Mechanic put my wheel lock too tight
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jrdbrn, May 23, 2010.
  1. May 23, 2010 at 3:15 PM
    jrdbrn
    jrdbrn [OP] Well-Known Member
    Jared
    Louisiana
    '21 TRD Off Road
    I am hands on, so I decided today to rotate my tires. Back in November I had a flat tire, so for the time being I put the spare tire as my main, but had the local mechanic shop swap rims. Well, they put all the lug nuts too tight on the one tire! I had to use a cheater bar for the others, but the wheel lock socket stripped out.
    I plan on going back to the mechanic and having him take it off if he can. If not, is there anything I can do to get it off without paying Toyota assloads of money? :confused:
  2. May 23, 2010 at 3:38 PM
    rwcfrank
    rwcfrank Well-Known Member
    08 SR5 Prerunner
    I used to make good money removing wheel locks for the wheel store next to my old business. Get a large nut from the hardware store, something that takes a 3/4 or 7/8 socket. then weld it to the wheel lock with a mig gun . I used to use a toilet paper cardboard tube around the nut to keep the spatter from hittitng the wheel. The weld doesnt have to look good just be strong...Be sure to turn the nut as soon as your done welding the heat really helps..
  3. May 23, 2010 at 3:39 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Do you have any information about what brand wheel lock it is? Do you have paperwork for them? You might be able to call the manufacturer with a model or serial number and they might be able to send you a new wheel lock socket. Just a thought....
  4. May 23, 2010 at 3:41 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    HP60/14 bolt, Atlas 5.0.
    Hammer a socket onto it.
  5. May 23, 2010 at 4:09 PM
    jrdbrn
    Jared
    Louisiana
    '21 TRD Off Road
    The wheel locks came with the truck from Toyota.
    Hammering a socket won't do anything. It's a round nut, so there is nothing to grab. It wouldn't be so bad if the lug nut pattern wasn't so shallow.
  6. May 23, 2010 at 4:11 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    if you dont have access to a welder just try jbweld, I use it for all sorts of things and it may just work.
  7. May 23, 2010 at 4:13 PM
    jrdbrn
    Jared
    Louisiana
    '21 TRD Off Road
    Looking online, it appears they are made by McGard. I will contact them tomorrow to see what they suggest.
  8. May 23, 2010 at 4:13 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
    I think what THE END is saying is find a socket that won't quite fit and hammer the crap out of it to get it on the lug.
  9. May 23, 2010 at 4:20 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    So you stripped the key itself? I did the same using the crappy lug nut tool that comes with our trucks when I was standing on it. You have to be very careful with the McGuard wheel locks, they are very easy to brake. Taking them off requires equal pressure on the wheel lock itself, or you will strip the key.
    To get it off, you have 2 options. Order a new key from McGuard for $10. Or have a wheel/tire shop get it off by using a special tool for stripped lug nuts.
  10. May 23, 2010 at 4:24 PM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    cut a slot in it and use an impact driver?
    or I like the idea of welding a bolt head onto it..:thumbsup:
  11. May 23, 2010 at 4:26 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    I work at a tire shop. The "lock removal kit" is just some assorted sockets that you hammer on. Try it man, just don't hit your wheel.
  12. May 23, 2010 at 5:19 PM
    gjbonner
    gjbonner Well-Known Member
    Guy
    Northern Idaho
    07 Tacoma Off Road TRD
    Rhino Lined exterior,Fab Tech 6", 1.25" SpiderTrax spacers, Wheels painted Rustoleum Hammered Black, All Pro front plate bumper, Warn 9.5 ti winch, BHLM, Cig lighter constant on, Door beep toggle switch, Locker mod, Lock/unlock beeper Mod, Rear tailights smoked, 750w inverter with the outlets and on/off switch wired to rear of the console, Blacked out badges, blacked out rear bumper.
    yeah the guys that installed my lift put ALL mine on too tight! i actually broke the socket while using a cheater. luckily a tire shop nearby had a lock socket that was almost identical and ended up doing the job:) I had to give it some TLC to get it off. i was also able to cut off the end with a hacksaw ans save the broken socket, to some extent anyways! I don't even know why they were ALL locks. I asked for black lug nuts and that is what i got.
    I will soon be in the business for normal lug nuts and i will have a plethora of pinatas...i mean wheel locks. I guess for people i dont like i could install wheel locks on their tires :) that would be going too far i guess.
  13. May 23, 2010 at 5:28 PM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    once you get em off maybe look into gorilla locks. never had a problem with them
  14. May 23, 2010 at 6:06 PM
    TrdPETE
    TrdPETE Well-Known Member
    Maui
    08 double-cab 4x4
    TSB, Motto Metal 954, 5100s all around, front set @ 2.5, M/T baja atz radial, 285/70/17,Kenwood dd712,halo cccf,de-badged
    Totally agree. I have used this method myself. Works better then you might think
  15. May 23, 2010 at 8:47 PM
    jrdbrn
    Jared
    Louisiana
    '21 TRD Off Road
    Shouldn't I have gotten 4 regular lugs when I bought my truck? I can't seem to find them. My Mazda 3 came with 4 spare lugs.
  16. May 23, 2010 at 9:07 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Mine were in the glove box .
  17. May 23, 2010 at 9:12 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    .... 100ft/lbs is always enough.. I'd tell the dick to fix it.
  18. May 24, 2010 at 4:45 AM
    bailerc
    bailerc Well-Known Member
    Cody
    Fayetteville, NC
    16' MGM Limited
    I haven't checked my toyota manual yet, but im almost positive it will say the torque spec for a lug in there , like dually said prolly around 100
  19. May 24, 2010 at 5:16 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
  20. May 24, 2010 at 6:34 AM
    whitebread
    whitebread Well-Known Member
    Raleigh, NC
    2019 OR 4x4 6MT
    My owners manual says 85 ft*lbf.
