed and few have issues as a result.
    Rear Diff: Reccomended 60-100k (more often if you drive through high water).
    Transmission: Reccomended 60-100k (30-60k if you do alot of towing)
    Coolant: Reccomended 10 years 100k 1st change, 5 years 50k after
    Tune-up: Plugs V6 30k Reccomended, 4cyl 100k Reccomended, Water Pump only if it's leaking, noisy, or has play in the bearing.
    Timing cover leak is common, some members have had success cleaning the area very well and covering it with a good RTV otherwise it's a pretty big job to reseal the timing cover.
    Alot of maintenance info and links to witeups in the thread below.
    https://www.tacomaworld.com/threads/2nd-gen-diy-maintenance-quick-reference-guide.438945/
    Charlie Bravo and henryp like this.
  5. Mar 11, 2022 at 7:39 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Haha 4wd service..
    Without any record of prior service I'd do all of it except the timing cover leak
    Up here where it rains a lot, I recommend brake fluid every 2-3 years. Being hygroscopic it soaks up moisture and gets contaminated. Also repeated heat can cause aeration in the fluid down at the calipers. Flushing it out can improve overall pedal feel and fade
    Rob MacRuger and Dm93 like this.
  6. Mar 11, 2022 at 8:00 PM
    Waasheem
    Waasheem
    2007 xrunner
    Contact the bbb, see if they’d be interested in doing a sting. Go back and just get the transfer case and front differential services done.
    I swear it’s places like that that make my life difficult. I once went to a place & did a oil change and preventative maintenance service on a forklift. Told them the rear axle is broken, I don’t know how you can use it like that. They declined repair. Then called my office to say they can’t drive it now.
    Na taco typed out a good guideline to follow. Anything you don’t know how to do, you can find instructions in the stickies. Changing fluids early hurts nothing except your wallet. Changing fluids late can have adverse effects.
    A couple things to add. Make sure your battery terminals and posts are acid free and clean. Follow instructions in the stickies to clean your maf sensor and throttle body.
    tacotoe likes this.
  7. Mar 11, 2022 at 10:07 PM
    TacoTuesday1
    SD CA
    change your brake fluid every 1 or 2 years or when it looks bad. You can use a Motive pressure bleeder and power probe BA10 adapter
    you don't have a front diff
    • Rear diff service
    yeah. Gear oil. LSD oil if you have an LSD (early TRD Sport, sticker says LSD)
    you don't have a transfer case
    I'm not really sure how the dealer came up with this. Sometimes there's a program that automatically recommends services based on time/miles. Or an advisor who wants to sell things, which is normally good. Like let's say you have an advisor who knows his stuff and knows you're due for a coolant flush meanwhile you didn't know that. Great! Now you've just been informed.
    Only issue is, you don't have a transfer case...
    Techs can also make recommendations, but they would see you don't have a transfer case...
    It's also kind of a prerequisite to first ask you, "is it 4x4" which, depending on where you live, may not be. Like in CA, most Tacomas are not 4x4.I guess the trucks were bought to live on a dry highway.
    Yes
    • Coolant service
    Yes
    Spark plugs are due. Water pump is not a bad idea. I plan to change mine. If you have any interest in saving money, you can do yours yourself. If you buy some cheap tools, they will serve you for the rest of your life.
    A lot of people say "I don't have time." then play Call of Duty for 2 hours a day. You can fix the truck instead.
    The valve covers leak. You should start with those first.
    Timing covers can leak too. Probably labor intensive and not high part cost, which is great. Some people will say that is bad. But people say a lot of things.
    It is better to have a job that requires you fucking around on a Saturday to install a $20 part, than a $2k part taking less time that still fucks your wallet no matter how experienced, fast, or well-equipped with tools you are due to the part costing what it costs.
    I would not call the list a crap ton. In their mind, it is not. It is very shallow, easy, basic, cheap, bare minimum, and takes minutes to come up with a surface level common sense list like that.
    You don't have to do it all the same time.
    Fluids are usually $10+ a bottle.
    I guess it does add up if it's all at the same time versus one at a time.
    eherlihy and Charlie Bravo like this.
  8. Mar 11, 2022 at 10:16 PM
    Charlie Bravo
    Charlie Bravo Well-Known Member
    Charlie
    Coeur d'Alene, Idaho
    2009 Red Tacoma Access Cab 4wd 2.7MT
    RedLine Tuning hood QuickLIFT, Gen3 alloy 16x7J, All Pro Off-road bed stiffeners & IFS skid plate
    AMD, a Toyota Master Diagnostic Technician in Rust Belt Chicagoland, and his wife produce great videos on maintenance, DIY servicing, and vehicle reviews on "The Car Care Nut" YouTube channel. His advice is to not flush the transmission, just drain and fill at the 60k interval because some loose clutch material in the fluid aids engagement. I enjoy his service work videos done at his home garage evaluating and explaining what should be repaired/replaced out of necessity (safety), what should be watched to fix when it gets worse, and what looks bad but is nothing to worry about. As he says about Toyota's philosophy, Toyota's are engineered well so "If it ain't broke, don't fix it!" My lo-cal Toyota dealer has the same philosophy, so I was pleased with the technician and his work on Barcelona Red's first annual checkup. Two days later I stopped by the Parts dept. and asked for oil drain gaskets (having seen dealers selling packs of ten on eBay), and a pair of wiper blade inserts. I learned they have the gaskets in a large box gaskets, so "How many do you want?" "Four," since I have four Fram gold synthetic filters for changes between dealer changes (forget JiffyLube since they charge the same as the dealer, who also provides a coupon for a free car wash next door). I looked and he'd added a fifth gasket in the plastic bag. :)
  9. Mar 12, 2022 at 5:01 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    • Brake fluid service: nah
    • Front diff service: nah
    • Rear diff service: 20 minute job in your driveway
    • Transfer case fluid service: nah
    • Transmission fluid service: nah
    • Coolant service: nah
    • Tune up* assuming spark plugs / water pump etc: 20 minute job in your driveway/nah
    • Does have Timing cover leak:nah
    Charlie Bravo likes this.
  10. Mar 18, 2022 at 8:50 PM
    rick carpenter
    rick carpenter Well-Known Member
    Rick
    Huntsville, East Texas
    2019 SR5 2wd v6 DCLB for the win!
    I also like Ahmed and his channel. He'll respond to comments on the vids.
  11. Mar 19, 2022 at 10:59 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Just wanted to thank you for posting "The Car Care Nut" been watching on YouTube since I stumbled on this - guy really know his shite. Thanks.
