Mechanic who installed radiator spilled ATF fluid and other potential Issues - Need feedback
Discussion in '1st Gen. Tacomas (1995-2004)' started by yrmzzi, Dec 15, 2024.
  1. Dec 15, 2024 at 5:16 PM
    yrmzzi
    yrmzzi [OP] Active Member
    2001 Toyota Tacoma V6 - 4X4
    I recently had Precision Auto at 9009 Baileywick Rd #101, Raleigh, NC 27615 install a new radiator in my 2001 Tacoma V6 4x4. I provided my own OEM Toyota part for the job, which they agreed to install, and the final cost came to about $170.
    Given their solid reputation, I expected the job to be done properly. However, after I left, I popped the hood and found a significant amount of ATF fluid soaked throughout the engine compartment.
    I returned to ask about the issue, and they told me to call back in a few days when the technician who worked on my truck would be available. When I followed up, I was told the spill was due to an air bubble in the transmission, causing the fluid to leak. They offered to clean it up, but this explanation didn’t sit right with me. It seems more likely that the fluid was spilled while they were topping it off. I’m struggling to understand how an air bubble could cause such a large spill, and although I cleaned up most of it, you can still see traces of the fluid in the attached pictures.
    While I know no one will work on your vehicle as carefully as you would, this felt sloppy. After further inspection, I have several concerns and would really appreciate some feedback on whether these are real issues or if I’m overlooking something.
    1. The transmission fluid level is now dangerously low, even though I was charged for the fluid. Is this a sign they didn’t top it off correctly?
    2. The fan shroud doesn’t appear to be flush with the radiator, which I believe it should be. Also, the bolts or toggles securing the radiator seem to be improperly installed.
    This is really frustrating, and I’m considering asking for a partial refund since I’ll need to have these issues fixed. Could anyone let me know if these problems are serious or if I’m missing something? Where else should I inspect to make sure no other damage occurred during the installation? I’m really concerned this could lead to more costly repairs down the line.
    The fan shroud does not seem flush with the radiator.
    These toggles don't seem properly engaged
    I cleaned up most of the ATF fluid with soap and water but there's still a substantial amount...
  2. Dec 15, 2024 at 5:20 PM
    MGMDesertTaco
    ATF fluid is flammable and if it's on the serpentine belt and pulley's you'll need to clean them and replace the belt. Low atf fluid is no good.
    Find another shop or top off the atf fluid yourself. The fan shroud looks okay. Maybe get a second shops opinion. I wouldn't go back to that shop.
    yrmzzi[OP] likes this.
  3. Dec 15, 2024 at 5:24 PM
    yrmzzi
    I thought the fan shroud should be totally flush with the radiator??? I'll top the ATF fluid...
  4. Dec 15, 2024 at 5:30 PM
    MGMDesertTaco
    fan shroud doesn't need to be completely flush.
    MadNachos likes this.
  5. Dec 15, 2024 at 6:12 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    Yeah, that is certainly a proper fit for the shroud, no issue there.
  6. Dec 15, 2024 at 6:23 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It’s been a LONG time since I owned my 1st Gen with 3.4.
    But am fairly certain my truck had ATF cooler lines that went to the radiator.
    The whole “air bubble” thing make no sense. I bet it was a sloppy cleanup.
    The tech yanked the old one out.
    Tossed a new on in.
    Closed the hood.
    @Speedytech7 is the 1st Gen guru.
    He can correct me if I am wrong.
    But I seem to recall mine having atf cooler lines to the radiator.
  7. Dec 15, 2024 at 6:24 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Yup they do
    TnShooter[QUOTED] likes this.
  8. Dec 15, 2024 at 6:25 PM
    TnShooter
    Deogee
    STOCK
    I thought so.
    It’s been a long time since I was under a 1st Gen Auto.
    Thanks for confirming.
  9. Dec 15, 2024 at 6:26 PM
    MadNachos
    They do and it doesn't hold a lot. But if you don't plug the lines it can probably lose "extra". But it sounds like they were just sloppy.
  10. Dec 15, 2024 at 6:29 PM
    Moonrman
    Moonrman Fix it and it will run
    Hill Country, TX
    2001 Dbl_Cab Prerunner TRD
    Sounds like they didn't replace the amount of atf fluid that was in the original radiator transmission cooler portion. But my shroud, same year and engine as yours, is tucked up tight against radiator. I always give one chance to make things right and hear their attitude about the situation. $170 not a bad price if that includes labor, proper coolant, tranny fluid and shop supplies.
  11. Dec 15, 2024 at 6:33 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Am I the only one not seeing ATF everywhere?
    Idk what could even cause that. There are no transmission fluid lines above the radiator. There are two going to the bottom of the rad and are literally impossible to remove and plug without spilling some.
    $170 sound like 1.5hrs of labor which is definitely fair
    Area51Runner and MadNachos like this.
  12. Dec 15, 2024 at 6:34 PM
    MadNachos
    Looks really clean to me.
  13. Dec 15, 2024 at 6:39 PM
    Moonrman
    Hill Country, TX
    Even rusty bolts in Texas
  14. Dec 15, 2024 at 6:57 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Are you checking the ATF fluid when the engine is cold or hot? Just remember, if the engine is cold, it should be in the COLD range on the dipstick. If the engine is at operating temp, then it should be between the lower and upper HOT lines. ATF fluid expands as it gets hot.
    https://www.tacomaworld.com/threads/high-mileage-2002-prerunner-diff-oil-trans.833159/#post-29857418
    Do your own check and make sure its filled yourself. Use the linked procedure. It's not difficult to do.
    Also give your coolant overflow bottle a visual check. You should have coolant in there, somewhere around the mid point I believe. Don't want it higher than that. Look at it from the side.
    I too am at a loss as to how the hell ATF fluid ended up all over the top of the engine bay. Maybe they had an open bottle of ATF sitting up there on the airbox and was knocked over? :notsure:
    MadNachos and ABA180 like this.
  15. Dec 15, 2024 at 7:27 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Came here to say the same re the ATF check and to check the coolant as well..nice catch
